Migrating to UNIGINE from Unity: Programming
Game logic in a Unity project is implemented via Script components. You got used to determine GameObject's behavior by writing event functions like Start(), Update(), etc.
UNIGINE has quite a similar concept, which can be easily adopted — C# Component System, which is safe and secure and ensures high performance. Logic is written in C# components that can be assigned to any node in the scene. Each component has a set of functions (Init(), Update(), etc.), that are called by the corresponding functions of the engine main loop.
Programming in UNIGINE using C# is not much different from programming in Unity software. For example, let's compare how rotation is performed in Unity software:
Source code (C#)
using UnityEngine;
public class MyComponent : MonoBehaviour
    public float speed = 90.0f;
    void Update()
        transform.Rotate(0, speed * Time.deltaTime, 0, Space.Self);
and in UNIGINE:
Source code (C#)
using Unigine;
public class MyComponent : Component
	void Update()
		node.Rotate(0, 0, speed * Game.IFps);
The Run button is available in the Editor to run an instance of the application in a separate window. Along with the button, there are settings available to fine-tune run options.
That's how we'll make the wheel rotate using C# Component System and run an instance to immediately check it:
Moreover in UNIGINE, you can also implement Application Logic for the whole application by writing code in the AppWorldLogic.cs, AppSystemLogic.cs and AppEditorLogic.cs files stored in the source/ project folder.
To learn more about the execution sequence and how to build components, follow the links below:
For those who prefer C++, UNIGINE allows creating C++ applications using C++ API and, if required, C++ Component System.
Writing Gameplay Code#
Printing to Console#
Unity software UNIGINE
Source code (C#)
Debug.Log("Text: " + text);
Debug.LogFormat("Formatted text: {0}", text);
Source code (C#)
Log.Message("Debug info:" + text + "\n");
Log.Message("Debug info: {0}\n", new vec3(1, 2, 3));
  • More types of messages in the Log class API
  • The video tutorial demonstrating how to print user messages to console using C# Component System
Accessing the GameObject / Node from Component#
Source code (C#)
GameObject this_go = gameObject;
string n = gameObject.name;
Source code (C#)
Node this_node = node;
string n = node.Name;
  • The video tutorial demonstrating how to access nodes from components using C# Component System
Working with Directions#
In Unity software to get a vector on a certain axis while also considering the rotation of a game object in world coordinates, you use the corresponding properties of the Transform component. The same vector in UNIGINE is got by using Node.GetWorldDirection() function:
Source code (C#)
Vector3 forward = transform.forward;
Vector3 right = transform.right;
Vector3 up = transform.up;
transform.Translate(forward * speed * Time.deltaTime);
Source code (C#)
vec3 forward = node.GetWorldDirection(MathLib.AXIS.Y);
vec3 right = node.GetWorldDirection(MathLib.AXIS.X);
vec3 up = node.GetWorldDirection(MathLib.AXIS.Z);
node.Translate(forward * speed * Game.IFps);
Intances of the Players-Related classes use different direction vectors and are to be treated correspondingly.
Smoother Gameplay with DeltaTime / IFps#
In Unity software to ensure that certain actions are performed at the same time periods regardless of the framerate (e.g. change something once per second etc) you use a scaling multiplier Time.deltaTime (the time in seconds it took to complete the last frame). The same thing in UNIGINE is called Game.IFps:
Source code (C#)
Source code (C#)
Drawing Debug Data#
Unity software:
Source code (C#)
Debug.DrawLine(Vector3.zero, new Vector3(5, 0, 0), Color.white, 2.5f);
Vector3 forward = transform.TransformDirection(Vector3.forward) * 10;
Debug.DrawRay(transform.position, forward, Color.green);
UNIGINE:
Source code (C#)
Visualizer.Enabled = true;
Visualizer.RenderLine3D(vec3.ZERO, new vec3(5, 0, 0), vec4.ONE);
Visualizer.RenderVector(node.Position, node.GetDirection(MathLib.AXIS.Y) * 10, new vec4(1, 0, 0, 1));
The visualizer can be toggled on and off via show_visualizer 1 console command as well.
  • More types of visualizations in the Visualizer class API.
