Rebuild Qt Libraries
You can re-build the Unigine Qt libraries but it's not recommended for the Qt components to work properly.
In the Unigine SDK Qt version 5.4.1 is used.
Build Qt for Windows
Preparation
  • Build ICU libraries:
    1. Install cygwin
    2. Download ICU source code
    3. Build ICU with the following batch script, changing %CYGWIN_PATH% variable with the path where cygwin installed
      Shell commands
      set PATH=%CYGWIN_PATH%\bin;%PATH%
      call %VS120COMNTOOLS%vsvars32.bat
      :: for x64 build use:
      :: call %VS120COMNTOOLS%..\..\VC\bin\x86_amd64\vcvarsx86_amd64.bat
      cd icu/source
      bash runConfigureICU Cygwin/MSVC --enable-static --disable-shared
      nmake
      nmake install
  • Build OpenSSL libraries:
    1. Install perl
    2. Download OpenSSL v1.0.2 source code
    3. Build OpenSSL for x86, changing %PERL_PATH% variable with the path where perl installed
      Shell commands
      set PATH=%PERL_PATH%\bin;%PATH%
      cd openssl-1.0.2
      call perl Configure VC-WIN32 no-shared no-asm
      call ms\do_ms
      nmake -f ms\nt.mak
      nmake -f ms\nt.mak install
    4. For building OpenSSL 64-bit version use the following script
      Shell commands
      cd openssl-1.0.2
      call perl Configure VC-WIN64A no-shared no-asm
      call ms\do_win64a
      nmake -f ms\nt.mak
Build
Download sources of Qt modules and unpack them
qtbase-opensource-src-5.4.1.zip
qttools-opensource-src-5.4.1.zip
qtwebkit-opensource-src-5.4.1.zip
  • Build Qt base libraries with the script, setting variables %ICU_PATH% and %OPENSSL_PATH% before
    Shell commands
    set QMAKESPEC=win32-msvc2013
    set PREFIX=%~dp0
    set LIBDIR=%~dp0\lib
    set INFIX=Unigine_x86
    set PATH=%ICU_PATH%\bin;%PATH%
    set INCLUDE=%ICU_PATH%\include;%INCLUDE%
    set LIB=%ICU_PATH%\lib;%LIB%
    set INCLUDE=%OPENSSL_PATH%\include;%INCLUDE%
    set LIB=%OPENSSL_PATH%\lib;%LIB%
    cd qtbase-opensource-src-5.4.1
    call configure.exe -prefix %PREFIX% -libdir %LIBDIR% -plugindir %LIBDIR% -qtlibinfix %INFIX% -release -opensource -confirm-license ^
    	-no-sql-mysql -no-sql-psql -no-sql-oci -no-sql-odbc -no-sql-tds -no-sql-db2 -qt-sql-sqlite -no-sql-sqlite2 -no-sql-ibase ^
    	-no-plugin-manifests -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -no-avx -no-avx2 ^
    	-no-ltcg -no-nis -no-iconv -no-evdev -no-mtdev -no-inotify -no-fontconfig ^
    	-qt-zlib -icu -no-gif -qt-libpng -qt-libjpeg -qt-freetype -no-harfbuzz -no-angle ^
    	-openssl-linked -no-dbus -no-audio-backend -no-wmf-backend -no-qml-debug -no-directwrite -no-direct2d ^
    	-qt-style-windowsvista -no-style-windowsce -no-style-windowsmobile ^
    	-no-native-gestures -no-mp -opengl desktop ^
    	-nomake examples -nomake tests
    nmake
    nmake install
  • Build Qt UiTools library with previously built qmake tool
    Shell commands
    cd qttools-opensource-src-5.4.1\src\designer\src
    qmake
    nmake
    nmake install
  • Build Qt WebKit libraries.
