Thread Safety in API
Unigine API objects are guaranteed to be used safely in the main loop. When it comes to multiple user threads, things get a bit more complicated.
As not all of API classes are thread-safe, you should take into consideration the behaviour type of an API member to reach safe multithreading in your application.
All types require special approaches described in this article.
Dealing with Multiple Threads#
Thread-Safe Objects#
Fully thread-safe objects are free to use in any thread, be it the main loop or a user's one. This is provided due to thread synchronization mechanisms making all critical operations atomic and protecting data structures, it negates issues like race condition and others.
Only one thread is allowed to access data at the same time, while data is locked for other threads, that is why multiple threads may have to wait for each other until their tasks are finished.
Many requests to data from multiple threads may cause additional performance loss due to synchronization.
The following API members are considered to be thread-safe:
Loading Nodes Asynchronously#
It is not allowed to load nodes in user threads. For that purpose the AsyncQueue Class is recommended to be used.
AppWorldLogic.h
Source code (UnigineScript)
#ifndef __APP_WORLD_LOGIC_H__
#define __APP_WORLD_LOGIC_H__
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UnigineThread.h>
	AppWorldLogic() {}
	virtual ~AppWorldLogic() {}
	virtual int init();
	virtual int shutdown();
	Thread *thread1;
	Thread *thread2;
AppWorldLogic.cpp
#include "AppWorldLogic.h"
#include <UnigineAsyncQueue.h>
class MeshProducerThread : public Thread
	MeshProducerThread()
		callback = AsyncQueue::addCallback(AsyncQueue::CALLBACK_MESH_LOADED, MakeCallback(this, &MeshProducerThread::mesh_loaded));
	~MeshProducerThread()
		AsyncQueue::removeCallback(AsyncQueue::CALLBACK_MESH_LOADED, callback);
	void process()
		while (isRunning())
			mesh_id = AsyncQueue::loadMesh("core\\meshes\\material_ball.mesh");
			wait();
			Log::message("Thread %d: mesh loaded\n", getID());
			AsyncQueue::takeMesh(mesh_id);
	void mesh_loaded(const char *name, int id)
		if (mesh_id == id)
			signal();
	int mesh_id = 0;
	int callback = 0;
int AppWorldLogic::init()
	thread1 = new MeshProducerThread();
	thread1->run();
	thread2 = new MeshProducerThread();
	thread2->run();
int AppWorldLogic::shutdown()
	thread1->stop();
	thread2->stop();
Avoiding Deadlocks#
There is a possibility of mutual locking, also known as deadlock, on condition that a function of a locked object executes a callback function which in turn calls a function of the same locked object.
To prevent deadlocks you should avoid calling potentially locked objects from their callback functions.
Intersections with Global Terrain#
ObjectTerrainGlobal contains a set of thread-safe methods intended for some special use cases.
AppWorldLogic.h
#include <UnigineVector.h>
	AppWorldLogic();
	virtual ~AppWorldLogic();
	virtual int init();
	Unigine::Vector<Thread*> threads;
AppWorldLogic.cpp
#include <UnigineEditor.h>
#include <UnigineObjects.h>
#include <UnigineGame.h>
class TerrainIntersectionThread : public Thread
	TerrainIntersectionThread(ObjectTerrainGlobalPtr terrain_)
		terrain = terrain_;
		intersection = ObjectIntersection::create();
	void process() override
		while (isRunning())
			float x = Game::getRandomFloat(-1000.0f, 1000.0f);
			float y = Game::getRandomFloat(-1000.0f, 1000.0f);
			int success = terrain->getIntersection(vec3{ x, y, 10000.0f }, vec3{ x, y, 0.0 }, intersection, 0);
			if (success)
				const auto intersection_point = intersection->getPoint();
				Log::message("Thread %d: %f %f %f\n", getID(), intersection_point.x, intersection_point.y, intersection_point.z);
	ObjectTerrainGlobalPtr terrain;
	ObjectIntersectionPtr intersection;
	const auto terrain = checked_ptr_cast<ObjectTerrainGlobal>(World::getNodeByName("Landscape"));
	int num_thread = 4;
	for (int i = 0; i < num_thread; ++i)
		Thread *thread = new TerrainIntersectionThread(terrain);
		thread->run();
		threads.push_back(thread);
	for (Thread *thread : threads)
		thread->stop();
		delete thread;
Main-Loop-Dependent Objects#
The Node class and the Node-Related classes are directly involved into threads of the main loop. They don't have synchronization mechanisms provided.
