Surface-based collision using collision masks
This example shows how to enable collision detection for a surface using bitmasks. Two boxes (orange and yellow), each with a body and a box shape assigned, and a blue plane are created. We want the yellow box to collide with the surface of the blue plane and the orange box to pass through. So we set the following collision masks for the shapes of the boxes and for the surface of the plane.
Element | Mask |
Yellow box: shape | 0010 |
Orange box: shape | 0001 |
Plane: surface | 0010 |
Surface-to-surface collisions cannot be enabled using collision masks.
// AppWorldLogic.h
#include <UnigineObjects.h>
Unigine::ObjectMeshStaticPtr box1;
Unigine::ObjectMeshStaticPtr box2;
Unigine::ObjectMeshStaticPtr plane;
#include "AppWorldLogic.h"
#include "UnigineGame.h"
#include "UnigineObjects.h"
/// function, creating a named box of a specified size and color at pos
ObjectMeshStaticPtr create_box(char *name, const vec4& color, const vec3& size, const vec3& pos)
// creating an auxiliary mesh with a box surface
MeshPtr meshbox = Mesh::create();
meshbox->addBoxSurface("box_surface", size);
// creating a static mesh object using an auxiliary mesh and setting parameters
ObjectMeshStaticPtr OM = ObjectMeshStatic::create(meshbox);
OM->setMaterial("mesh_base", "*");
OM->setMaterialParameter("albedo_color", color, 0);
OM->setProperty("surface_base", "*");
OM->setName(name);
// assigning a rigid body with our object
BodyRigid::create(OM->getObject());
// creating a box shape and assigning it to the rigid body of our object
OM->getBody()->addShape(ShapeBox::create(size)->getShape(), translate(0.0f, 0.0f, 0.0f));
// clearing the auxiliary mesh
meshbox->clear();
return OM;
/// function, creating a named plane having a specified width and height at pos
ObjectMeshStaticPtr create_plane(char *name, float width, float height, const vec3& pos)
// creating an auxiliary mesh with a plane surface
MeshPtr meshplane = Mesh::create();
meshplane->addPlaneSurface("plane_surface", width, height, 1.0f);
ObjectMeshStaticPtr OM = ObjectMeshStatic::create(meshplane);
OM->setMaterialParameter("albedo_color", vec4(0.0f, 0.0f, 1.0f, 1.0f), 0);
OM->setName(name);
meshplane->clear();
return OM;
int AppWorldLogic::init()
// setting up a player
PlayerSpectatorPtr player = PlayerSpectator::create();
player->setPosition(Vec3(0.0f, -6.0f, 12.5f));
player->release();
// creating a scene: two boxes and a plane
box1 = create_box("box1", vec4(1.0f, 1.0f, 0.0f, 1.0f), vec3(0.5f), vec3(1.5f, 0.0f, 12.0f));
box2 = create_box("box2", vec4(1.0f, 0.5f, 0.1f, 1.0f), vec3(0.5f), vec3(-1.5f, 0.0f, 12.0f));
plane = create_plane("plane", 10.0f, 6.0f, vec3(0.0f, 1.0f, 10.5f));
// setting shape collision mask for the first box [00000000000000000000000000000010]
box1->getBody()->getShape(0)->setCollisionMask(2);
// setting shape collision mask for the second box [00000000000000000000000000000001]
box2->getBody()->getShape(0)->setCollisionMask(1);
// setting collision mask for the plane surface [00000000000000000000000000000010]
plane->setCollisionMask(2, 0);
Last update: 2018-06-04
