The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Unigine Material Library
Dummy Object
A dummy object is an object that is not present in the world visually but shares all of the properties that other objects have. It is usually used as an invisible object with physics properties and can also serve as a root node to organize objects in a hierarchy.
Last update: 03.07.2017
