Unigine::World Class
Header:#include <UnigineWorld.h>
This class provides functionality for the world script. It contains methods required for loading the world with all its nodes, managing a spatial tree and handling nodes collisions and intersections.
World Class
Members
World * get()
Returns a pointer to the World instance.
Return value
Pointer to World.
Ptr<Node> getAsyncNode(int id)
Gets the loaded node. If the loaded node consists of multiple objects, a new dummy object is created to combine them and its smart pointer is returned.
Arguments
  • int id - Loading operation identifier.
Return value
Returns the loaded node smart pointer, if found; otherwise, 0.
int getAsyncNodes(int id, Vector< Ptr<Node> > & nodes)
Gets an array of the loaded nodes. If the loaded node consists of multiple objects, they are put into the array.
Arguments
  • Vector< Ptr<Node> > & nodes - Array of loaded nodes' smart pointers.
Return value
1 if the operation is successful; otherwise, 0.
void setBudget(float budget)
Sets the world generation budget value for Grass and Clutter objects. New objects are not created when time is out of the budget.
Arguments
  • float budget - The budget value in seconds.
float getBudget()
Returns the value of the world generation budget for Grass and Clutter objects. New objects are not created when time is out of the budget.
Return value
The budget value in seconds. The default value is 1/60.
int getCollision(const UNIGINE_BOUND_BOX & bb, Vector< Ptr<Object> > & objects)
Searches for all collider objects within a given bounding box.
Arguments
  • const UNIGINE_BOUND_BOX & bb - Bounding box.
  • Vector< Ptr<Object> > & objects - Array with collider objects' smart pointers.
Return value
1 if the collider objects are found; otherwise, 0.
int getCollision(const UNIGINE_BOUND_SPHERE & bs, Vector< Ptr<Object> > & objects)
Arguments
  • const UNIGINE_BOUND_SPHERE & bs - Bounding box.
Return value
int getCollision(const Math::Vec3 & p0, const Math::Vec3 & p1, Vector< Ptr<Object> > & objects)
Arguments
  • const Math::Vec3 & p0 - The start point coordinates.
  • const Math::Vec3 & p1 - The end point coordinates.
Return value
void setData(const char * data)
Sets user data associated with the world. In the *.world file, the data is set in the data tag.
Arguments
  • const char * data - New user data.
const char * getData()
Returns user string data associated with the world. This string is written directly into the data tag of the *.world file.
Return value
User string data.
void setDistance(float distance)
Updates the distance, at which (and farther) nothing will be rendered or simulated.
Arguments
  • float distance - New distance in units.
float getDistance()
Returns a distance, at which (and farther) nothing will be rendered or simulated.
Return value
Distance in units.
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Vector< Ptr<Node> > & exclude, Math::Vec3 * ret_point, Math::vec3 * ret_normal, Math::vec4 * ret_texcoord, int * ret_index, int * ret_surface)
Searches for intersections with nodes that are found in a given bounding box.
Arguments
  • const Math::Vec3 & p0 - Coordinates of the line start point.
  • const Math::Vec3 & p1 - Coordinates of the line end point.
  • int mask - Intersection mask. If 0 is passed, the function will return NULL.
  • const Vector< Ptr<Node> > & exclude - The list of objects to exclude.
  • Math::Vec3 * ret_point - Intersection point of the line and object.
  • Math::vec3 * ret_normal - Normal vector to the intersection point.
  • Math::vec4 * ret_texcoord - Texture coordinates of the intersection point (vec4, where vec4.xy is for the first (0) UV channel, vec4.zw is for the second (1) UV channel).
  • int * ret_index - Intersected triangle (polygon) number.
  • int * ret_surface - Intersected surface number.
Return value
1 if intersections are found; otherwise, 0.
int getIntersection(const UNIGINE_BOUND_FRUSTUM & bf, Vector< Ptr<Object> > & objects)
Arguments
  • const UNIGINE_BOUND_FRUSTUM & bf - Bounding box.
  • Vector< Ptr<Object> > & objects - Array with intersected nodes' smart pointers.
