创建C#应用程序
A Unigine-based application can be implemented by means of C# only, without using UnigineScript. This article describes how to create a new Unigine-based C# application on Windows platform.基于Unigine的应用程序只能通过C#来实现,而无需使用UnigineScript。本文介绍如何在Windows平台上创建一个新的基于Unigine的C#应用程序。
Implementation by using the C# language is very similar to C++. Read the Creating C++ Application article to get basic principles.使用C#语言的实现与C ++非常相似。阅读创建C ++应用程序文章以获取基本原理。
See Also也可以看看#
- Examples located in the <UnigineSDK>/source/csharp/samples/Api and <UnigineSDK>/source/csharp/samples/App folders.示例位于<UnigineSDK>/source/csharp/samples/Api和<UnigineSDK>/source/csharp/samples/App文件夹中。
- The article on Setting Up Development Environment to learn more on how to prepare the development environment.设置开发环境上的文章,以了解有关如何准备开发环境的更多信息。
Creating Empty C# Application创建空的C#应用程序#
It is very easy to start your own C# project by using UNIGINE SDK Browser:使用UNIGINE SDK浏览器来启动自己的C#项目非常容易:
- Open the UNIGINE SDK Browser.打开UNIGINE SDK浏览器。
- Go to the Projects tab and click CREATE NEW.
转到Projects选项卡,然后单击CREATE NEW。
- Specify the following parameters:
- Project name — specify the name of your project.Project name — specify the name of your project.
- Location — specify the path to your project folder.Location — specify the path to your project folder.
- SDK — choose the Unigine SDK.SDK — choose the Unigine SDK.
- API+IDE — choose C# (.NET).API+IDE — choose C# (.NET).
- Precision — specify the precision. In this example we will use double precision.Precision — specify the precision. In this example we will use double precision.
注意Project name — specify the name of your project.Location — specify the path to your project folder.SDK — choose the Unigine SDK.API+IDE — choose C# (.NET).Precision — specify the precision. In this example we will use double precision.Read more about these parameters in this article.指定以下参数:Read more about these parameters in this article.Read more about these parameters in this article.
- Project name — specify the name of your project.Project name-指定项目的名称。
- Location — specify the path to your project folder.Location-指定项目文件夹的路径。
- SDK — choose the Unigine SDK.SDK —选择Unigine SDK。
- API+IDE — choose C# (.NET).API+IDE — 选择 C# (.NET)。
- Precision — specify the precision. In this example we will use double precision.Precision-指定精度。在此示例中,我们将使用双精度。
注意Read more about these parameters in this article.在本文中阅读有关这些参数的更多信息。 - Click the Create New Project button. The project will appear in the projects list.
单击Create New Project按钮。该项目将出现在项目列表中。
You can run your project by clicking the Run button.您可以通过单击Run按钮来运行项目。
Implementing C# Logic实施C#逻辑#
可以使用以下任一API来实现C#逻辑:
In this section we will add logic to the empty C# application project and rotate the material ball that is created by default.在本节中,我们将向空的C#应用程序项目中添加逻辑,并旋转默认情况下创建的物料球。
- In UNIGINE SDK Browser, choose your C# project created with the C# (.NET) option selected as API+IDE, and click the Open Editor button.
在UNIGINE SDK浏览器中,选择使用C# (.NET)选项作为API + IDE选择创建的C#项目,然后单击打开编辑器按钮。
- In UnigineEditor, create a new C# component via Asset Browser.
Let's name it rotator. 在UnigineEditor中,通过Asset Browser创建一个新的C#组件。
我们将其命名为rotator。 - By double-clicking a created asset rotator.cs, it will open in the default IDE. Add the following code to this file.
源代码 (C#)All saved changes of the component source code make the component update with no compilation required when the Editor window gets focus. 双击创建的资产rotator.cs,它将在默认IDE中打开。将以下代码添加到该文件。
public class rotator : Component { public float angle = 30.0f; void Update() { // write here code to be called before updating each render frame node.Rotate(0, 0, angle * Game.IFps); } }
源代码 (C#)编辑器窗口获得焦点时,所有已保存的组件源代码更改都将使组件更新,而无需编译。public class rotator : Component { public float angle = 30.0f; void Update() { // write here code to be called before updating each render frame node.Rotate(0, 0, angle * Game.IFps); } }
- Add this component to the material ball.将此组件添加到material ball。
- Run an instance of the application by clicking the Play button on the toolbar.
通过单击工具栏上的“播放”按钮来运行该应用程序的实例。
The component can be assigned to any node or nodes without changing anything in it.可以将组件分配给任何一个或多个节点,而无需更改其中的任何内容。
