Creating End UI
The end widget should be visible when the game is over. The user will be able to restart the game or exit the application via the corresponding buttons.
Step 1. Make the World Widget Controller#
The widget controller node will specify the handlers for different types of UI elements and show the UI at the end of the game.
  1. Create a new C++ component and call it UiElement. This component handles the selection and button functions calls. Write the following code and save your code in your IDE.
    UiElement.h (C++)
    #pragma once
    #include <UnigineApp.h>
    #include <UnigineGame.h>
    class UiElement : public Unigine::ComponentBase
    	COMPONENT_DEFINE(UiElement, ComponentBase)
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	enum Element { Restart, Exit, None };
    	// default type of a UI element
    	Element uiType = Element::None;
    	// scale on cursor hover
    	float selectScale = 1;
    	// emission color on cursor hover
    	Unigine::Math::vec4 selectEmission = Unigine::Math::vec4_black;
    	// default mask for the mouse intersection detection
    	int uiMask = 1;
    	static void setOnClickCallback(Unigine::CallbackBase *callback) { onClickCallback = callback; }
    protected:
    	void init();
    	void update();
    	void onWindowResize();
    	void onDisable();
    	void onLeave();
    	void onEnter();
    	static Unigine::CallbackBase *onClickCallback;
    	// ID of the UI element
    	int Id;
    	// ID counter for initialization
    	static int idCount;
    	// counter of selected objects
    	int selectedObjects = 0;
    	Unigine::WorldIntersectionPtr intersection;
    	bool isSelect = false;
    	Unigine::ObjectPtr uiObject = nullptr;
    	Unigine::Math::vec3 sourceScale = Unigine::Math::vec3_one;
    	Unigine::Math::vec4 sourceEmission = Unigine::Math::vec4_one;
    UiElement.cpp (C++)
    #include "UiElement.h"
    REGISTER_COMPONENT(UiElement);
    CallbackBase *UiElement::onClickCallback = nullptr;
    int UiElement::idCount = 0;
    void UiElement::init()
    	// set ID
    	Id = idCount;
    	++idCount;
    	// get the UI element
    	uiObject = checked_ptr_cast<Object>(node);
    	// remember the source scale and emission color
    	sourceScale = node->getScale();
    	if (uiObject)
    		sourceEmission = uiObject->getMaterialParameterFloat4("emission_color", 0);
    	intersection = WorldIntersection::create();
    void UiElement::update()
    	// get points for intersection
    	vec3 dir = Game::getPlayer()->getDirectionFromScreen();
    	vec3 p0 = Game::getPlayer()->getWorldPosition();
    	vec3 p1 = p0 + dir * 25.0f;
    	// find the intersection
    	ObjectPtr obj = World::getIntersection(p1, p0, uiMask, intersection);
    	if (obj)
    		// try to get the UI element component and select/deselect it
    		UiElement *uiElement = ComponentSystem::get()->getComponent<UiElement>(obj);
    		if (uiElement && uiElement->Id == Id)
    			if (!isSelect)
    				UiElement::onEnter();
    				isSelect = true;
    				++selectedObjects;
    		else if (isSelect)
    			UiElement::onLeave();
    			isSelect = false;
    			--selectedObjects;
    	else
    		if (isSelect)
    			isSelect = false;
    			--selectedObjects;
    	// run the mouse click callback
    	if (isSelect && Input::isMouseButtonDown(Input::MOUSE_BUTTON::MOUSE_BUTTON_LEFT) && onClickCallback)
    		onClickCallback->run(uiType);
    void UiElement::onDisable()
    	// deselect an object
    	if (isSelect)
    		--selectedObjects;
    		if (selectedObjects < 0)
    		isSelect = false;
    void UiElement::onEnter()
    	// set the visual effect on selection
    	node->setScale(sourceScale * selectScale);
    	uiObject->setMaterialParameterFloat4("emission_color", selectEmission, 0);
    void UiElement::onLeave()
    	// remove the visual effect when the UI element is not selected anymore
    	node->setScale(sourceScale);
    	uiObject->setMaterialParameterFloat4("emission_color", sourceEmission, 0);
  2. Create a new C++ component and call it EndWidget. Copy the code below and paste it to the corresponding files in your project and save them in your IDE.
    EndWidget.h (C++)
    #pragma once
    #include "LevelManager.h"
    #include <UnigineConsole.h>
    class EndWidget : public Unigine::ComponentBase
    	COMPONENT_DEFINE(EndWidget, ComponentBase)
    	// object with the end game message
    	PROP_PARAM(Node, endGameWidget);
    protected:
    	void init();
    	void endGameEventHandler();
    	void onClickHandler(UiElement::Element uiType);
    	LevelManager *levelManager;
    EndWidget.cpp (C++)
    #include "EndWidget.h"
    REGISTER_COMPONENT(EndWidget);
    void EndWidget::init()
    	levelManager = ComponentSystem::get()->getComponent<LevelManager>(World::getNodeByName("level_manager"));
    	if (levelManager)
    		levelManager->setEndGameCallback(MakeCallback(this, &EndWidget::endGameEventHandler));
    	// set the mouse click handler for UI elements (Restart/Exit)
    	UiElement::setOnClickCallback(MakeCallback(this, &EndWidget::onClickHandler));
    	if (endGameWidget)
    		// hide the end UI
    		endGameWidget->setEnabled(false);
    void EndWidget::endGameEventHandler()
    	// set gui and input
    	Input::setMouseHandle(Input::MOUSE_HANDLE::MOUSE_HANDLE_USER);
    	// show the end UI
    	endGameWidget->setEnabled(true);
    void EndWidget::onClickHandler(UiElement::Element uiType)
    	// restart the level by reloading the world
    	if (uiType == UiElement::Element::Restart)
    		Unigine::Console::run("world_reload");
    	// exit the game
    	if (uiType == UiElement::Element::Exit)
    		App::exit();
  3. Build and run the solution in your IDE to regenerate the properties.
  4. Switch to the UnigineEditor and create a new Dummy Node. Call it "widgets_controller".
  5. Assign the EndWidget property to the widgets_controller node.
Step 2. Set Up the World Widget#
The end widget provides button functionality and additional information about the current game outcome. To properly display the end widget, position it in front of the camera.