    1. Install ruby
    2. Install GNUWin32
    3. Install SQLite. For SQLite, download the 'amalgamation' sources and make sure you set SQLITE3SRCDIR environment variable to the directory containing the source files. (You could also set %SQLITE3SRCDIR% to the sources in your Qt's base source directory src/3rdparty/sqlite)
    4. Build QtWebKit and QtWebKitWidgets libraries with the following batch script, changing variables with the real pathes
      Shell commands
      set PATH=%RUBY_PATH%\bin;%PATH%
      set PATH=%GNUWIN32_PATH%\bin;%PATH%
      set SQLITE3SRCDIR=%SQLITE_PATH%
      cd qtwebkit-opensource-src-5.4.1
      call perl Tools\Scripts\build-webkit --qt --release --minimal
      cd WebKitBuild\Release
      call nmake install
Build Qt for Linux
Preparation
    1. Download ICU source code
    2. Unpack and build ICU with the following shell script
      Shell commands
      cd icu/source
      ./configure --enable-static --disable-shared
      make
      make install
  • Build OpenSSL 1.0.2 libraries:
    1. Download OpenSSL v1.0.2 source code
    2. Unpack and build
      Shell commands
      cd openssl-1.0.2
      ./config no-shared -fPIC
      make
      make install
Build
qtbase-opensource-src-5.4.1.tar.gz
qttools-opensource-src-5.4.1.tar.gz
qtwebkit-opensource-src-5.4.1.tar.gz
    Shell commands
    PREFIX=../
    LIBDIR=../lib
    INFIX=Unigine_x64
    cd ./qtbase-opensource-src-5.4.1
    ./configure -verbose -prefix $PREFIX -libdir $LIBDIR -plugindir $LIBDIR -qtlibinfix $INFIX -release -opensource -confirm-license \
    	-I$PWD/../icu/include -I$PWD/../openssl/include -L$PWD/../icu/lib -L$PWD/../openssl/lib -ldl \
    	-no-sql-db2 -no-sql-ibase -no-sql-mysql -no-sql-oci -no-sql-odbc -no-sql-psql -qt-sql-sqlite -no-sql-sqlite2 -no-sql-tds \
    	-no-qml-debug -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -no-avx -no-avx2 \
    	-qt-zlib -no-mtdev -no-gif -qt-libpng -qt-libjpeg -qt-freetype -no-harfbuzz -openssl-linked \
    	-qt-pcre -no-xinput2 -no-glib -no-pulseaudio -no-alsa -no-gtkstyle \
    	-no-nis -no-cups -no-iconv -no-evdev -icu -fontconfig -no-pch -no-dbus \
    	-qt-xcb -no-eglfs -no-directfb -no-linuxfb -no-kms \
    	-qpa xcb -opengl desktop \
    make -j 8
    make install
    Shell commands
    qmake
    make
    make install
  • Build Qt WebKit libraries with the script included:
    Shell commands
    ./Tools/Scripts/build-webkit --qt --release --minimal --makeargs="-j8"
    cd ./WebKitBuild/Release
    make install
  • After build is successful, run the next script from the directory with Qt libraries:
    Shell commands
    MAJOR=5
    MINOR=4
    VER=1
    for i in *.la *.prl *_x64.so *_x64.so.$MAJOR.$MINOR; do
    	rm $i
    done
    for i in *_x64.so.$MAJOR.$MINOR.$VER; do
    	mv $i ${i/so.$MAJOR.$MINOR.$VER/so.$MAJOR}
    done
    for i in *_x64.so.$MAJOR; do
    	ln -s $i ${i/so.$MAJOR/so}
    done
Build Qt for Mac OS X
Preparation
    2. Unpack and build
      Shell commands
      cd openssl-1.0.2
      ./Configure darwin64-x86_64-cc no-shared
      make
      make install
Build
    Shell commands
    PREFIX=../
    LIBDIR=../lib
    INFIX=Unigine_x64
    cd ./qtbase-opensource-src-$VERSION
    	-no-nis -no-cups -no-iconv -no-evdev -no-icu -fontconfig -no-pch -no-dbus \
    	-no-xcb -no-eglfs -no-directfb -no-linuxfb -no-kms \
    	-qpa cocoa -opengl desktop -no-framework \
    make -j 8
    make install
    Shell commands
    cd qttools-opensource-src-$VERSION\src\designer\src
    qmake
    make
    make install
  • Build Qt WebKit libraries with the script included.
    Shell commands
    make install
  • After build is successful, run the next script in the directory with Qt libraries:
    Shell commands
    PREFIX=$PWD
    NAMES=''
    MAJOR=5
    MINOR=4
    VER=1
    for i in *.la *.prl *_x64.dylib *_x64.$MAJOR.$MINOR.dylib; do
    	rm $i
    done
    for i in *_x64.$MAJOR.$MINOR.$VER.dylib; do
    	mv $i ${i/$MAJOR.$MINOR.$VER.dylib/$MAJOR.dylib}
    done
    for i in *_x64.$MAJOR.dylib; do
    	ln -s $i ${i/$MAJOR.dylib/dylib}
    done
    for i in *.$MAJOR.dylib; do
    	install_name_tool -id @rpath/$i $i
    	for j in *.$MAJOR.dylib; do
    		install_name_tool -change $PREFIX/$j @rpath/$j $i
    	done
    	NAMES="$NAMES $i"
    done
    cd ./platforms
    for i in *.dylib; do
    	for j in $NAMES; do
    	done
    done
