Clouds
This section contains settings for clouds.
Clouds Settings
Common#
Enable Clouds The value indicating if rendering of clouds is enabled. Enabled by default.
Console access: render_clouds_enabled
Ground Shadows The value indicating if rendering of shadows from the clouds on the ground is enabled. Enabled by default.
Console access: render_clouds_ground_shadows
Accurate Layers Sorting The value indicating if correct sorting of intersecting cloud layers is enabled.
Enabling this feature may reduce raymarching quality as samples shall be distributed among all layers.
Enabled by default.
Console access: render_clouds_accurate_layers_sorting
Transparent Order The rendering order for clouds relative to transparent objects (except water).
  • Render Before Transparent — render clouds before all transparent objects (except water).
  • Render After Transparent — render clouds after all transparent objects (except water).
  • Sort Transparent — enable rough sorting for transparent objects relative to clouds (below the lowest cloud layer base -> inside the clouds -> above the highest cloud layer top).
Console access: render_clouds_transparent_order
Detail Distortion The value indicating which texture type is currently used for clouds distortion. This parameter has a significant impact on performance:
  • 2D Texture — more performance-friendly, but may cause an excessive vertical extrusion of clouds.
  • 3D Texture — ensures homogeneous detail distortion and better image quality, but at a higher performance cost.
Console access: render_clouds_distortion_texture
Soft Intersection The soft intersection distance for clouds, in meters.
Range of values: [0.0f, 100000.0f]. The default value is 100.0f.
Console access: render_clouds_soft_intersection
Quality#
Clouds quality rendering settings
Preset The index of the currently used clouds quality preset. One of the following values:
  • Low (by default)
  • Medium
  • High + Interleaved
  • High
  • Ultra + Interleaved
  • Ultra
  • Extreme + Interleaved
  • Extreme
  • Custom
Console access: render_clouds_quality_preset
Customizable Settings#
Clouds quality custom settings
Clouds Quality Settings
Sampling Quality The sampling quality for clouds. This parameter sets the number of noise samples that affects the cloud shape processing quality. The higher the value, the less are visual artifacts. The following modes are available:
  • Low — 1 sample, low quality (higher cloud density)
  • Medium — 3 samples, medium quality
  • High — 5 samples, high quality
  • Ultra — 6 samples, ultra quality (lower density, the clouds are softer)
Visual difference between low and ultra quality is not significant. Therefore, it is recommended to use low settings, when possible, to gain performance.
Console access: render_clouds_sampling_quality
Lighting Quality The lighting quality for clouds. This parameter determines the number of samples used to calculate lighting for clouds. The following values are available:
This parameter has a significant impact on performance. Therefore, it is recommended to use low settings, when possible.
Console access: render_clouds_lighting_quality
Samples Count The number of samples used for clouds rendering. The higher the value, the less noise in clouds rendering. The following values are available:
Option #3 is selected by default (see above).
Console access: render_clouds_samples_count
Step Accuracy The accuracy of ray marching steps. This parameter enables you to improve the visual look of clouds when viewed from inside a cloud layer. It reduces the noise of lighting and clouds shape for long ray marching distances, adds some noise-based blur to a sharp border at the bottom sphere of the cloud layer (rounded) and removes popping effect when leaving a rounded cloud layer. Higher values provide more accurate form and less noise, while lower ones gain more performance.
Range of values: [0.0f, 1.0f]. The default value is 0.5f.
Console access: render_clouds_step_accuracy
Downsampling Rendering The downsampling rendering mode for clouds. This parameter determines clouds resolution based on current screen resolution.
  • Full - full resolution
Console access: render_clouds_downsampling_rendering
Interleaved Rendering The interleaved rendering mode for clouds. In cases when clouds are viewed from the ground, or from above (at significant distance) and viewer's velocities are less than 200 units per second, this parameter can be used to provide a significant gain in performance. One of the following values:
  • Disabled (by default)
  • 2×2
  • 4×4
  • 8×8
Console access: render_clouds_interleaved_rendering
Depth Based Reconstruction The value indicating if clouds ray-marched depth is used for upsampling the downsampled clouds without obscuring the geometry and reprojection depending on the cloud depth. Recommended for flying through clouds.
