This example shows how to:
- Create a simple mechanism using various types of joints.
- Animate the mechanism using joint motors.
- Create geometry for all parts of the mechanism.
- Assign bodies and collision shapes to the parts.
- Set up masses for the parts.It is very important to ensure mass balance – avoid connection of too heavy bodies to light ones, otherwise the joints may become unstable!
- Connect all parts of the mechanism using appropriate types of joints. Set up joint parameters.
- 2 blue guide bars
- a red piston
- a green rod
- a black wheel
- 2 dummy objects with dummy bodies to attach the parts of our mechanism to.
/// function, creating a named dummy body having a specified size and transformation with a dummy body and a shape
Object createBodyDummy(string name, Vec3 size, Mat4 transform)
// creating geometry a dummy object and setting up its parameters (name and transformation)
ObjectDummy dummy = new ObjectDummy();
dummy.setWorldTransform(transform);
dummy.setName(name);
BodyDummy body = class_remove(new BodyDummy(dummy));
ShapeBox shape = class_remove(new ShapeBox(size));
body.addShape(shape, translate(0.0f, 0.0f, 0.0f));
return dummy;
/// function, creating a named box having a specified size, color and transformation with a body and a shape
Object createBodyBox(string name, Vec3 size, float mass, Vec4 color, Mat4 transform)
// creating geometry and setting up its parameters (name, material and transformation)
ObjectMeshDynamic box = Unigine::createBox(size);
box.setWorldTransform(transform);
box.setMaterial("mesh_base", "*");
box.setMaterialParameterFloat4("albedo_color", color, 0);
box.setCollision(1, 0);
box.setName(name);
BodyRigid body = class_remove(new BodyRigid(box));
shape.setMass(mass);
body.setFreezable(0);
return box;
/// function, creating a named cylinder having a specified radius, height, color and transformation with a body and a shape
Object createBodyCylinder(string name, float radius, float height, float mass, Vec4 color, Mat4 transform)
ObjectMeshDynamic cylinder = Unigine::createCylinder(radius, height, 1, 32);
cylinder.setWorldTransform(transform);
cylinder.setMaterial("mesh_base", "*");
cylinder.setMaterialParameterFloat4("albedo_color", color, 0);
cylinder.setCollision(1, 0);
cylinder.setName(name);
BodyRigid body = class_remove(new BodyRigid(cylinder));
ShapeCylinder shape = class_remove(new ShapeCylinder(radius, height));
return cylinder;
Now using these functions we can create our mechanism. We are going to use DynamicMesh objects for the parts and Dummy objects for mounting points.
Mat4 transform = Mat4(translate(0.0f, 0.0f, 10.0f)*rotateY(90.0f));
piston = createBodyBox("piston", Vec3(1.0f, 2.0f, 0.5f), 15.0f, Vec4(1.0f, 0.1f, 0.1f, 1.0f), transform* translate(0.0f, 3.5f, 0.0f));
guide_bar1 = createBodyBox("guide_bar1", Vec3(1.0f, 9.0f, 0.5f), 15.0f, Vec4(0.0f, 0.1f, 0.7f, 1.0f), transform* translate(1.0f, 3.0f, 0.0f));
guide_bar2 = createBodyBox("guide_bar2", Vec3(1.0f, 9.0f, 0.5f), 15.0f, Vec4(0.0f, 0.1f, 0.7f, 1.0f), transform* translate(-1.0f, 3.0f, 0.0f));
wheel = createBodyCylinder("wheel", 3.0f, 0.25f, 25.0f, Vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * translate(0.0f, -15.0f, -0.5f));
rod = createBodyCylinder("rod", 0.1f, 15.0f, 5.0f, Vec4(0.1f, 1.1f, 0.1f, 1.0f), transform * translate(0.0f, -5.0f, 0.0f) * rotateX(90.0f));
