Playing Sounds on Collisions
The example below demonstrates how to:
- Create a new sound source.
- Update settings of the existing sound source.
- Implement a contact callback that plays a sound at a contact with a physical body.
The sound file used in the example can be found in the <UnigineSDK>/data/samples/sounds/sounds folder. You can also specify any other file, including .mp3.
AppWorldLogic.h:
#ifndef __APP_WORLD_LOGIC_H__
#define __APP_WORLD_LOGIC_H__
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UniginePhysics.h>
#include <UnigineMesh.h>
#include <UnigineSounds.h>
#include <UnigineObjects.h>
#include <UnigineEditor.h>
AppWorldLogic();
virtual ~AppWorldLogic();
virtual int init();
virtual int update();
virtual int postUpdate();
virtual int updatePhysics();
virtual int shutdown();
// callbacks
struct ContactArguments
Unigine::BodyPtr body;
int num;
ContactArguments(const Unigine::BodyPtr &body, int num)
this->body = body;
this->num = num;
Unigine::Vector<ContactArguments> callbacks;
Unigine::Vector<Unigine::SoundSourcePtr> sounds;
void contact_callback(Unigine::BodyPtr body, int num);
void contact_callback_handler(const Unigine::BodyPtr &body, int num);
void create_box(Unigine::Math::Vec3 position);
AppWorldLogic.cpp:
#include "AppWorldLogic.h"
// a callback function that will be run when a contact with a given body emerges
void AppWorldLogic::contact_callback(BodyPtr body, int num)
ContactArguments ca = ContactArguments(body, num);
callbacks.append(ca);
void AppWorldLogic::contact_callback_handler(const BodyPtr &body, int num)
if (num >= body->getNumContacts())
return;
// get coordinates of the contact point
Vec3 position = body->getContactPoint(num);
// get the relative impulse in the contact point
float impulse = body->getContactImpulse(num);
// calculate volume of the sound played for the contact
float volume = impulse * 0.5f - 1.0f;
// a flag indicating that no sounds have played yet
bool need_sound = true;
for (int i = 0; i < sounds.size(); i++)
if (!sounds[i]->isPlaying())
need_sound = false;
// reuse the existing sound source
sounds[i]->setEnabled(1);
sounds[i]->setGain(saturate(volume));
sounds[i]->setWorldTransform(translate(position));
Sound::renderWorld(1);
sounds[i]->play();
break;
if (need_sound)
// create a new sound source
SoundSourcePtr s = SoundSource::create("static_impact_00.wav");
// specify necessary settings for the sound source
s->setOcclusion(0);
s->setMinDistance(10.0f);
s->setMaxDistance(100.0f);
s->setGain(saturate(volume));
s->setWorldTransform(translate(position));
// play the sound source
s->play();
// append the sound to the vector of the playing sounds
sounds.append(s);
// method creating a box mesh with a physical body
void AppWorldLogic::create_box(Vec3 position)
mesh->addBoxSurface("box_0", vec3(0.5f));
ObjectMeshStaticPtr object_mesh = ObjectMeshStatic::create(mesh);
object_mesh->setWorldTransform(translate(position));
object_mesh->setCollision(1, 0);
BodyRigidPtr body = BodyRigid::create(object_mesh);
ShapeBox::create(body, vec3(0.5f));
// set a callback function that is run when a contact with the box occurs
body->addContactEnterCallback(MakeCallback(this, &AppWorldLogic::contact_callback));
int AppWorldLogic::init() {
// create box meshes
for (int i = -5; i <= 5; i++) {
AppWorldLogic::create_box(Vec3(0.0f, i * 2.0f, 8.0f + i * 1.0f));
// create another box mesh
AppWorldLogic::create_box(Vec3(5.0f, 10.0f, 50.0f));
sounds.clear();
callbacks.clear();
int AppWorldLogic::update() {
if (callbacks.size() > 0)
for (int i = 0; i > callbacks.size(); i++)
contact_callback_handler(callbacks[i].body, callbacks[i].num);
//delete callbacks[i];
callbacks.clear();
int AppWorldLogic::postUpdate() {
int AppWorldLogic::updatePhysics() {
sounds[i].clear();
sounds.clear();
UNIGINE_UNUSED(stream);