Loading a Scene#
Source code (C#)
SceneManager.LoadScene("YourSceneName",LoadSceneMode.Single);
Source code (C#)
World.LoadWorld("YourSceneName");
Accessing a Component from the GameObject / Node#
Unity software:
Source code (C#)
MyComponent my_component = gameObject.GetComponent<MyComponent>();
UNIGINE:
Source code (C#)
MyComponent my_component = node.GetComponent<MyComponent>();
MyComponent my_component = GetComponent<MyComponent>(node);
Accessing Standard Components#
Unity software provides component-based workflow so such standard entities as MeshRenderer, Rigidbody, Collider, Transform and other are treated as usual components.
In UNIGINE, analogs for these entities are accessed differently. For example, to access an entity of a type derived from the Node class (e.g. ObjectMeshStatic), you should downcast the instance to the corresponding class. Let's consider these most popular use cases:
Unity software:
Source code (C#)
// accessing the transform of the game object
Transform transform_1 = gameObject.GetComponent<Transform>();
Transform transform_2 = gameObject.transform;
// accessing the Mesh Renderer component
MeshRenderer mesh_renderer = gameObject.GetComponent<MeshRenderer>();
// accessing the Rigidbody component
Rigidbody rigidbody = gameObject.GetComponent<Rigidbody>();
// accessing a collider
Collider collider = gameObject.GetComponent<Collider>();
BoxCollider boxCollider = collider as BoxCollider;
UNIGINE:
Source code (C#)
// getting the transformation matrix of the node
mat4 transform = node.WorldTransform;
// downcasting the node to the ObjectMeshStatic class
ObjectMeshStatic mesh_static = node as ObjectMeshStatic;
// accessing the rigid body assigned to the node
Body body = (node as Unigine.Object).Body;
BodyRigid rigid = body as BodyRigid;
// fetch all collision shapes of the ShapeBox type
for (int i = 0; i < body.NumShapes; i++)
	Shape shape = body.GetShape(i);
	if (shape is ShapeBox)
		ShapeBox shape_box = shape as ShapeBox;
Finding GameObjects / Nodes#
Unity software:
Source code (C#)
// Find a GameObject by name
GameObject myGameObj = GameObject.Find("My Game Object");
// Find the child named "ammo" of the gameobject "magazine" (magazine is a child of "gun").
Transform ammo_transform = gameObject.transform.Find("magazine/ammo");
GameObject ammo = ammo_transform.gameObject;
// Find GameObjects by the type of component assigned
MyComponent[] components = Object.FindObjectsOfType<MyComponent>();
foreach (MyComponent component in components)
// Find GameObjects by tag
GameObject[] taggedGameObjects = GameObject.FindGameObjectsWithTag("MyTag");
foreach (GameObject gameObj in taggedGameObjects)
UNIGINE:
Source code (C#)
// Find a Node by name
Node my_node = World.GetNodeByName("my_node");
// Find all nodes having this name
List<Node> nodes = new List<Node>();
World.GetNodesByName("my_node");
// Find the index of a direct child node
int index = node.FindChild("child_node");
Node direct_child = node.GetChild(index);
// Perform a recursive descend down the hierarchy to find a child Node by name
Node child = node.FindNode("child_node", 1);
// Find Nodes by the type of component assigned
MyComponent[] my_comps = FindComponentsInWorld<MyComponent>();
foreach(MyComponent comp in my_comps)
	Log.Message("{0}\n",comp.node.name);
Casting From Type to Type#
Downcasting (from a pointer-to-base to a pointer-to-derived) is performed similarly in both engines, by using the C# as native construction:
Source code (C#)
Collider collider = gameObject.GetComponent<Collider>;
Source code (C#)
Node node = World.GetNodeByName("my_mesh");
ObjectMeshStatic mesh = node as ObjectMeshStatic;
To perform Upcasting (from a pointer-to-derived to a pointer-to-base) you can simply use the instance itself:
Source code (C#)
Collider coll = boxCollider;
Source code (C#)
Unigine.Object obj = mesh;
Destroy GameObject/Node#
Source code (C#)
Destroy(maGameObject);
// destroy the game object with 1 second delay
Destroy(maGameObject, 1);
Source code (C#)
node.DeleteLater(); // recommended option
//called between the current and the next frames
node.DeleteForce(); // called during the same frame but unsafe
To perform deferred removal of a node in UNIGINE, you can create a component that will be responsible for the timer and deletion.
