Each world script is associated with a certain world. Although the basic recommended workflow when writing application logic in C++ / C# is to have a single AppWorldLogic class to process all worlds in your project, sometimes it might be necessary to split world logic between several separate classes. In such a case the basic AppWorldLogic class is used as a manager calling corresponding methods (init(), update(), postUpdate(), etc.) of a particular class implementing logic of the current world.
This example illustrates how to split world-specific code between separate classes. Suppose in our project we have a default world named "world1" and another one named "world2" and we want to have two separate world logic classes (WorldLogic1 and WorldLogic2) for each of these worlds. Suppose we also want to switch between these worlds by pressing PGUP and PGDOWN keys.
1. Creating WorldLogic Classes#
First, we just inherit two new classes (WorldLogic1 and WorldLogic2) from Unigine::WorldLogic. You can simply copy the contents of AppWorldLogic.h and AppWorldLogic.cpp files and modify their init() and update() methods like this:
You can implement your logic for other methods of the execution sequence if necessary.
WorldLogic1.cpp
int WorldLogic1::init()
	// reporting that we're processing the first world and displaying a path to the .world file
	Log::message("Initializing the FIRST world (%s)\n", World::getPath());
	// insert your init logic for the first world
int WorldLogic1::update()
	// insert your update logic for the first world
WorldLogic2.cpp
int WorldLogic2::init()
	Log::message("Initializing the SECOND world (%s)\n", World::getPath());
	// insert your init logic for the second world
int WorldLogic2::update()
	// insert your update logic for the second world
2. Managing World Logics via AppWorldLogic#
Now, we implement world logic management in the AppWorldLogic, so we should add all our world logics, and a pointer to the one currently used. In the init() method, as it is called each time a new world is loaded, we should change the current world logic. So we modify the AppWorldLogic.h file as follows:
AppWorldLogic.h
#include "WorldLogic1.h"		//<-- include world logic class declaration for the first world
#include "WorldLogic2.h"		//<-- include world logic class declaration for the second world
	Unigine::WorldLogic *current_world_logic = &wl1;	//<-- pointer to the current world logic, we set the first one by default
	WorldLogic1 wl1;									//<-- world logic for the first world
	WorldLogic2 wl2;									//<-- world logic for the second world
Inside each method of the AppWorldLogic class, we simply call the corresponding method of the current world logic class, like for the init() and update() methods below. In the init() method, as it is called each time a new world is loaded, we also should change the current world logic, if necessary:
AppWorldLogic.cpp
#include <UnigineWorld.h>	//<-- include the UnigineWorld.h for the World class
int AppWorldLogic::init()
	// checking the name of the loaded world and updating current world logic
	if (strstr(World::getPath(), "world1.world"))
	else if (strstr(World::getPath(), "world2.world"))
		current_world_logic = &wl2;
	// calling the init() method of the current world logic
	current_world_logic->init();
int AppWorldLogic::update()
	// calling the update() method of the current world logic
	current_world_logic->update();
3. Keyboard World Loading via AppSystemLogic#
Switching between the worlds is to be performed in the AppSystemLogic class. In the update() method we should check keyboard input and load the corresponding world, if necessary. So, we modify the AppSystemLogic.cpp file as follows:
AppSystemLogic.cpp
#include <UnigineApp.h>
int AppSystemLogic::update()
	// checking key states and loading worlds
	if (App::clearKeyState(App::KEY_PGUP))
	{	// loading the second world if it is not already loaded
			World::loadWorld("world2");
	else if (App::clearKeyState(App::KEY_PGDOWN))
	{	// loading the first world if it is not already loaded
			World::loadWorld("world1");
Last update: 13.12.2021
