Occluder Mesh
An occluder mesh is an occluder which is based on an arbitrary mesh. The occluder mesh is used to cull objects' surfaces, bounds of which are not visible behind it. The surfaces behind the occluder are not sent to the GPU, thereby saving performance.
- General information on occluders
- A WorldOccluderMesh class to edit mesh occluders via UnigineScript
- A data/samples/worlds/occluder_01 sample
Creating Occluder Mesh
Before adding an occluder mesh to a scene, you should prepare a mesh, on which this occluder mesh will be based. Such mesh is created separately and should be as simple as possible: it should contain the minimum number of polygons.
When the mesh is prepared, you can add the occluder mesh to the scene via UnigineEditor:
- Run UnigineEditor.
- On the Menu bar, click Create -> Worlds -> Occluder Mesh.
- In the file dialog window, choose a mesh (*.mesh) on which the occluder will be based.
- Place the occluder mesh in the world and specify the required parameters for it.
Example
For example, if you have a building that occludes some objects' surfaces, you should prepare a simplified mesh to be used as a base for the occluder mesh instead of using the detailed mesh.
The mesh that represents the building and contains a lot of details |
The occluder that is based on the simplified mesh and is rendered into the separate buffer in the low resolution |
Editing Occluder Mesh
On the Occluder tab of the Nodes panel, you can adjust the following parameters of the occluder mesh:
Distance | Distance between the camera and the bounding box of the occluder, at which the occluder mesh becomes disabled. For example, you should disable the occluder at a certain distance if it stops hiding the objects and their surfaces in order to increase performance. By default, the inf value is used. |
Loading a New Mesh
To load a new mesh on which the occluder will be based:
- On the Occluder tab, press .
- In the file dialog window that opens, choose the required mesh and press Ok.
Saving the Current Mesh
To save the current mesh on which the occluder is based:
- In the file dialog window that opens, specify a name for the mesh and press Ok.