Source code (C#)
// LifetimeController.cs
public class LifetimeController : Component
	public float lifetime = 5.0f;
	void Update()
		lifetime = lifetime - Game.IFps;
        if (lifetime < 0)
            // destroy current node with its properties and components
			node.DeleteLater();
// MyComponent.cs
	void Update()
		if (/* a reason to die */)
			LifetimeController lc = node.AddComponent<LifetimeController>();
			lc.lifetime = 2.0f;
Instantiating Prefab / Node Reference#
In Unity software, you instantiate a prefab using the Object.Instantiate function:
Source code (C#)
using UnityEngine;
public GameObject myPrefab;
void Start()
	Instantiate(myPrefab, new Vector3(0, 0, 0), Quaternion.identity);
Then, you should specify the prefab to be instantiated in the script component parameters:
In UNIGINE, you should use World.LoadNode to load a hierarchy of nodes from a .node asset. In this case the hierarchy of nodes that was saved as NodeReference will be added to the scene. You can refer to the asset either via a component parameter or manually by providing the virtual path to it:
Source code (C#)
	public AssetLinkNode node_to_spawn;
	private void Init()
		Node spawned = node_to_spawn.Load(node.WorldPosition, quat.IDENTITY);
		Node spawned_manually = World.LoadNode("nodes/node_reference.node");
In case of using the approach of component parameters, you should also specify the .node asset:
You can also spawn the node reference as a single node (without extracting the content) in the world:
Source code (C#)
	void Init()
		NodeReference nodeRef = new NodeReference("nodes/node_reference_0.node");
Running Scripts in the Editor#
You are likely to be accustomed that Unity software enables you to extend the Editor using C# scripts. For this purpose you can use special attributes in your scripts:
  • [ExecuteInEditMode] — to execute the script logic during Edit mode, while your application is not running.
  • [ExecuteAlways] — to execute the script logic both as part of Play mode and when editing.
For example, this is how you write a component that makes GameObject orient towards the certain point in the scene:
Source code (C#)
//C# Example (LookAtPoint.cs)
using UnityEngine;
[ExecuteInEditMode]
public class LookAtPoint : MonoBehaviour
    public Vector3 lookAtPoint = Vector3.zero;
    void Update()
        transform.LookAt(lookAtPoint);
UNIGINE doesn't support executing C# logic inside the Editor. Instead, you can write logic in UnigineScript to optimize a project creation process. UnigineScript is available for any programming workflow you have chosen for your project including C# .NET 5.
There are two methods to add a script to the project:
  • By creating a World script. Perform the following steps:
    1. Create a .usc script asset.
    2. Write logic. If necessary, add a condition checking if the Editor is loaded:
      Source code (UnigineScript)
      #include <core/unigine.h>
      vec3 lookAtPoint = vec3_zero;
      Node node;
      int init() {
      	node = engine.world.getNodeByName("material_ball");
      int update() {
      	if(engine.editor.isLoaded())
      		node.worldLookAt(lookAtPoint);
    3. Select the current world and specify the world script for it. Click Apply and reload the world.
    4. Check the Console window for errors.
    After that the script logic will be executed in both Editor and application.
  • By using WorldExpression. For the same purpose you can use a built-in WorldExpression node executing scripts when added to the world:
    1. Click Create -> Logic -> Expression and place the new WorldExpression node in the world.
    2. Write logic in UnigineScript in the Source field:
      Node node = engine.world.getNodeByName("my_node");
    3. Check the Console window for errors.
    4. The logic will be executed immediately.
Triggers#
In addition to collision detection, Unity Collider component is accountable for being Trigger that is executed when one collider enters the space of another.
