Creating Mirrors Using Viewports (Rendering to Texture) or a Standard Material
This example covers some aspects of using viewports and cameras as well as demonstrates 2 different ways of implementing mirrors:
- Using the planar reflection option of the standard mesh_base material.NoticePlanar reflections don't reflect each other and miss post-effects.
- Using the Viewport class to render an image from a certain camera to the RenderTarget interface and then setting the texture as albedo texture of the mirror material.
- 3 rearview mirrors implemented using viewport texture rendering
- large top rearview tilted mirror implemented using the planar reflection option of the mesh_base material.
- 2 modes:
- Single viewport for multiple cameras
- Separate viewport for each camera
- Keyboard control of car movement.
Using the Standard mesh_base Material#
You can create mirrors by simply using the planar reflection option the mesh_base material. The basic workflow here is as follows:
- Create a mesh, that is going to represent a mirror.
- Inherit a material from the mesh_base.
- For the new inherited material perform the following actions:
- Enable the planar reflection option for the new inherited material.
For metalness workflow:
- Set the value of the metallness parameter to 1.
- Set the value of the roughness parameter to 0.
For specular workflow:
- Set the value of the gloss parameter to 1.
- Set the value of the microfiber parameter to 0.
- Tune the reflection_pivot_rotation parameter to compensate rotation of the surface if any.
- Assign the new inherited material to the reflecting surface.
- Enable rendering of planar reflections using the render_reflection_dynamic console command.
Using Viewports (Rendering to Texture)#
Another way of creating mirrors is to use a viewport to render an image from a camera placed behind the mirror to a texture and set it as albedo texture for the material of the reflecting surface. This approach can also be used to create various portals or monitors showing an image from a certain camera etc. The basic workflow here is as follows:
- Create a camera and set its projection and modelview matrices (in case of implementing a mirror the camera should be placed behind the mirror looking in the direction of the normal to the reflecting surface).
- Create a 2D texture to render the image from the camera to.
- Create a viewport to render the image from the camera to the texture.NoticeIt is recommended to use a separate viewport for each camera. In case of using several cameras with a single viewport rendering of screen-space effects should be disabled to avoid artefacts (See the render_screen_space_effects console command).
- Save current render state and change necessary settings.
- Render an image from the camera to the texture using the renderTexture2D() method of the Viewport class.
- Restore the previously saved render state.
- Set the texture as albedo texture for the material of the reflecting surface.
Using Both Approaches to Create Mirrors for a Car#
First let us describe our Car class and implement all methods using the approaches described above.
// Car.cs
using System;
using System.Linq;
using System.Text;
using Unigine;
enum VMode
MODE_VIEWPORT_SINGLE, // use a single viewport for multiple cameras
MODE_VIEWPORT_MULTIPLE // use a separate viewport for each camera
namespace UnigineApp
// rearview mirror
struct Mirror {
public ObjectMeshStatic mesh; // mirror mesh
public String m_type; // mirror type (left/right/mid)
public Texture texture; // mirror texture
public PlayerDummy camera; // mirror camera
public Viewport viewport; // mirror viewport
public dvec3 position; // mirror position
class Car
const float MOVING_SPEED = 10.0f; // speed of objects movement
const float DELTA_ANGLE = 60.0f; // delta angle of objects rotation
