This example shows how to:
- Create a simple mechanism using various types of joints.
- Animate the mechanism using joint motors.
- Create geometry for all parts of the mechanism.
- Assign bodies and collision shapes to the parts.
- Set up masses for the parts.NoticeIt is very important to ensure mass balance – avoid connection of too heavy bodies to light ones, otherwise the joints may become unstable!
- Connect all parts of the mechanism using appropriate types of joints. Set up joint parameters.
- 2 blue guide bars
- a red piston
- a green rod
- a black wheel
- 2 dummy objects with dummy bodies to attach the parts of our mechanism to.
We are also going to add some physical parameters to the geometry such as mass and collision shapes. So, we need a set of basic functions:
ObjectDummyPtr createBodyDummy(char *name, const vec3& size, const Mat4& transform)
// creating a dummy object
// setting parameters
dummy->setWorldTransform(transform);
dummy->setName(name);
BodyDummy::create(dummy);
return dummy;
/// function, creating a named box having a specified size, color and transformation with a body and a shape
ObjectMeshDynamicPtr createBodyBox(char *name, const vec3& size, float mass, const vec4& color, const Mat4& transform)
// creating geometry and setting up its parameters (name, material and transformation)
ObjectMeshDynamicPtr OMD = Primitives::createBox(size);
OMD->setWorldTransform(transform);
OMD->setCollision(1, 0);
OMD->setName(name);
BodyRigidPtr body = BodyRigid::create(OMD);
body->addShape(ShapeBox::create(size), translate(vec3(0.0f)));
OMD->getBody()->getShape(0)->setMass(mass);
return OMD;
/// function, creating a named cylinder having a specified size, color and transformation with a body and a shape
ObjectMeshDynamicPtr createBodyCylinder(char *name, float radius, float height, float mass, const vec4& color, const Mat4& transform)
ObjectMeshDynamicPtr OMD = Primitives::createCylinder(radius, height, 1, 32);
OMD->setName(name);
body->addShape(ShapeCylinder::create(radius, height), translate(vec3(0.0f)));
return OMD;
Now using these functions we can create our mechanism. We are going to use DynamicMesh objects for the parts and Dummy objects for mounting points.
Mat4 transform = Mat4(translate(0.0f, 0.0f, 10.0f)*rotateY(90.0f));
piston = createBodyBox("piston", vec3(1.0f, 2.0f, 0.5f), 15.0f, vec4(1.0f, 0.1f, 0.1f, 1.0f), transform * Mat4(translate(0.0f, 3.5f, 0.0f)));
guide_bar1 = createBodyBox("guide_bar1", vec3(1.0f, 9.0f, 0.5f), 15.0f, vec4(0.0f, 0.1f, 0.7f, 1.0f), transform* Mat4(translate(1.0f, 3.0f, 0.0f)));
guide_bar2 = createBodyBox("guide_bar2", vec3(1.0f, 9.0f, 0.5f), 15.0f, vec4(0.0f, 0.1f, 0.7f, 1.0f), transform* Mat4(translate(-1.0f, 3.0f, 0.0f)));
wheel = createBodyCylinder("wheel", 3.0f, 0.25f, 25.0f, vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * Mat4(translate(0.0f, -15.0f, -0.5f)));
rod = createBodyCylinder("rod", 0.1f, 15.0f, 5.0f, vec4(0.1f, 1.1f, 0.1f, 1.0f), transform * Mat4(translate(0.0f, -5.0f, 0.0f) * rotateX(90.0f)));
//creating mounting points
dummy1 = createBodyDummy("dummy1", vec3(1.0f, 1.0f, 1.0f), transform * Mat4(translate(0.0f, -15.0f, -1.5f)));
dummy2 = createBodyDummy("dummy2", vec3(1.0f, 1.0f, 0.5f), transform * Mat4(translate(0.0f, 7.0f, 0.0f)));
Adding and Setting Up Joints#
jc = JointCylindrical::create(dummy1->getBody(), wheel->getBody());
jc->setWorldAxis(vec3(1.0f, 0.0f, 0.0f));
jc->setLinearRestitution(0.4f);
jc->setAngularRestitution(0.4f);
jc->setLinearSoftness(0.4f);
jc->setAngularSoftness(0.4f);
jc->setLinearDamping(4.0f);
jc->setAngularDamping(2.0f);
jc->setLinearLimitFrom(-0.0005f);
jc->setLinearLimitTo(0.0005f);
// setting number of iterations
jc->setNumIterations(16);
Now let us attach the rod to the wheel and to the piston. This is where we need a hinge joint. For both of these joints we have to specify anchor point and joint axis coordinates in the JointHinge() constructor
// creating hinge joints
jh = JointHinge::create(wheel->getBody(), rod->getBody(), Vec3(0.0f, -12.5f, 10.0f), vec3(1.0f, 0.0f, 0.0f));
jh2 = JointHinge::create(rod->getBody(), piston->getBody(), Vec3(0.0f, 2.5f, 10.0f), vec3(1.0f, 0.0f, 0.0f));
jh->setNumIterations(8);
jh2->setNumIterations(8);
The next thing we are going to do is to attach 2 guide bars to the second mounting point(dummy2) using a pair of fixed joints. For both of these joints we will specify anchor point coordinates in the JointFixed() constructor
// creating fixed joints
jf1 = JointFixed::create(dummy2->getBody(), guide_bar1->getBody(), Vec3(0.0f, 7.0f, 9.0f));
jf2 = JointFixed::create(dummy2->getBody(), guide_bar2->getBody(), Vec3(0.0f, 7.0f, 11.0f));
jf1->setNumIterations(1);
jf2->setNumIterations(1);
And the last joint we are going to use is a prismatic joint to attach the piston to the second mounting point(dummy2). Here we will specify joint axis coordinates, linear limits to determine the range of motion for the piston and linear softness
// creating a prismatic joint
jp = JointPrismatic::create(piston->getBody(), dummy2->getBody());
jp->setWorldAxis(vec3(0.0f, 1.0f, 0.0f));
jp->setLinearLimitFrom(-5.0f);
jp->setLinearLimitTo(0.0f);
jp->setLinearSoftness(0.5f);
jp->setNumIterations(8);
Using Joint Motors#
jc->setAngularVelocity(1000.0f);
jc->setAngularTorque(150.0f);
Putting it All Together#
In this section let us sum up all described above. The final code for our tutorial will be as follows:
// AppWorldLogic.h
#include <UnigineObjects.h>
Unigine::ObjectMeshDynamicPtr rod;
Unigine::ObjectMeshDynamicPtr wheel;
Unigine::ObjectMeshDynamicPtr piston;
Unigine::ObjectMeshDynamicPtr guide_bar1;
Unigine::ObjectMeshDynamicPtr guide_bar2;
#include "UnigineGame.h"
#include "UnigineEngine.h"
// joints of the mechanism
JointCylindricalPtr jc;
JointHingePtr jh;
JointHingePtr jh2;
JointFixedPtr jf1;
JointFixedPtr jf2;
JointPrismaticPtr jp;
return dummy;
OMD->setName(name);
return OMD;
OMD->setName(name);
return OMD;
int AppWorldLogic::init() {
Physics::setGravity(vec3(0.0f, 0.0f, -9.8f * 2.0f));
Physics::setFrozenLinearVelocity(0.1f);
Physics::setFrozenAngularVelocity(0.1f);
// setting up player
player->setPosition(Vec3(22.0f, -2.0f, 10.0f));
player->setDirection(vec3(-10.0f, -2.0f, 0.0f), vec3(0.0f, 0.0f, -1.0f));
Game::setPlayer(player);