Works only with the clouds downsampling rendering mode set to half and/or the clouds interleaved rendering mode set to 2x2.
Enabled by default.
Console access: render_clouds_depth_based_reconstruction
Interleaved Rendering Temporal The value indicating if temporal accumulation of noises for interleaved sampling for clouds is enabled.
Works only when the clouds interleaved rendering mode is set to 2x2.
Enabled by default.
Console access: render_clouds_interleaved_rendering_temporal
Depth Based Reconstruction Threshold The depth threshold value for clouds depth-based reconstruction mode. This value defines the depth difference starting from which pixels are considered to be related to different surfaces.
Range of values: [0.0f, inf]. The default value is 100.0f.
Console access: render_clouds_depth_based_reconstruction_threshold
Noise Step The value of the noise step parameter for clouds. This parameter determines the amount of jitter in the areas within clouds, that is used to reduce banding effect due to insufficient number of steps.
Range of values: [0.0f, 1.0f]. The default value is 0.3f.
Console access: render_clouds_noise_step
Noise Iterations The value of the noise iterations parameter for clouds. This parameter determines the amount of jitter in the areas within clouds, that is used to reduce banding effect due to insufficient number of steps.
Range of values: [0.0f, 1.0f]. The default value is 0.1f.
Console access: render_clouds_noise_iterations
Noise Lighting The value of the noise lighting parameter for the clouds. This parameter determines the amount of jitter for tracing steps of lighting calculation, that is used to reduce banding effect due to insufficient number of steps.
Console access: render_clouds_noise_lighting
Noise Step Skip The value of the noise step skip parameter for clouds. This parameter determines the amount of jitter in the areas between clouds, that is used to reduce banding effect due to insufficient number of steps.
Console access: render_clouds_noise_step_skip
Lighting#
Lighting Trace Length The lighting trace length for clouds. This parameter determines the maximum length of a sun ray inside a cloud.
Range of values: [1.0f, 2048.0f]. The default value is 230.0f.
Console access: render_clouds_lighting_tracelength
Lighting Cone Radius The lighting cone sampling radius for clouds lighting.
Low values may result in unnatural behavior as the position of the sun changes.
Console access: render_clouds_lighting_cone_radius
Lighting Samples Distribution The value that controls distribution of samples for clouds lighting. Can be used to keep small details for long shadows when the lighting trace length value is high.
Range of values: [0.001f, 5.0f]. The default value is 1.0f.
Console access: render_clouds_lighting_samples_distribution
Rounded#
Enable Rounded The value indicating if cloud layers are to be curved to make them look more natural imitating planet's curvature. Enabled by default.
Console access: render_clouds_rounded
Planet Radius The radius of the planet to be used for clouds curving. Visual curving can be used to make clouds look more natural imitating planet's curvature.
Range of values: [100.0f, inf]. The default value is 200000.0f.
Console access: render_clouds_rounded_planet_radius
Dynamic Coverage#
Dynamic Coverage Resolution The the value defining the size of the square dynamic coverage resolution texture for clouds, in pixels. This parameter determines the quality of dynamic coverage texture for FieldWeather objects. Higher values make it possible to preserve texture details at high distances.
Range of values: [16, 8192]. The default value is 256.
Console access: render_clouds_dynamic_coverage_resolution
  • 128 x 128
  • 256 x 256
  • 512 x 512
  • 1024 x 1024
  • 2048 x 2048
Dynamic Coverage Area The dynamic coverage area for clouds, in units. This parameter determines visibility distance for coverage of FieldWeather objects.
Increasing dynamic coverage area leads to reduction of quality of FieldWeather coverage texture and loss of details. This effect can be mitigated by increasing dynamic coverage resolution using the corresponding command.
Range of values: [10.0f, 400000.0f]. The default value is 10000.0f.
Console access: render_clouds_dynamic_coverage_area
Last update: 2021-12-13
