Water
Water Settings
SSR Enabled | Enables or disables the SSR (Screen Space Reflections) effect for water. |
SSR Quality | Quality of the water screen-space reflections:
SSR Increased Accuracy | Enables or disables increased accuracy for the water SSR (Screen Space Reflections). This option reduces visual artifacts by increasing accuracy of the last step. |
Refraction Quality | Quality of water refraction.
Anisotropy Quality | Water texture anisotropy level.
Shoreline Wetness | Enables or disables the wetness effect for objects near the shoreline. |
Render Underwater Shafts | Enables or disables rendering of underwater shafts. |
Render Environment Probes | Enables or disables rendering of environment probes on the water surface. |
Render Lights | Enables or disables rendering of lights on the water surface. |
Field Height Precision | This parameter determines the resolution of the texture into which all textures set for all FieldHeight objects are rendered. The following values are available:
Notice Increased resolution significantly affects performance. |
Field Precision 32 bits | Enables 32-bit precision for of textures used for field objects. |
Field Shoreline Precision | This parameter determines the resolution of the texture into which all textures set for all FieldShoreline objects are rendered. The following values are available:
Last update: 2018-06-04
