The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Unigine Material Library
Dynamic Mesh
A dynamic mesh is an object geometry represented by points, lines or triangles that are modified procedurally. It has all the static meshes' shader functionalities, so you can load an existing static mesh as a dynamic one in order to modify it.
Last update: 03.07.2017
