Fundamentials
Core Library
Engine Classes
Bounds-Related Classes
Utility Classes
Sector
A sector is a cuboid shaped object that culls all of the objects outside its volume. Sectors usage is very convenient for designing of indoor spaces. Sectors are connected by portals.
Creating a Sector
To create a sector, choose the Add World Sector option in the list of nodes of Editor panel. In the opened creation dialog window specify initial parameters:
A Creation Window
Size The size of the sector's bounding box along the X, Y and Z axes, in units.
After the initial parameters are set, click Ok and place the sector somewhere in the world.
Editing a Sector
In the Sector tab you can adjust the following parameters of the sector:
A Sector tab
Bounding Box Parameters
Last update: 03.07.2017