  1. Drag the programming_quick_start\ui\ui_plane.node from the Asset Browser to the world.
  2. Parent it to the PlayerDummy camera. Set the position of the ui_plane node to the following values.
  3. Save changes to the world, go to File->Save World or press Ctrl + S hotkey.
  4. Next, we add a win condition check, end widget text, and a callback run to the LevelManager class. Let's also assign the UiElement component to the end widget's buttons right there in the LevelManager class.
    Set the Ui Type to Restart, check the 6th bit option for the Ui Mask (matching the button’s Intersection Mask) to correctly process selection intersections and set the Select Scale to 1.05 in order to make buttons bigger on cursor hover. Also, set the Select Emission to #505050 to make the button change its color.
    To do so, open the LevelManager component in your IDE and replace it with the following code. Don’t forget to save your code.
    LevelManager.h (C++)
    #pragma once
    #include <UnigineWidgets.h>
    #include <UnigineString.h>
    //=========================== NEW - END ================================
    class LevelManager : public Unigine::ComponentBase
    	COMPONENT_DEFINE(LevelManager, ComponentBase)
    	COMPONENT_INIT(init, 2);
    	COMPONENT_SHUTDOWN(shutdown);
    	// level timer
    	PROP_PARAM(Float, timer, 100.0f);
    	PROP_PARAM(Node, restartButton);
    	PROP_PARAM(Node, exitButton);
    	void decPhysicalObjectsNum();
    	void setEndGameCallback(Unigine::CallbackBase *callback) { endGameEvent = callback; }
    protected:
    	void init();
    	void update();
    	void shutdown();
    	void initGUI();
    	Unigine::CallbackBase *endGameEvent = nullptr;
    	bool isCounting = true;
    	int physicalObjectsNum;
    	Unigine::WidgetLabelPtr widget_timer, widget_goal;
    	Unigine::ObjectTextPtr endText;
    LevelManager.cpp (C++)
    REGISTER_COMPONENT(LevelManager);
    void LevelManager::init()
    	LevelManager::initGUI();
    	// find the object text node of the widget
    	endText = checked_ptr_cast<ObjectText>(Game::getPlayer()->findNode("header_text", 1));
    	// count dynamic objects in the level
    	physicalObjectsNum = node->getNumChildren();
    	// set up the restart button as a UI element
    	if (restartButton)
    		UiElement* restart_component = ComponentSystem::get()->addComponent<UiElement>(restartButton);
    		restart_component->uiType = UiElement::Element::Restart;
    		restart_component->uiMask = 0x00000040; // 6th bit is set
    		restart_component->selectScale = 1.05f;
    	// set up the exit button as a UI element
    	if (exitButton)
    		UiElement* exit_component = ComponentSystem::get()->addComponent<UiElement>(exitButton);
    		exit_component->uiType = UiElement::Element::Exit;
    		exit_component->uiMask = 0x00000040; // 6th bit is set
    void LevelManager::initGUI()
    	// get a GUI pointer
    	GuiPtr gui = Gui::get();
    	// create a label widget and set up its parameters
    	widget_timer = WidgetLabel::create(gui, "Time Left:");
    	widget_timer->setPosition(10, 10);
    	widget_timer->setFontColor(vec4::RED);
    	widget_goal = WidgetLabel::create(gui, "Objects Left: ");
    	widget_goal->setPosition(10, 30);
    	widget_goal->setFontColor(vec4::BLUE);
    	// add widgets to the GUI
    	gui->addChild(widget_timer, Gui::ALIGN_OVERLAP);
    	gui->addChild(widget_goal, Gui::ALIGN_OVERLAP);
    void LevelManager::update()
    	// decrease the timer
    	if (isCounting)
    		timer = timer - Game::getIFps();
    		if (timer <= 0)
    			//set end game text
    			endText->setText("Game Over");
    			if (endGameEvent) endGameEvent->run();
    			isCounting = false;
    	// show the current time and objects left to clear
    	if (isCounting)
    		widget_timer->setText(String::format("Time Left: %.2f s", timer.get()));
    		widget_goal->setText(String::format("Objects Left: %d", physicalObjectsNum));
    	//hide the widgets on endgame
    	else
    		widget_timer->setEnabled(false);
    		widget_goal->setEnabled(false);
    	//win
    	if (physicalObjectsNum <= 0)
    		endText->setText("Success!");
    		isCounting = false;
    void LevelManager::shutdown()
    	widget_timer->deleteLater();
    	widget_goal->deleteLater();
    void LevelManager::decPhysicalObjectsNum()
    	physicalObjectsNum--;
  5. Build and run the solution to regenerate a property file for the LevelManager component.
  6. Switch to the UnigineEditor, select the ui_plane node in the World Nodes window and right-click to choose Unpack To Node Content to link the buttons nodes to the LevelManager component.
  7. Then drag the buttons (restart_button and exit_button) to the corresponding fields of the LevelManager property.
  8. Drag the ui_plane node to the End Game Widget field under the EndWidget component of the widgets_controller node.
  9. Save changes to the world, go to File->Save World or press Ctrl + S hotkey.
  10. Switch to your IDE, then build and run the game in your IDE to see the UI in action.
Last update: 2022-02-04
