SSR
The tab contains settings that control screen-space reflections (SSR).
Screen-space reflections settings
Resolution Specifies the resolution of the SSR:
  • Quad — 1/4 resolution
  • Half — 1/2 resolution
  • Full — full resolution
Can be controlled by render_ssr_resolution console command.
Normal threshold Limits blur of screen space reflections (calculation of SSR roughness) by normals.
Can be controlled by render_ssr_normal_threshold console command.
Depth threshold Limits blur of screen space reflections (calculation of SSR roughness) by depth.
Can be controlled by render_ssr_depth_threshold console command.
Roughness quality Specifies the current quality of screen space reflections roughness:
  • Low — low quality
  • Medium — medium quality
  • High — high quality
  • Ultra — ultra quality
Can be controlled by render_ssr_roughness_quality console command.
Scale Controls the scale of the SSR within [0;10] range.
Can be controlled by render_ssr_scale console command.
Stretching Controls the stretching factor of the SSR within [0;10] range.
Can be controlled by render_ssr_stretching console command.
Near Enables screen space reflections calculation for the near view.
Can be controlled by render_ssr_near console command.
Near quality Specifies the quality of screen space reflections rendered at the near view.
  • Low — low quality
Can be controlled by render_ssr_near_quality console command.
Near distance scale Specifies the scale of the rendering distance of the near view for SSR.
Can be controlled by render_ssr_near_distance_scale console command.
Far Enables screen space reflections calculation for the far view.
Can be controlled by render_ssr_far console command.
Far quality Specifies the quality of screen space reflections rendered at the far view.
  • Low — low quality
Can be controlled by render_ssr_far_quality console command.
Far distance scale Specifies the scale of the rendering distance of the far view for SSR.
Can be controlled by render_ssr_far_distance_scale console command.
