渲染设置
The Render section of the Settings window allows adjusting the rendering settings of the world. It has a set of sub-sections given below. Settings窗口的Render部分允许调整世界的渲染设置。 以下是一组子节。
- Screen — screen settings such as VR emulation and stereo modes, virtual resolution, border, etc. Screen-屏幕设置,例如VR仿真和立体声模式,虚拟分辨率,边框等。
- Visibility Distances — settings related to visibility distances for shadows, reflections, and various types of objects. Visibility Distances —与阴影,反射和各种对象的可见距离有关的设置。
- Antialiasing-抗锯齿设置:时间抗锯齿(TAA),快速近似抗锯齿(FXAA)和超采样。
- Textures — texture-related settings, such as quality, resolution, filtering options, etc. Textures-与纹理相关的设置,例如质量,分辨率,过滤选项等。
- Lights — lights-related settings, such as lens flares effect, batching parameters as well as per-object limits for forward rendering pass. Lights —与灯光有关的设置,例如镜头光晕效果,批处理参数以及前向渲染过程的每个对象限制。
- Transparent — settings related to rendering of transparent materials. Transparent-与渲染透明材质有关的设置。
- Shadows — settings of the scene shadows. Shadows-场景阴影的设置。
- Global Illumination — the settings of the global illumination including SSAO (screen-space ambient occlusion), SSGI (screen-space global illumination) and bent normals. Global Illumination —全局照明的设置,包括SSAO(屏幕空间周围光遮挡),SSGI(屏幕空间全局照明)和弯曲法线。
- SSS — settings of the subsurface scattering. SSS-地下散射的设置。
- SSR — settings of the screen-space reflections (SSR). SSR-屏幕空间反射(SSR)的设置。
- Decals — decals-related settings. Decals-与贴花相关的设置。
- SSBevel — settings of the screen-space bevel effect (SSBevel). SSBevel-屏幕空间斜角效果(SSBevel)的设置。
- SSDirt — settings of the screen-space dirt effect (SSDirt). SSDirt-屏幕空间污垢效果(SSDirt)的设置。
- Terrain — terrain rendering settings. Terrain-地形渲染设置。
- Water — water rendering settings. Water-水渲染设置。
- Clouds — clouds rendering settings. Clouds-云渲染设置。
- Vegetation — vegetation animation parameters applied across the whole world. Vegetation —应用于整个世界的植被动画参数。
- Environment — settings controlling environment of the scene (scattering, haze, etc.). Environment —设置控制场景环境(散射,雾度等)。
- Occlusion Culling — settings related to occlusion culling. Occlusion Culling-与遮挡剔除有关的设置。
- Camera Effects — settings of the camera (Motion Blur, DOF, etc.). Camera Effects-摄像机的设置。
- Color — scene color correction settings. Color —场景颜色校正设置。
- Buffers — additional buffer settings. Buffers-其他缓冲区设置。
- Streaming — settings related to resource streaming. Streaming —与资源流有关的设置。
最新更新:
2022-10-10
