Playing Sounds on Collisions
The example below demonstrates how to:
- Create a new sound source.
- Update settings of the existing sound source.
- Implement a contact callback that plays a sound at a contact with a physical body.
The sound file used in the example can be found in the <UnigineSDK>/data/samples/sounds/sounds folder. You can also specify any other file, including .mp3.
#include <core/unigine.h>
SoundSource sounds[0];
void contact_callback(Body body,int num)
if (num >= body.getNumContacts())
return;
// get coordinates of the contact point
Vec3 position = body.getContactPoint(num);
// get the relative impulse in the contact point
float impulse = body.getContactImpulse(num);
// calculate volume of the sound played for the contact
float volume = impulse * 0.5f - 1.0f;
// a flag indicating that no sounds have played yet
int need_sound = 1;
for (int i = 0; i < sounds.size(); i++)
if (sounds[i].isPlaying() == 0)
need_sound = 0;
// reuse the existing sound source
sounds[i].setEnabled(1);
sounds[i].setGain(saturate(volume));
sounds[i].setWorldTransform(translate(position));
engine.sound.renderWorld(1);
sounds[i].play();
break;
if (need_sound)
// create a new sound source
SoundSource s = new SoundSource("static_impact_00.wav");
// specify necessary settings for the sound source
s.setOcclusion(0);
s.setMinDistance(10.0f);
s.setMaxDistance(100.0f);
s.setGain(saturate(volume));
s.setWorldTransform(translate(position));
// play the sound source
s.play();
// append the sound to the vector of the playing sounds
sounds.append(s);
// method creating a box mesh with a physical body
void create_box(Vec3 position)
Mesh mesh = new Mesh();
mesh.addBoxSurface("box_0",vec3(0.5f));
ObjectMeshStatic object = node_remove(new ObjectMeshStatic(mesh));
engine.editor.addNode(object);
object.setWorldTransform(translate(position));
object.setMaterial("mesh_base","*");
object.setProperty("surface_base","*");
BodyRigid body = class_remove(new BodyRigid(object));
class_remove(new ShapeBox(body,vec3(0.5f)));
// set a callback function that is run when a contact with the box occurs
body.setContactCallback(functionid(contact_callback));
int init() {
Player player = new PlayerSpectator();
player.setPosition(Vec3(0.0f,-3.401f,1.5f));
player.setDirection(Vec3(0.0f,1.0f,-0.4f));
// create box meshes
for(int i = -5; i <= 5; i++)
create_box(Vec3(0.0f,i * 2.0f,8.0f + i * 1.0f));
// create another box mesh
create_box(Vec3(0.0f,0.0f,50.0f));
int update() {
foreach(SoundSource s; sounds)
if(!s.isPlaying()) s.setEnabled(0);
int render() {
int flush() {
int shutdown() {
Last update: 2018-08-10