const int ASPECT_RATIO = 1; // aspect ratio
const float HFOV = 60; // horizontal field of view
const float VFOV = HFOV / ASPECT_RATIO; // vertical field of view
VMode MODE = VMode.MODE_VIEWPORT_MULTIPLE; // set viewport mode (single/multiple)
ObjectMeshStatic car_frame;
ObjectMeshStatic material_mirror;
Mirror[] mirrors = new Mirror[3];
Controls controls;
float ifps;
/// method creating a mirror using the mesh_base "planar reflection" option
public bool create_top_mirror()
// creating a mesh with a plane surface for the top mirror
Mesh mesh = new Mesh();
mesh.AddPlaneSurface("plane", 1.97f, 0.3f, 1.0f);
// rotating the mesh surface by 108 degrees around the X-axis
mesh.SetSurfaceTransform(MathLib.RotateX(108.0f));
// creating a top mirror and setting its position
material_mirror = new ObjectMeshStatic(mesh);
material_mirror.Position = new dvec3(0.0f, 0.73f, 1.60f);
// passing the node to the Editor and adding it as a child to the car frame
car_frame.AddChild(material_mirror);
// creating a new mirror material named "planar_reflector"
Material mesh_base = Materials.FindMaterial("mesh_base");
Material reflector_material = mesh_base.Inherit("planar_reflector");
// enabling planar reflections for the mirror material
reflector_material.SetState("planar_reflection", 1);
// setting metallness and roughness parameters to make the surface look like a mirror
reflector_material.SetParameterSlider(reflector_material.FindParameter("metalness"), 1.0f);
reflector_material.SetParameterSlider(reflector_material.FindParameter("roughness"), 0.0f);
// compensating the 108-degree rotation angle of the mesh surface
reflector_material.SetParameter(reflector_material.FindParameter("reflection_pivot_rotation"), new vec4(108.0f, 0.0f, 0.0f, 0.0f));
// assigning new mirror material to the surface of the mirror
material_mirror.SetMaterial("planar_reflector", 0);
// enabling planar reflections rendering using the corresponding console command (render_reflection_dynamic)
Console.Run("render_reflection_dynamic 1");
return true;
public bool Init()
// setting texture width and height
int width = 512;
int height = width / ASPECT_RATIO;
// preparing a mesh for the car body
Mesh bodymesh = new Mesh();
bodymesh.AddBoxSurface("body", new vec3(2.0f, 5.0f, 1.2f));
bodymesh.AddBoxSurface("body", new vec3(0.05f, 0.05f, 1.1f));
bodymesh.SetSurfaceTransform(MathLib.Translate(new vec3(0.96f, 0.8f, 0.91f)), 1);
bodymesh.SetSurfaceTransform(MathLib.Translate(new vec3(-0.96f, 0.8f, 0.91f)), 2);
bodymesh.AddBoxSurface("body", new vec3(1.88f, 0.05f, 0.05f));
bodymesh.SetSurfaceTransform(MathLib.Translate(new vec3(0.0f, 0.8f, 1.435f)), 3);
// creating car body using a mesh and passing it to the Editor
car_frame = new ObjectMeshStatic(bodymesh);
car_frame.SetMaterial("mesh_base", "*");
car_frame.SetMaterialParameterFloat4("albedo_color", new vec4(1.0f, 0.0f, 0.0f, 1.0f), 0);
// creating a top rearview mirror using the mesh_base material
create_top_mirror();
// setting type and position for all mirrors
mirrors[0].m_type = "left";
mirrors[1].m_type = "mid";
mirrors[2].m_type = "right";
mirrors[0].position = new dvec3(-1.08f, 0.77f, 0.9f);
mirrors[1].position = new dvec3(0.0f, 0.35f, 1.25f);
mirrors[2].position = new dvec3(1.08f, 0.77f, 0.9f);
// initializing mirrors
for (int i = 0; i < 3; i++)
// creating a mesh for the current mirror
mesh.AddPlaneSurface("mirror_plane", 0.2f, 0.1f, 1);
// creating the current mirror and setting its transform
mirrors[i].mesh = new ObjectMeshStatic(mesh);
mirrors[i].mesh.Transform = new dmat4(MathLib.Translate(new vec3(mirrors[i].position))*MathLib.RotateX(90.0f));
// creating and setting materials for the current mirror mesh
mesh_base.Inherit(String.Concat("car_mirror_", mirrors[i].m_type));
mirrors[i].mesh.SetMaterial(String.Concat("car_mirror_", mirrors[i].m_type), 0);