//creating mounting points
dummy1 = createBodyDummy("dummy1", Vec3(1.0f, 1.0f, 1.0f), transform * translate(0.0f, -15.0f, -1.5f));
dummy2 = createBodyDummy("dummy2", Vec3(1.0f, 1.0f, 0.5f), transform * translate(0.0f, 7.0f, 0.0f));
Adding and Setting Up Joints#
jc = class_remove(new JointCylindrical(dummy1.getBody(), wheel.getBody()));
jc.setWorldAxis(vec3(1.0f, 0.0f, 0.0f));
jc.setLinearRestitution(0.4f);
jc.setAngularRestitution(0.4f);
jc.setLinearSoftness(0.4f);
jc.setAngularSoftness(0.4f);
jc.setLinearDamping(4.0f);
jc.setAngularDamping(2.0f);
jc.setLinearLimitFrom(-0.0005f);
jc.setLinearLimitTo(0.0005f);
// setting number of iterations
jc.setNumIterations(16);
Now let us attach the rod to the wheel and to the piston. This is where we need a hinge joint. For both of these joints we have to specify anchor point and joint axis coordinates in the JointHinge() constructor
// creating hinge joints
jh = class_remove(new JointHinge(wheel.getBody(), rod.getBody(), Vec3(0.0f, -12.5f, 10.0f), Vec3(1.0f, 0.0f, 0.0f)));
jh2 = class_remove(new JointHinge(rod.getBody(), piston.getBody(), Vec3(0.0f, 2.5f, 10.0f), Vec3(1.0f, 0.0f, 0.0f)));
jh.setNumIterations(8);
jh2.setNumIterations(8);
The next thing we are going to do is to attach 2 guide bars to the second mounting point(dummy2) using a pair of fixed joints. For both of these joints we will specify anchor point coordinates in the JointFixed() constructor
// creating fixed joints
jf1 = class_remove(new JointFixed(dummy2.getBody(), guide_bar1.getBody(), Vec3(0.0f, 7.0f, 9.0f)));
jf2 = class_remove(new JointFixed(dummy2.getBody(), guide_bar2.getBody(), Vec3(0.0f, 7.0f, 11.0f)));
jf1.setNumIterations(1);
jf2.setNumIterations(1);
And the last joint we are going to use is a prismatic joint to attach the piston to the second mounting point(dummy2). Here we will specify joint axis coordinates, linear limits to determine the range of motion for the piston and linear softness
// creating a prismatic joint
jp = class_remove(new JointPrismatic(piston.getBody(), dummy2.getBody()));
jp.setWorldAxis(vec3(0.0f, 1.0f, 0.0f));
jp.setLinearLimitFrom(-5.0f);
jp.setLinearLimitTo(0.0f);
jp.setLinearSoftness(0.5f);
jp.setNumIterations(8);
Using Joint Motors#
jc.setAngularVelocity(1000.0f);
jc.setAngularTorque(150.0f);
Putting it All Together#
In this section let us sum up all described above. The final code for our tutorial will be as follows:
#include <core/scripts/primitives.h>
return dummy;
box.setName(name);
return box;
return cylinder;
// parts of the mechanism and mounting points
ObjectDummy dummy1;
ObjectDummy dummy2;
ObjectMeshDynamic rod;
ObjectMeshDynamic wheel;
ObjectMeshDynamic piston;
ObjectMeshDynamic guide_bar1;
ObjectMeshDynamic guide_bar2;
// joints of the mechanism
JointCylindrical jc;
JointHinge jh;
JointHinge jh2;
JointFixed jf1;
JointFixed jf2;
JointPrismatic jp;
int init() {
engine.physics.setGravity(vec3(0.0f,0.0f,-9.8f * 2.0f));
engine.physics.setFrozenLinearVelocity(0.1f);
engine.physics.setFrozenAngularVelocity(0.1f);
// setting up player
Player player = new PlayerSpectator();
player.setPosition(Vec3(22.0f,-2.0f,10.0f));
player.setDirection(Vec3(-10.0f,-2.0f,0.0f));
// creating and setting up hinge joints
// creating and setting up a prismatic joint
// creating and setting up fixed joints
// creating and setting up a cylindrical joint
