Handling Contacts on Collision
Sometimes you may need to implement your own contact handler for colliding physical bodies. In this example, you will learn how to visualize contact points, display debug information, and add a hit effect (sparks) at the point of impact.
Preparing the content#
To create sparks, we are going to use the VFX add-on (you can install it via the Add-Ons section of UNIGINE SDK Browser).
Create a new project in UNIGINE SDK Browser with the VFX add-on included.
Open the project in the UnigineEditor and add some primitive objects to the default scene.
Let’s get some information about the contacts the blue box will have with other objects.
Making the Objects Collidable#
The objects in the scene are dynamic ones, so to be able to collide they need a body and a collision shape. Add a Rigid body and a shape to each object via the Physics tab of the Parameters window.
Collisions are available for static objects as well (like buildings or ground) - simply enable the Collision option for the corresponding surface.
Enabling High Priority Contacts#
On collision, contacts are distributed randomly between the interacting bodies to optimize performance: some are handled by the first body, others by the second. For a body, contacts that it handles itself are internal (access to them is fast), and contacts handled by other bodies are external.
You can iterate through all contacts for a body, but for better performance it is recommended to process only internal ones.
The box is a high-priority body for us and we want to track its collisions with maximum efficiency. We can make the box handle most of its contacts itself (so that most of them are internal). To do so, select the box and check High Priority Contacts in the Physics tab (or do it via code).
Creating a Hit Effect Node#
We will use a Particle System to create a node that simulates sparks.
  1. In the UnigineEditor, click Create -> Particle System -> Particles. Place the object somewhere in the world, rename it to sparks, and adjust its parameters:
    • Number Per Spawn = 10
    • Radius = 0.02
    • Life Time = 0.2
    • Period = inf
    • Duration = 0
  2. In the Surface Material section, assign library_spark1.mat material (it is located in the data -> vfx -> materials -> library_vfx folder of your project).
  3. Switch to the data folder in the Asset Browser. Right-click the sparks node and select Create a Node Reference. A sparks.node file will be generated in the data folder.
  4. Delete the sparks object from the scene, we no longer need it since it will be loaded via code.
Algorithm Description#
The algorithm we are going to use can be described as follows:
  1. We create three variables (lastContactTime, lastContactPoint, lastContactInfo) to keep the time and position of the last occurred contact and some info about it.
  2. We add a callback to be fired when each contact emerges. This function (OnContactEnter()) takes the body and the index of the contact.
  3. If the contact is internal, we save its time and position.
  4. We get both physical bodies participating in this contact (body0, body1). We check if our box has hit another physical object.
    • If any of body0 and body1 exists (and it is not the body of our box), then we have found this object. We get details about this body and render it in the viewport using Visualizer.
    • Otherwise, the box has hit some static object (a surface with Collision enabled). We make this surface highlighted in the viewport as well.
  5. We add details we are interested in (e.g., the contact impulse).
  6. We spawn a hit effect if the impulse is strong enough. Physics callbacks are called in the main thread, so it is safe to create nodes inside the OnContactEnter() function.
  7. Finally, in the Update() method we display the info and create a slow motion effect for one second.
Component Code#
Let's use the C++ Component System to implement this logic. We will create a C++ component and assign it to the box node.
  1. Open your project in an IDE.
    It is recommended to use Visual Studio as a default IDE.
  2. In the IDE create a new C++ class (*.h and *.cpp files) and call it ContactsHandler. Make sure it inherits from the Unigine::ComponentBase class.
