Cluster Editor
Cluster Editor is a convenient tool for brush-based placement of meshes baked into Mesh Clusters directly in the scene. It allows editing the existing Mesh Clusters and creating new ones.
Cluster Editor is available when the Cluster Paint Mode is selected on the toolbar:
Switching to this mode opens the Active Tool window:
In the Objects section, there is a list of all Mesh Cluster objects available in the world. Similarly to the World Hierarchy window, you can organize the nodes:
  • Select one or several nodes;
  • Toggle the nodes on and off;
  • Filter nodes by name;
  • Rename a node by double-clicking on it;
  • Toggle the Spawn When Drawing flag.
To edit the required Mesh Clusters (one or many), select them either in the Objects section or in the World Hierarchy window and specify the Objects settings.
For convenience, the Create New Cluster button, a shortcut to manual creation of Mesh Clusters, is available right in the Active Tool window.
Editing Mesh Clusters with Cluster Editor#
As soon as you have at least one Mesh Cluster with the Spawn When Drawing flag enabled, brush painting is available in the Editor Viewport. Select the required tool and start editing the cluster directly in the scene:
Available tools:
  • Replace Density — replace meshes within the Brush Radius with new ones spawned in accordance with the current density values.
  • Single Object — place a single mesh at the desired point.
  • Erase — remove meshes.
To paint over a surface or an object, make sure it has the Intersection flag and any bit of the Intersection Mask enabled. Painting over Mesh Cluster objects is not available.
Brush Settings#
Radius Size of the brush.
Density Multiplier Global multiplier for density.
Controls#
  • To draw with a brush, click LMB and drag the mouse.
  • To change the brush radius, use the mouse wheel.
  • To switch to the Replace Density tool, press B.
  • To switch to the Erase tool, press E.
You can adjust the controls in the Cluster Paint Mode tab of the Editor Hotkeys settings.
Objects Settings#
The following settings are saved for each Mesh Cluster in the scene:
Spawn When Drawing
Flag indicating if the Mesh Cluster is affected by brush painting.
Seed
Pseudo-random seed that defines the distribution of spawned meshes. Click the Randomize button to generate a new Seed.
If the same Seed value is set for several Mesh Clusters, their new meshes will spawn at the same points during one stroke.
Density The target density of meshes of the Mesh Cluster.
Normal Orientation Flag indicating whether new meshes should orient along the normals of surfaces under the brush.
Local Offset Minimum and maximum offset values for new meshes with regard to normal orientation.
World Offset Minimum and maximum offset for new meshes in world coordinates.
Local Rotation Minimum and maximum rotation values for new meshes with regard to normal orientation.
World Rotation Minimum and maximum rotation values for new meshes in world coordinates.
Scale Minimum and maximum scale values for new meshes. Click the gear icon to choose the scale mode:
  • Uniform — meshes are scaled uniformly along all axes.
  • Nonuniform — scale is random along each axis.
Last update: 2021-12-13