Return value
int getIntersection(const UNIGINE_BOUND_SPHERE & bs, Vector< Ptr<Node> > & nodes)
Arguments
  • Vector< Ptr<Node> > & nodes - Array with intersected nodes' smart pointers.
Return value
int getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, Vector< Ptr<Object> > & objects)
Arguments
  • Vector< Ptr<Object> > & objects - Array of intersected nodes' smart pointers.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, Math::Vec3 * ret_point, Math::vec3 * ret_normal, Math::vec4 * ret_texcoord, int * ret_index, int * ret_surface)
Arguments
Return value
int getIntersection(const UNIGINE_BOUND_SPHERE & bs, int type, Vector< Ptr<Node> > & nodes)
Arguments
  • int type - Node type filter. Only the nodes of the specified type is checked.
  • Vector< Ptr<Node> > & nodes - Array of intersected nodes' smart pointers.
Return value
int getIntersection(const UNIGINE_BOUND_BOX & bb, int type, Vector< Ptr<Node> > & nodes)
Arguments
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Ptr<WorldIntersectionTexCoord> & v)
Arguments
  • int mask - An intersection mask.
  • const Ptr<WorldIntersectionTexCoord> & v - The list of objects IDs to exclude.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Vector< Ptr<Node> > & exclude, const Ptr<WorldIntersection> & v)
Arguments
  • const Vector< Ptr<Node> > & exclude - The list of objects IDs to exclude.
  • const Ptr<WorldIntersection> & v - The variable.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Ptr<WorldIntersection> & v)
Arguments
  • const Ptr<WorldIntersection> & v - The list of objects IDs to exclude.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Vector< Ptr<Node> > & exclude, const Ptr<WorldIntersectionTexCoord> & v)
Arguments
  • const Ptr<WorldIntersectionTexCoord> & v - The variable.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Ptr<WorldIntersectionNormal> & v)
Arguments
  • const Ptr<WorldIntersectionNormal> & v - The list of objects IDs to exclude.
Return value
Ptr<Object> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, int mask, const Vector< Ptr<Node> > & exclude, const Ptr<WorldIntersectionNormal> & v)
Arguments
  • const Ptr<WorldIntersectionNormal> & v - The variable.
Return value
int getIntersection(const UNIGINE_BOUND_FRUSTUM & bf, int type, Vector< Ptr<Node> > & nodes)
Arguments
Return value
int getIntersection(const UNIGINE_BOUND_BOX & bb, Vector< Ptr<Object> > & objects)
Arguments
Return value
int getIntersection(const UNIGINE_BOUND_SPHERE & bs, Vector< Ptr<Object> > & objects)
Arguments
Return value
int getIntersection(const UNIGINE_BOUND_BOX & bb, Vector< Ptr<Node> > & nodes)
Arguments
Return value
int isLoaded()
Returns a value indicating if the current world is fully loaded.
Return value
1 if the world is loaded; otherwise, 0.
void setName(const char * name)
Sets a new name for the world.
Arguments
  • const char * name - Name of the world.
const char * getName()
Returns the name of the currently loaded world. (If a path was specified in the name, the returned string will contain both the world name and a path).
Return value
Name of the world.
Ptr<Node> getNode(int id)
Returns a node by its ID. This can be any node: either created dynamically in run-time or loaded from the *.world file.
Arguments
  • int id - Node ID.
Return value
Node smart pointer if the node with the specified ID exists; otherwise, NULL.
int isNode(int id)
Checks if a node with a given ID exists in the world.
Arguments
  • int id - Node ID.
Return value
1 if the node with the given ID exists; otherwise, 0.
void getNodes(Vector< Ptr<Node> > & nodes)
Gets all of the nodes (either loaded from the *.world file or created dynamically in run-time).
Arguments
  • Vector< Ptr<Node> > & nodes - Return array with node smart pointers.
int getNumQueuedNodes()
Returns the number of queued nodes waiting for the background loading. The return value also includes the currently processed node. To add node for the background loading, use the loadAsyncNode() function.
Return value
Number of queued nodes including the currently processed node.
int getNumQueuedResources()
Returns the number of queued resources waiting for the background loading. The return value also includes the currently processed node.
