engine.world Functions
This class provides functionality for the world script. It contains methods required for loading the world with all its nodes, managing a spatial tree and handling nodes collisions and intersections.
World Class
Members
Node engine.world.getAsyncNode(int id)
Gets the loaded node. If the loaded node consists of multiple objects, a new dummy object to combine them is created and its smart pointer is returned.Arguments
- int id - The loading operation identifier.
Return value
The loaded node smart pointer, if found; otherwise - 0.void engine.world.setBudget(float budget)
Sets the world generation budget value for Grass and Clutter objects. New objects are not created when time is out of the budget.Arguments
- float budget - The budget value in seconds. The default value is 1/60.
float engine.world.getBudget()
Returns the value of the world generation budget for Grass and Clutter objects. New objects are not created when time is out of the budget.Return value
The budget value in seconds.void engine.world.setData(string data)
Sets user data associated with the world. In the *.world file, the data is set in the data tag.Arguments
- string data - New user data.
string engine.world.getData()
Returns user string data associated with the world. This string is written directly into the data tag of the *.world file.Return value
User string data.void engine.world.setDistance(float distance)
Updates the distance, at which (and farther) nothing will be rendered or simulated.Arguments
- float distance - New distance in units.
float engine.world.getDistance()
Returns a distance, at which (and farther) nothing will be rendered or simulated.Return value
Distance in units.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, Vector<Node> exclude, Vec3 * ret_point, vec3 * ret_normal, vec4 * ret_texcoord, int * ret_index, int * ret_surface)
Performs tracing from the p0 point to the p1 point to find the list of objects intersecting the line. This function detects intersection with surfaces (polygons) of mesh and terrain objects. An intersection is found only if an object is matching the intersection mask.
Intersections with the surface can be found only if the following conditions are fulfilled:
- A per-surface Intersection flag is enabled.
- An Intersection option of the property in the Properties window is enabled.
- A surface is enabled.
- A surface has an assigned material.
- A surface has an assigned property.
Depending on the variable passed as an argument, the result will be presented as following:
- WorldIntersection intersection - The WorldIntersection class instance.
- WorldIntersectionNormal normal - The WorldIntersectionNormal class instance.
- WorldIntersectionTexCoord texcoord - The WorldIntersectionTexCoord class instance.
Arguments
- Vec3 p0 - The start point coordinates.
- Vec3 p1 - The end point coordinates.
- int mask - An intersection mask.
NoticeIf 0 is passed, the function will return NULL.
- Vector<Node> exclude - The list of objects IDs to exclude.
- Vec3 * ret_point - The variable.
- vec3 * ret_normal - Normal vector to the intersection point.
- vec4 * ret_texcoord - Texture coordinates of the intersection point (vec4, where vec4.xy is for the first (0) UV channel, vec4.zw is for the second (1) UV channel).
- int * ret_index - Intersected triangle (polygon) number.
- int * ret_surface - Intersected surface number.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundFrustum bf, Vector<Object> & objects)
- WorldIntersection intersection — The WorldIntersection class instance.
- WorldIntersectionNormal normal — The WorldIntersectionNormal class instance.
- WorldIntersectionTexCoord texcoord — The WorldIntersectionTexCoord class instance.
Arguments
- WorldBoundFrustum bf - The start point coordinates.
- Vector<Object> & objects - The end point coordinates.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundSphere bs, Vector<Node> & nodes)
Arguments
- WorldBoundSphere bs - The start point coordinates.
- Vector<Node> & nodes - The end point coordinates.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(Vec3 p0, Vec3 p1, Vector<Object> & objects)
Arguments
- Vector<Object> & objects - An intersection mask.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, Vec3 * ret_point, vec3 * ret_normal, vec4 * ret_texcoord, int * ret_index, int * ret_surface)
Arguments
- Vec3 * ret_point - The list of objects IDs to exclude.
- vec3 * ret_normal - The variable.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundSphere bs, int type, Vector<Node> & nodes)
Arguments
- int type - The end point coordinates.
- Vector<Node> & nodes - An intersection mask.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundBox bb, int type, Vector<Node> & nodes)
Arguments
- WorldBoundBox bb - The start point coordinates.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, WorldIntersectionTexCoord v)
Arguments
- WorldIntersectionTexCoord v - The list of objects IDs to exclude.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, Vector<Node> exclude, WorldIntersection v)
Arguments
- WorldIntersection v - The variable.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, WorldIntersection v)
Arguments
- WorldIntersection v - The list of objects IDs to exclude.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, Vector<Node> exclude, WorldIntersectionTexCoord v)
Arguments
- WorldIntersectionTexCoord v - The variable.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, WorldIntersectionNormal v)
Arguments
- WorldIntersectionNormal v - The list of objects IDs to exclude.