// creating a camera for the current mirror and setting its parameters
mirrors[i].camera = new PlayerDummy();
mirrors[i].camera.Projection = MathLib.Perspective(VFOV, 2.0f, 0.05f, 10000.0f) * MathLib.Scale(-1.0f, 1.0f, 1.0f);
mirrors[i].camera.Position = mirrors[i].position;
mirrors[i].camera.SetDirection(new vec3(0.0f, -1.0f, 0.0f), vec3.UP);
// adding mirror mesh and camera as children to the car frame
car_frame.AddChild(mirrors[i].mesh);
car_frame.AddChild(mirrors[i].camera);
// creating a 2D texture to be set for the mirror material
mirrors[i].texture = Texture.Create();
mirrors[i].texture.Create2D(width, height, Texture.FORMAT_RGBA8, Texture.USAGE_RENDER);
// checking viewport mode and creating necessary number of viewports
if (MODE == VMode.MODE_VIEWPORT_MULTIPLE)
mirrors[i].viewport = new Viewport();
else if ((MODE == VMode.MODE_VIEWPORT_SINGLE) && (i == 1))
// setting up player and controls
PlayerSpectator player = new PlayerSpectator();
car_frame.AddChild(player);
player.WorldPosition = new dvec3(0.0f, -0.5f, 1.1f);
player.Controlled = false;
Game.Player = player;
Game.Enabled = true;
player.Fov = 60.0f;
player.SetDirection(new vec3(0.0f, 1.0f, 0.0f), new vec3(0.0f, 0.0f, -1.0f));
player.Collision = 0;
controls = player.Controls;
car_frame.WorldPosition = car_frame.WorldPosition + new dvec3(0.0f, 4.0f, 0.0f);
return true;
public bool Update()
ifps = Engine.ifps;
dmat4 transform = car_frame.WorldTransform;
dvec3 direction = transform.GetColumn3(1);
// checking controls states and changing car frame transformation
if ((controls.GetState(Controls.STATE_FORWARD) == 1) || (controls.GetState(Controls.STATE_TURN_UP) == 1))
car_frame.WorldPosition = car_frame.WorldPosition + direction * MOVING_SPEED*ifps;
if ((controls.GetState(Controls.STATE_BACKWARD) == 1) || (controls.GetState(Controls.STATE_TURN_DOWN) == 1))
car_frame.WorldPosition = car_frame.WorldPosition - direction * MOVING_SPEED*ifps;
if ((controls.GetState(Controls.STATE_MOVE_LEFT) == 1) || (controls.GetState(Controls.STATE_TURN_LEFT) == 1))
car_frame.SetWorldRotation(car_frame.GetWorldRotation() * new quat(0.0f, 0.0f, DELTA_ANGLE*ifps));
direction.z += DELTA_ANGLE*ifps;
if ((controls.GetState(Controls.STATE_MOVE_RIGHT) == 1) || (controls.GetState(Controls.STATE_TURN_RIGHT) == 1))
car_frame.SetWorldRotation(car_frame.GetWorldRotation() * new quat(0.0f, 0.0f, -DELTA_ANGLE*ifps));
direction.z -= DELTA_ANGLE*ifps;
return true;
public bool Render()
Viewport viewport;
// using a separate viewport for each camera
viewport = mirrors[i].viewport;
else
// using a single viewport for all cameras
viewport = mirrors[1].viewport;
// skipping post effects when using a single viewport for multiple cameras to avoid artefacts
viewport.AppendSkipFlags(Viewport.SKIP_POSTEFFECTS);
// saving current render state and clearing it
RenderState render_state = RenderState;
render_state.SaveState();
render_state.ClearStates();
// enabling polygon front mode to correct camera flipping
render_state.PolygonFront = 1;
// rendering and image from the camera of the current mirror to the texture
viewport.RenderTexture2D(mirrors[i].camera.Camera, mirrors[i].texture);
// restoring back render state
render_state.PolygonFront = 0;
render_state.RestoreState();
Material material = mirrors[i].mesh.GetMaterialInherit(0);
// setting rendered texture as albedo texture for the material of the current mirror
material.SetTexture(material.FindTexture("albedo"), mirrors[i].texture);
return true;
And now let us integrate our car to the AppWorldLogic class.
// AppWorldLogic.cs
using System;
using System.Linq;
using System.Text;
using Unigine;
Car car;
public override bool Init()
// creating and initializing a car
car = new Car();
car.Init();
return true;
// start of the main loop
public override bool Update()
car.Update();
return true;
public override bool Render()
car.Render();
return true;
