volume_cloud_base
A volume_cloud_base material is used to create clouds or shaped fog. It is applied to Volume boxes.
Volume cloud material
States
In the States tab you can set rendering passes and available options. Enabling some of the states activates additional textures and parameters in the Textures and Parameters tabs respectively.
For this material the states contain only Options field.
Possible values for a Samplesoption:
GUI name XML name Description
16 16 A density texture is sampled to render a cloud 16 times.
32 32 A density texture is sampled to render a cloud 32 times.
64 64 A density texture is sampled to render a cloud 64 times.
128 128 A density texture is sampled to render a cloud 128 times.
256 256 A density texture is sampled to render a cloud 256 times.
All the other options can be either enabled or disabled by ticking the respective boxes.
All the states can be set to default ones - click a Set to parent button near the state (if the state is different from the default one, its field will be highlighted with green).
The states available for this kind of materials are listed below.
Options
The following options are set in the Options field of the States tab.
Samples samples Defines how many times a density texture is sampled to render a cloud.
The higher the value, the smoother and less discrete the cloud is. To increase the performance, use low Samples values.
Low value of samples Hogh value of samples
Samples = 32
Samples = 128
Attenuation attenuation Specifies if the attenuation texture will be used to override transparency values with the texture color for the cloud.
Volume volume Specifies if adensity texture is a 3D texture (rather than a 2D one).
In the Textures tab of the Materials Editor you can:
  • Load the textures - click a Load button near the texture and specify the path to the texture or type the path in the texture field manually
  • Open the view window to see texture's details - click a View button near the texture
  • Set the current texture to default one - click a Set to parent button near the texture (if the texture is different from the default one, its field will be highlighted with green)
The textures available for this kind of materials are listed below.
Base Textures
Base textures are loaded and modified in the Base field of the Textures tab.
GUI name XML name Description Channels
Density density Specifies the shape of the cloud and its density:
  • 3D Texture is used by default (if the Volumeoption enabled in theStates tab). It represents a set of vertical cross-sections of the cloud.
  • 2D Texture is used if the Volumeoption in theStates tab is disabled. It represents one horizontal cross-section of the cloud.
RG:
  1. If Attenuationoption is disabled in theStates tab:
    • R value specifies the actual grayscale color
    • G value is used for transparency (alpha) values:
      • 0 is full transparency
      • 1 is full opacity
  2. If Attenuationoption is enabled in theStates tab: :
    • R value specifies the U coordinate of the attenuation texture:
      • The minimum value of 0 means U coordinate value is 0
      • The maximum value of 255 means a U coordinate value is 1
        U coordinate of the attenuation texture.
    • G value is ignored. Alpha values are specified in the attenuation texture instead
Attenuation attenuation Attenuation map. A texture to add the color to the cloud ans specify its transparency. RGBA:
  • RGB values store the color of the texture
  • A (alpha) value stores transparency values. G channel values of the density texture are ignored
Grayscale attenuation texture Colored attenuation texture
Parameters
Parameters of different types are set in different ways:
  • expression - vector values can be set either in the field near the parameter or in the dialog window opened when double clicking this field
  • slider - the value can be set either by smoothly moving the slider of the scroll box or manually in the box near the parameter (if required, the value bigger than maximum one for the slider can be set)
  • color - the color can be chosen in the dialog window, activated after double clicking the color field
All the parameters can be set to default ones - click a Set to parent button near the parameter (if the parameter is different from the default one, its field will be highlighted with green).
The parameters available for this kind of materials are listed below.
Transform Parameters
Texture transformation parameters are modified in the Transform field of the Parameters tab. Detail materials transformation parameters are present only if the Detailoption is enabled.
GUI name XML name Type Description
Attenuation attenuation_transform expression V coordinate of the attenuation texture coordinates transformation. Attenuation coordinates
V coordinate of the attenuation texture.
Scale base_scale expression Coordinate transformation of the density texture.
Cloud scale of 1 Cloud scale of 4
Scale = (1, 1, 1)
Scale = (2, 2, 1)
Offset base_offset expression An offset of the density texture along X, Y and Z axes respectively. (For example, this option can be used to animate the cloud.)
Besides the native texture coordinates transformation, there are more options of setting texture coordinates. They are described in the Texture coordinates transformation article.
Shading Parameters
Shading parameters are modified in the Shading field of the Parameters tab.
Diffuse diffuse_color color
A color picker to choose the color of the diffuse map.
Density Parameters
Density parameters are modified in the Density field of the Parameters tab.
Multiplier volume_density slider A coefficient to scale the density of the cloud. The density value multiplies the value of the G channel of the density texture.
By the minimum value of 0, the cloud is not rendered at all.
The higher the value, the bigger and darker cloud is (if a default texture is used).