Return value
Number of queued resources including the currently processed resource.
int getNumUpdateNodes()
Returns the number of currently updating nodes in the world.
Return value
Number of updating nodes.
float getTotalTime()
Returns the total time (in milliseconds) of loading a resource.
Return value
The total time value, milliseconds.
Ptr<Node> getUpdateNode(int num)
Returns an updated node by its ID.
Arguments
  • int num - Node ID.
Return value
The node smart pointer, if found; otherwise - 0.
void addUpdateNode(const Ptr<Node> & node)
Adds a node that should be updated even if it is outside of the viewing frustum. This function should be called every frame.
Arguments
  • const Ptr<Node> & node - Node to be updated.
void addUpdateNodes(const Vector< Ptr<Node> > & nodes)
Adds a node array that should be updated even if the nodes are outside of the viewing frustum. This function should be called every frame.
Arguments
  • const Vector< Ptr<Node> > & nodes - Nodes array to be updated.
int addWorld(const char * name)
Loads a world from a file and adds it to the current world.
Arguments
Return value
1 if the world is loaded and added successfully; otherwise, 0.
int checkAsyncNode(int id)
Returns a value indicating if the node is in the loading queue or already loaded.
Arguments
Return value
1 if the node is in queue or already loaded; otherwise, 0.
int clearNode(const char * name)
Clears a cache of a given node.
Arguments
  • const char * name - Path to the *.node file.
Return value
1 if the cache is cleared successfully; otherwise, 0.
int forceAsyncNode(int id)
Forces the node loading. The specified node gets the higher priority and will be loaded first.
Arguments
Return value
1 if the node is loaded successfully; otherwise, 0.
int loadAsyncNode(const char * name, int group = 0, float weight = 0.0f)
Loads the node with the specified group and priority to the thread.
Arguments
  • const char * name - Node name.
  • int group - Number of a node group.
  • float weight - Node priority.
Return value
Returns the loading operation identifier.
Ptr<Node> loadNode(const char * name, int cache = 1, int is_world = 0)
Loads a node from a file. If the node is loaded successfully, it does not belong to any node hierarchy or list, so be careful and make sure to handle it properly, when it is no longer needed.
Arguments
  • int cache - 1 to use the file cache, 0 not to use.
  • int is_world - If set to 1, the material library of the node is loaded as a world library (i.e. is specified in the *.world file and is automatically loaded on the world initialization).
Return value
Loaded node; 0 if the node cannot be loaded.
int loadNodes(const char * name, Vector< Ptr<Node> > & nodes)
Loads nodes from a file.
Arguments
  • Vector< Ptr<Node> > & nodes - Array of nodes' smart pointers to which the loaded nodes are appended.
Return value
1 if the nodes are loaded successfully; otherwise, 0.
int removeAsyncNode(int id)
Removes node from the loading queue.
Arguments
Return value
1 if the node is removed successfully; otherwise, 0.
int saveNode(const char * name, const Ptr<Node> & node, int materials = 1, int binary = 0)
Saves a given node into a file.
Arguments
  • const Ptr<Node> & node - Pointer to the node to save.
  • int materials - If the node has the materials assigned, and this flag is set to 1, the corresponding material libraries will be also listed in the *.world file.
  • int binary - If set to 1, the node is saved to the binary *.xml. This file cannot be read, but using it speeds up the saving of the node and requires less disk space.
Return value
1 if the node is saved successfully; otherwise, 0.
int saveNodes(const char * name, const Vector< Ptr<Node> > & nodes, int materials = 1, int binary = 0)
Saves nodes into a file.
Arguments
  • const Vector< Ptr<Node> > & nodes - Array of nodes' smart pointers to be saved.
Return value
1 if the nodes are saved successfully; otherwise, 0.
void updateSpatial()
Updates the BSP tree. This function is automatically called each frame. This function is called manually if a new object was added through the script and it needs to participate in spatial intersection during one and the same frame. Or if you have moved the node, and then want to get callbacks on basis of changed position in the same frame.
You may want to call updateSpatial() before: You can call updateSpatial() several times during one frame, but do not use it once too many times. It is more rational to change position of all required nodes first and only after that call updateSpatial().
