Switcher
A switcher is a cuboid shaped object, switching off (or turning on) all of the nodes inside of it immediately.
A world switcher should be a parent node for the nodes it controls.
- WorldSwitcher class to edit world switchers via UnigineScript
- Unigine::WorldSwitcher class to edit world switchers via C++ API
Creating a Switcher
To create a world switcher, choose the Add World Switcher option in the list of nodes in Editor panel. In the creation dialog window, specify initial parameters:
A Creation Window
Point | A flag, indicating if the distance to the object is counted from the bounding box center (if disabled, the distance will be counted from its nearest edge). |
Size | The size of the switcher's bounding box along the X, Y and Z axes, in units. |
After the initial parameters are set, click Ok and place the world switcher somewhere in the world.
Editing a Switcher
In the Switcher tab you can adjust the following parameters of the switcher:
A Switcher tab
Bounding Box Parameters
Point | A flag, indicating if the distance to the object is counted from the center of the bounding box (if disabled, the distance will be counted from its nearest edge). |
Offset | The offset of the switcher's bounding box along the X, Y and Z axes, in units. |
Switching Off Parameters
Switching of distances:
Min distance | The minimum distance of visibility, in units. If a camera is closer to a node than this minimum distance, a node is not visible. |
Max distance | The maximum distance of visibility, in units. If a camera is further from a node than this maximum distance, a node is not visible. |
Last update: 03.07.2017