To safely operate on these objects from user threads, you should firstly pause the main loop to avoid interference. Then, you can run a required number of jobs for processing of nodes. After all jobs are done, continue the main loop.
Gpu-related methods must be called only in the main loop.
Thread safety is ensured by synchronization of all Engine’s threads dealing with main-loop-dependent objects with Engine::swap(), where delayed deletion of objects is performed. But user threads can be executed in parallel with Engine::swap() in the main thread, in such cases you shouldn’t perform any manipulations with main-loop dependent objects (such as nodes) during Engine::swap().
For some typical cases it is recommended to use the following objects:
  • AsyncQueue Class is useful for asynchronous loading of resources.
  • Async Class is intended for running custom tasks in asynchronous way.
Main-Loop-Independent Objects#
There are also API members which are not involved into the main loop, they don't have synchronization algorithms as well.
You can fully manage such an object in any thread, but please note that if you need to send it to another thread, either the main loop or a user's thread, you have to provide manual synchronization for its data consistency.
For this purpose you are free to use any methods and classes contained in the include/UnigineThread.h file or other mechanisms at your discretion.
The following API members are considered to be independent of the main loop threads:
See the Thread С++ Sample for C++ implementation of manual synchronization using the ScopedLock based on the simple mutex (Mutex).
GPU-Related Objects#
Some members methods interact with Graphics API, which is available only in the main loop. Once you need to call a gpu-related function, you have to pass the object to the main loop and perform calling in it.
The Rendering-Related Classes (e.g. MeshDynamic) should be considered as gpu-related.
Also, the Object-Related Classes have rendering-related methods, such as render() and other ones.
Note that rendering-related methods should be called only from Render/Viewport::callback functions (see an example of creating a Render::callback function).
Below you'll find the source code of the dynamic_03 default sample which demonstrates how to create a dynamic mesh by using the Marching cubes algorithm performed asynchronously.
dynamic_03.usc
#include <core/scripts/samples.h>
#include <samples/objects/dynamic_01.h>
Async async_0;
Async async_1;
int size = 32;
float field_0[size * size * size];
float field_1[size * size * size];
int flags_0[size * size * size];
int flags_1[size * size * size];
ObjectMeshDynamic mesh_0;
ObjectMeshDynamic mesh_1;
using Unigine::Samples;
string mesh_material_names[] = ( "objects_mesh_red", "objects_mesh_green", "objects_mesh_blue", "objects_mesh_orange", "objects_mesh_yellow" );
string get_mesh_material(int material) {
	return mesh_material_names[abs(material) % mesh_material_names.size()];
void update_thread() {
	while(1) {
		float time = engine.game.getTime();
		// wait async
		if(async_1 == NULL) async_1 = new Async();
		while(async_1 != NULL && async_1.isRunning()) wait;
		if(async_1 == NULL) continue;
		async_1.clearResult();
		// copy mesh
		Mesh mesh = new Mesh();
		mesh_1.getMesh(mesh);
		mesh_0.setMesh(mesh);
		mesh_0.setMaterial(get_mesh_material(1),"*");
		delete mesh;
		// wait async
		if(async_0 == NULL) async_0 = new Async();
		while(async_0 != NULL && async_0.isRunning()) wait;
		if(async_0 == NULL) continue;
		async_0.clearResult();
		// swap buffers
		field_1.swap(field_0);
		flags_1.swap(flags_0);
		// create field
		float angle = sin(time) + 3.0f;
		mat4 transform = rotateZ(time * 25.0f) * scale(vec3(5.0f / size)) * translate(vec3(-size / 2.0f));
		async_0.run(functionid(create_field),field_0.id(),flags_0.id(),size,transform,angle);
		// create mesh
		async_1.run(functionid(marching_cubes),mesh_1,field_1.id(),flags_1.id(),size);
		wait;
int init() {
	createInterface("samples/objects/dynamic_03.world");
	engine.render.loadSettings(fullPath("samples/common/world/render.render"));
	createDefaultPlayer(Vec3(30.0f,0.0f,20.0f));
	createDefaultPlane();
	mesh_0 = addToEditor(new ObjectMeshDynamic(OBJECT_DYNAMIC_ALL));
	mesh_0.setWorldTransform(Mat4(scale(vec3(16.0f / size)) * translate(-size / 2.0f,-size / 2.0f,0.0f)));
	mesh_1 = new ObjectMeshDynamic(1);
	mesh_1.setEnabled(0);
	setDescription(format("Async dynamic marching cubes on %dx%dx%d grid",size,size,size));
	thread("update_thread");
void shutdown() {
	if(async_0 != NULL) async_0.wait();
	if(async_1 != NULL) async_1.wait();
Threads in UnigineScript#
When using UnigineScript workflow, you should also keep in mind that main-loop-dependent objects must not be directly modified out of the main loop. Instead, it is suggested to create a twin for such an object which will be modyfied asynchronously and then swapped with the original object on the flush step.