Return value
The reference to the first intersected object, if found; otherwise - 0.Object engine.world.getIntersection(Vec3 p0, Vec3 p1, int mask, Vector<Node> exclude, WorldIntersectionNormal v)
Arguments
- WorldIntersectionNormal v - The variable.
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundFrustum bf, int type, Vector<Node> & nodes)
Arguments
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundBox bb, Vector<Object> & objects)
Arguments
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundSphere bs, Vector<Object> & objects)
Arguments
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.getIntersection(WorldBoundBox bb, Vector<Node> & nodes)
Arguments
Return value
The reference to the first intersected object, if found; otherwise - 0.int engine.world.isLoaded()
Returns a value indicating if the current world is fully loaded.Return value
1 if the world is loaded; otherwise, 0.void engine.world.setName(string name)
Assigns a new name to an editable world.Arguments
- string name - Name of the world.
string engine.world.getName()
Returns the name of the currently loaded world. (If a path was specified in the name, the returned string will contain both the world name and a path).Return value
Name of the current world.Node engine.world.getNode(int id)
Returns a node by its ID. This can be any node: either created in scripts or loaded from the *.world file.Arguments
- int id - Node ID.
Return value
Requested node, if found (NULL otherwise).int engine.world.isNode(int id)
Checks if a node with a given ID exists in the world.Arguments
- int id - Node ID.
Return value
1 if the node with the given ID exists; otherwise, 0.void engine.world.getNodes(Vector<Node> & nodes)
Gets all of the nodes (either loaded from the *.world file or created dynamically in run-time).Arguments
- Vector<Node> & nodes - Return array with node smart pointers.
int engine.world.getNumQueuedNodes()
Returns the number of queued nodes waiting for the background loading. The return value also includes the currently processed node. To add node for the background loading, use the loadAsyncNode() function.Return value
Number of queued nodes including the currently processed node.int engine.world.getNumQueuedResources()
Returns the number of queued resources waiting for the background loading. The return value also includes the currently processed node.Return value
Number of queued resources including the currently processed resource.int engine.world.getNumUpdateNodes()
Returns the number of currently updating nodes in the world.Return value
Number of updating nodes.float engine.world.getTotalTime()
Returns the total time (in milliseconds) of loading a resource.Return value
The total time value, milliseconds.Node engine.world.getUpdateNode(int num)
Returns an updated node by its ID.Arguments
- int num - Node ID.
Return value
The node smart pointer, if found; otherwise - 0.void engine.world.addUpdateNode(Node node)
Adds a node that should be updated even if it is outside of the viewing frustum. This function should be called every frame.Arguments
- Node node - Node to be updated.
int engine.world.addWorld(string name)
Loads a world from a file and adds it to the current world.Arguments
- string name - Name of the file describing the world.
Return value
1 if the world is loaded and added successfully; otherwise, 0.int engine.world.checkAsyncNode(int id)
Checks if the node is in the loading queue or already loaded.Arguments
Return value
1 if the node is in the loading queue or already loaded; otherwise, 0.int engine.world.clearNode(string name)
Clears a cache of the given NodeReference.Arguments
- string name - File with the node.
Return value
1 if the cache was successfully cleaned; otherwise, 0.int engine.world.forceAsyncNode(int id)
Forces the loading of the node (the specified node gets the higher priority and will be loaded first).Arguments
Return value
1 if the node is successfully loaded; otherwise, 0.int engine.world.loadAsyncNode(string name, int group = 0, float weight = 0.0f)
Loads the node with the specified group and priority to the thread.Arguments
- string name - The name of the node.
- int group - The number of the node group.
- float weight - The priority of the node.
Return value
The loading operation identifier.int engine.world.removeAsyncNode(int id)
Removes the node from the loading queue.Arguments
Return value
1 if the node is successfully removed; otherwise, 0.int engine.world.saveNode(string name, Node node, int materials = 1, int binary = 0)
Saves a given node into a file.Arguments
- string name - Path to the *.node file.
- Node node - Pointer to the node to save.
- int materials - If the node has the materials assigned, and this flag is set to 1, the corresponding material libraries will be also listed in the *.world file.
- int binary - If set to 1, the node is saved to the binary *.xml. This file cannot be read, but using it speeds up the saving of the node and requires less disk space.
Return value
1 if the node is saved successfully; otherwise, 0.int engine.world.saveNodes(string name, Node[] nodes, int materials = 1, int binary = 0)
Saves nodes into a file.Arguments
- Node[] nodes - Array of nodes' smart pointers to be saved.
Return value
1 if the nodes are saved successfully; otherwise, 0.void engine.world.updateSpatial()
Updates the BSP tree. This function is automatically called each frame. This function is called manually if a new object was added through the script and it needs to participate in spatial intersection during one and the same frame. Or if you have moved the node, and then want to get callbacks on basis of changed position in the same frame.You may want to call updateSpatial() before:
- getIntersection
- getCollision
- getting callbacks from the WorldTrigger
- getting callbacks from the PhysicalTrigger