  3. Copy the code below, paste it to the corresponding files in your project and save them in your IDE.
    ContactsHandler.h (C++)
    #pragma once
    #include <UnigineGame.h>
    #include <time.h>
    class ContactsHandler :
    	public  Unigine::ComponentBase
    	COMPONENT_DEFINE(ContactsHandler, ComponentBase)
    		COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	// A node that will be loaded on contact (a hit effect)
    	PROP_PARAM(File, hitEffect);
    	bool debug = true;
    protected:
    	void init();
    	void update();
    	void OnContactEnter(Unigine::BodyPtr, int);
    	// Time, position and some info of the last occurred contact
    	time_t lastContactTime;
    	Unigine::Math::vec3 lastContactPoint;
    	Unigine::String lastContactInfo;
    ContactsHandler.cpp (C++)
    #include "ContactsHandler.h"
    #include <UnigineNode.h>
    REGISTER_COMPONENT(ContactsHandler);
    void ContactsHandler::init()
    	BodyPtr body = node->getObjectBody();
    	if (body)
    		// For debug purposes, we can render certain contacts depending on their type
    		body->addContactsCallback(MakeCallback([](BodyPtr b) {b->renderInternalContacts(); }));
    		// A callback to be fired when each contact emerges
    		body->addContactEnterCallback(MakeCallback(this, &ContactsHandler::OnContactEnter));
    // This function takes the body and the index of the contact
    void ContactsHandler::OnContactEnter(Unigine::BodyPtr body, int num)
    	// Enable Visualizer to see the rendered contact points
    	Visualizer::setEnabled(true);
    	if (body->isContactInternal(num))
    		if (debug)
    			// The time of the contact
    			lastContactTime = time(NULL);
    			// The position of the contact
    			lastContactPoint = body->getContactPoint(num);
    			// We get both physical bodies participating in this contact
    			BodyPtr body0 = body->getContactBody0(num);
    			BodyPtr body1 = body->getContactBody1(num);
    			BodyPtr touchedBody = NULL;
    			// We check if our object has hit another physical object.
    			// If any of the bodies exists and it's not the body of our object
    			// then we have found another physics-driven object that hit it
    			if (body0 && body0 != body) touchedBody = body0;
    			if (body1 && body1 != body) touchedBody = body1;
    			if (touchedBody)
    				// Our object has touched a physics-driven object.
    				// We save the info about the body
    				lastContactInfo = String::format("body %s of object %s ", touchedBody->getName(), touchedBody->getObject()->getName());
    				// Render it in the viewport
    				Visualizer::renderObject(touchedBody->getObject(), Math::vec4_blue, 0.5f);
    			else
    				// It has touched a surface with Collision enabled
    				lastContactInfo = String::format("surface #%d of object %s", body->getContactSurface(num), body->getContactObject(num)->getName());
    				// Highlighting the surface
    				Visualizer::renderObjectSurface(body->getContactObject(num), body->getContactSurface(num), Math::vec4_blue, 0.5f);
    			// You can add details you are interested in (e.g., the contact impulse)
    			lastContactInfo += String::format("\nimpulse: %f", body->getContactImpulse(num));
    		// We spawn a hit effect if the impulse is strong enough
    		if (body->getContactImpulse(num) > 0.3f && hitEffect)
    			NodePtr Effect = World::loadNode(hitEffect);
    			Effect->setPosition(Vec3(body->getContactPoint(num)));
    void ContactsHandler::update()
    	// Here we can display the info and create a slow motion effect for one second
    	if (debug)
    		if (int(time(NULL) - lastContactTime) < 1.0f)
    			// Slow motion effect
    			Game::setScale(0.3f);
    			Visualizer::renderMessage3D(lastContactPoint, Math::vec3_one, ("last contact: \n" + lastContactInfo).get(), Math::vec4_green, 2, 24);
    		else  // All the other time the speed will be normal
    			Game::setScale(1.0f);
  4. Before you can use C++ components, you should initialize the Component System. Modify the init() method of the AppSystemLogic class as shown below (AppSystemLogic.cpp file).
    AppSystemLogic.cpp (C++)
    int AppSystemLogic::init()
  5. Build and run the project via your IDE (press Ctrl + F5 in Visual Studio). The Component System will generate a property file (ContactsHandler.prop) in the data -> ComponentSystem folder of your project.
Applying Logic to the Object#
Switch back to the UnigineEditor and select the box node. Click Add New Property in the Parameters window and assign the newly generated ContactsHandler property. Specify the sparks.node asset to be loaded and spawned on collision.
You might need to increase the physics FPS and the number of iterations for better quality during slowdown. You can do this in the Settings tab of the UnigineEditor.
Click Run to see the result. As the box is rolling around, the physics-driven objects and collidable surfaces it hits along the way are highlighted, and contact details are displayed near the contact point. Whenever a collision occurs, it triggers an asset spawning and a slow motion effect.
All manipulations with physical bodies should belong to the UpdatePhysics() method.
This is how you can easily track collisions and run necessary logic on time: spawn particles, play sounds, and destroy fracture objects.
Last update: 2022-10-10