Non-reentrant UnigineScript functions are not suitable for multithreaded usage. You will have to create a separate function for each thread. For that you can use Templates.
Below you'll find a UnigineScript sample on managing several mesh clusters asynchronously. You can copy and paste it to the world script file of your project.
cluster_03.usc
#include <core/unigine.h>
#define NUM_CLUSTERS 4
int size = 60;
// a class for asynchronous mesh cluster
class AsyncCluster
	Mat4 transforms[0];
	// original mesh cluster
	ObjectMeshCluster cluster;
	// a twin for async modification
	ObjectMeshCluster cluster_async;
	Async async;
AsyncCluster clusters[NUM_CLUSTERS];
string mesh_material_names[] = ( "stress_mesh_red", "stress_mesh_green", "stress_mesh_blue", "stress_mesh_orange", "stress_mesh_yellow" );
// a template to generate a function transforming a cluster in each thread
template async_transforms<NUM, OFFSET_X, OFFSET_Y> void async_transforms_ ## NUM(ObjectMeshCluster cluster_async, float transforms[], float time, int size) {
	Vec3 offset = Vec3(OFFSET_X - 0.5f, OFFSET_Y - 0.5f, 0.0f) * (size + 0.5f) * 2;
	int num = 0;
	for(int y = -size; y <= size; y++) {
		for(int x = -size; x <= size; x++) {
			float rand = sin(frac(num * 0.333f) + x * y * (NUM + 1));
			Vec3 pos = (Vec3(x, y, sin(time * rand * 2.0f) + 1.5f) + offset) * 2.0f;
			transforms[num] = translate(pos) * rotateZ(time * 25 * rand);
			num++;
	cluster_async.createMeshes(transforms);
async_transforms<0,0,0>;
async_transforms<1,0,1>;
async_transforms<2,1,0>;
async_transforms<3,1,1>;
	while(1) {
		// wait async
		for(int i = 0; i < NUM_CLUSTERS; i++) {
			while(clusters[i].async.isRunning())
				wait;
			AsyncCluster c = clusters[i];
			c.async.clearResult();
			c.cluster.swap(c.cluster_async);
			c.cluster.setEnabled(1);
			c.cluster_async.setEnabled(0);
			c.async.run("async_transforms_" + i, c.cluster_async, c.transforms.id(), engine.game.getTime(), size);
		wait;
int init() {
	// create scene
	PlayerSpectator player = new PlayerSpectator();
	player.setPosition(Vec3(30.0f,0.0f,20.0f));
	player.setDirection(vec3(-1.0f, 0.0f, -0.5f));
		AsyncCluster c = new AsyncCluster();
		c.cluster = new ObjectMeshCluster(fullPath("samples/common/meshes/box.mesh"));
		c.cluster.setMaterial(get_mesh_material(i),"*");
		c.cluster_async = class_append(node_cast(c.cluster.clone()));
		c.async = new Async();
		int num = pow(size * 2 + 1, 2);
		c.transforms.resize(num);
		clusters[i] = c;
	int num = pow(size * 2 + 1, 2) * NUM_CLUSTERS;
	log.message("ObjectMeshCluster with %d dynamic instances",num);
void shutdown() {
		clusters[i].async.wait();
Last update: 2020-04-10
