C# Component Samples
SDK Browser contains a set of C# component system samples that demonstrate various ways of using C# components. These samples are arranged into a demo that is easy to run or convert to a project, which can be then modified as necessary.
Accessing Demo Source Code#
- Find the C# Component Samples demo in the Available section and click Install (if you haven't installed it yet).
- After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
- In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
- Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
