系统选单
The System Menu window is displayed only when Wall, Projection, or Syncker plugin is loaded and contains settings for these plugins. It can be opened by pressing Esc.System Menu 窗口仅在加载 Wall, Projection 或 Syncker 插件时显示,并包含这些插件的设置。可以按 Esc 键打开。
The System Menu is available only when the UnigineEditor isn't loaded.只有未加载UnigineEditor时,系统菜单才可用。
SynckerSyncker#
System Menu window for Syncker pluginSyncker 插件的 System Menu 窗口
This window is available if the Syncker plugin is used.如果使用 Syncker 插件,则此窗口可用。
- Show debug info — shows debug information on the master and slaves. It includes the number of synchronized nodes and materials, a name of the view, the number of connected slaves (on the master computer), and others.Show debug info——显示有关主站和从站的调试信息。它包括同步节点和资料的数量,视图的名称,已连接的从属设备(在主计算机上)的数量等。
- Show debug window — opens the debug window that allows monitoring the objects hierarchy at run time.Show debug window——打开允许在运行时监视对象层次结构的调试窗口。
- Show projection configuration — enables the projection setup mode.Show projection configuration——启用投影设置模式。
Wall & ProjectionWall & Projection#
System Menu window for Wall/Projection pluginWall/Projection 插件的 System Menu 窗口
This window is available if the Wall or Projection plugin is used. The settings are described here.如果使用了 Wall 或 Projection 插件,则可以使用此窗口。这里描述了设置。
To open the Projection Configurator, click Projection. This option is available only for projects with the Projection plugin loaded.要打开Projection Configurator,请单击Projection。此选项仅适用于加载了Projection插件的项目。
最新更新:
2022-11-28