Source code (C#)
    void Start()
        collider.isTrigger = true;
    void OnTriggerEnter(Collider other)
    void OnTriggerExit(Collider other)
In UNIGINE, Trigger is a special built-in node that raises events in certain situations:
WorldTriger is the most common type that can be used in gameplay. Here is an example on how to use it:
Source code (C#)
	WorldTrigger trigger;
	void enter_callback(Node incomer)
		Log.Message("\n{0} has entered the trigger space\n", incomer.Name);
	void Init()
		trigger = node as WorldTrigger;
		if(trigger != null)
			trigger.AddEnterCallback(enter_callback);
			trigger.AddLeaveCallback( leaver => Log.Message("{0} has left the trigger space", leaver.Name));
Input#
Unity Conventional Game Input:
Source code (C#)
public class MyPlayerController : MonoBehaviour
    void Update()
        if (Input.GetButtonDown("Fire"))
        float horizontal = Input.GetAxis("Horizontal");
        float vertical = Input.GetAxis("Vertical");
UNIGINE:
Source code (C#)
class MyPlayerController : Component
    void Update()
		if(Input.IsMouseButtonDown(Input.MOUSE_BUTTON.LEFT))
			Log.Message("Left mouse button was clicked at {0}\n", Input.MouseCoord);
		if (Input.IsKeyDown(Input.KEY.Q) && !Unigine.Console.Activity)
			Log.Message("Q was pressed and the Console is not active.\n");
			App.Exit();
You can also use the ControlsApp class to handle control bindings. To configure the bindings, open the Controls settings:
Source code (C#)
    void Init()
		// remapping states to keys and buttons
		ControlsApp.SetStateKey(Controls.STATE_FORWARD, 'w');
		ControlsApp.SetStateKey(Controls.STATE_BACKWARD, 's');
		ControlsApp.SetStateKey(Controls.STATE_MOVE_LEFT, 'a');
		ControlsApp.SetStateKey(Controls.STATE_MOVE_RIGHT, 'd');
		ControlsApp.SetStateButton(Controls.STATE_JUMP, App.BUTTON_LEFT);
	void Update()
		if (ControlsApp.ClearState(Controls.STATE_FORWARD) != 0)
			Log.Message("FORWARD key pressed\n");
		else if (ControlsApp.ClearState(Controls.STATE_BACKWARD) != 0)
			Log.Message("BACKWARD key pressed\n");
		else if (ControlsApp.ClearState(Controls.STATE_MOVE_LEFT) != 0)
			Log.Message("MOVE_LEFT key pressed\n");
		else if (ControlsApp.ClearState(Controls.STATE_MOVE_RIGHT) != 0)
			Log.Message("MOVE_RIGHT key pressed\n");
		else if (ControlsApp.ClearState(Controls.STATE_JUMP) != 0)
			Log.Message("JUMP button pressed\n");
Raycasting#
In Unity software, Physics.Raycast is used. GameObject should have a Collider component attached to take part in raycasting:
Source code (C#)
using UnityEngine;
public class ExampleClass : MonoBehaviour
	public Camera camera;
    void Update()
    	// ignore the 2nd layer
        int layerMask = 1 << 2;
        layerMask = ~layerMask;
        RaycastHit hit;
        Ray ray = camera.ScreenPointToRay(Input.mousePosition);
        if (Physics.Raycast(ray, out hit, Mathf.Infinity, layerMask))
            Debug.DrawRay(transform.position, transform.TransformDirection(Vector3.forward) * hit.distance, Color.yellow);
            Debug.Log("Did Hit");
        else
            Debug.DrawRay(transform.position, transform.TransformDirection(Vector3.forward) * 1000, Color.white);
            Debug.Log("Did not Hit");
In UNIGINE the same is handled by Intersections:
Source code (C#)
class IntersectionExample : Component
	void Init()
    void Update()
    	ivec2 mouse = Input.MouseCoord;
		float length = 100.0f;
		vec3 start = Game.Player.WorldPosition;
		vec3 end = start + new vec3(Game.Player.GetDirectionFromScreen(mouse.x, mouse.y)) * length;
		// ignore surfaces that have certain bits of the Intersection mask enabled
		int mask = ~(1 << 2 | 1 << 4);
		WorldIntersectionNormal intersection = new WorldIntersectionNormal();
		Unigine.Object obj = World.GetIntersection(start, end, mask, intersection);
		if (obj)
			vec3 point = intersection.Point;
			vec3 normal = intersection.Normal;
			Visualizer.RenderVector(point, point + normal, vec4.ONE);
			Log.Message("Hit {0} at {1}\n", obj.Name, point);
Last update: 2021-12-13
