Application with OpenGL via OpenTK Library
This article describes the sample located in the <UnigineSDK>/source/csharp/apps/main_winform/GLOpenTKAppForm/ folder.
The sample demonstrates how to embed Unigine into a Windows Forms application:
  • Create a Windows Forms application and embed Unigine into it.
  • Initialize OpenGL by using OpenTK library.
The sample can be run on Windows only.
Running Sample#
To run the sample, you should do the following:
  1. Prepare the development environment:
    Microsoft .NET 6 or higher is required.
    OpenTK library will be installed automatically when you install UNIGINE SDK.
  2. Open the Visual C# main_x64.csproj project file located in the <UnigineSDK>/source/csharp/apps/main_winform/GLOpenTKAppForm/ folder.
  3. Click the button on the toolbar (or DEBUG -> Start Debugging) to start the project.
    Windows Form Application will open.
Description of C# classes#
This sample contains 4 classes:
  • AppForm — inherits the Unigine.App class. In this class thedoUpdate(), doRender() anddoSwap() functions are overridden and call the update(), render() andswap() functions respectively.
  • AppFormControl — inherits the System.Windows.Forms.Form class. This class implements all the necessary events, which will be performed when user interacts with the application.
  • GLTKAppForm — inherits the AppForm class and initializes the graphics OpenGL API in the Windows Forms Application via the OpenTK library.
  • UnigineApp — defines the entry point of the program. C# Wrapper and Engine are initialized here.
AppForm, AppFormControl, GLTKAppForm are defined in the Unigine namespace.
Last update: 2022-10-10
