Unigine::Game Class
Header:#include <UnigineGame.h>
Provides access to Unigine game functions. Game class contains functions to control the game logic of the application.
Game Class
Members
Game * get()
void setData(const char * data)
Sets user data associated with the world. In the *.world file, the data is set in the data tag.
Arguments
  • const char * data - User data. Data can contain an XML formatted string.
const char * getData()
Returns user string data associated with the world. This string is written directly into the data tag of the *.world file.
Return value
User string data.
void setEnabled(int enabled)
Pauses or resumes the current game.
Arguments
  • int enabled - 1 to resume the game, 0 to pause it.
int isEnabled()
Returns a value indicating if the game is paused or not.
Return value
Returns 1 if the game is not paused; otherwise, 0.
void setFrame(int frame)
Sets the game frame number.
Arguments
  • int frame - Frame number.
int getFrame()
Returns the current game frame number.
Return value
Frame number.
void setFTime(float ftime)
Sets the maximum rendering frame duration value. If the real rendering FPS is higher than the fixed frame FPS, the engine will wait until the fixed frame time is over. To remove fixed frame duration, use -1.
Arguments
  • float ftime - Frame time in seconds. -1 removes the FPS limitation.
float getFTime()
Returns time spent between a previous update and a current one. This function takes time scaling into account.
Return value
void setIFps(float ifps)
Sets the inverse FPS value. This function sets a fixed FPS that does not depend on the real FPS the hardware is capable of. To remove the FPS limitation, use -1.
Arguments
  • float ifps - Inverse FPS value (1/FPS) in seconds.-1 removes the FPS limitation.
float getIFps()
Returns the scaled (see the setScale() function) inverse FPS value.
Return value
Scaled inverse FPS value (1/FPS) in seconds. If the game is paused, 0 is returned.
Ptr<Obstacle> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, float radius, int mask, const Vector< Ptr<Node> > & exclude, Math::Vec3 * intersection)
Performs intersection to find if a pathfinding Obstacle is located within the cylinder between two points. The specified obstacles will be ignored.
World space coordinates are used for this function.
Arguments
  • const Math::Vec3 & p0 - Start point.
  • const Math::Vec3 & p1 - End point.
  • float radius - Radius of the intersection cylinder.
  • int mask - Obstacle intersection mask. The obstacle is ignored if its mask does not match.
  • const Vector< Ptr<Node> > & exclude - Array with excluded obstacles. These obstacle nodes are ignored when performing intersection.
  • Math::Vec3 * intersection - Intersection point.
Return value
Intersected obstacle.
Ptr<Obstacle> getIntersection(const Math::Vec3 & p0, const Math::Vec3 & p1, float radius, int mask, const Ptr<GameIntersection> & intersection)
Performs intersection to find if a pathfinding obstacle is located within the cylinder between two points.
Arguments
  • const Ptr<GameIntersection> & intersection - GameIntersection class instance to put the result into.
Return value
float getNoise1(float pos, float size, int frequency)
Returns a noise value calculated using a Perlin noise function.
Arguments
  • float pos - Float position.
  • float size - Size of the noise.
  • int frequency - Noise frequency.
Return value
Noise value.
float getNoise2(const Math::vec2 & pos, const Math::vec2 & size, int frequency)
Returns a 2D noise value calculated using a Perlin noise function.
Arguments
  • const Math::vec2 & pos - vec2 point position.
  • const Math::vec2 & size - vec2 size of the noise.
Return value
2D noise value.
float getNoise3(const Math::vec3 & pos, const Math::vec3 & size, int frequency)
Returns a 3D noise value calculated using a Perlin noise function.
Arguments
  • const Math::vec3 & pos - vec3 point position.
  • const Math::vec3 & size - vec3 size of the noise.
Return value
3D noise value.
void setPlayer(const Ptr<Player> & player)
Sets the current game player.
Arguments
  • const Ptr<Player> & player - Game player.
Ptr<Player> getPlayer()
Returns the current player.
Return value
Current player.
unsigned int getRandom()
Returns a pseudo-random unsigned number.
Return value
Random unsigned integer number.
double getRandomDouble(double from, double to)
Returns a pseudo-random double number within a given range.
Arguments
  • double from - The initial point of the range.
  • double to
Return value
Random double integer number.
float getRandomFloat(float from, float to)
Returns a pseudo-random float number within a given range.
Arguments
  • float from - The initial point of the range.
  • float to
Return value
Random float integer number.
int getRandomInt(int from, int to)
Returns a pseudo-random integer number within a given range.
Arguments
  • int from - The initial point of the range.
  • int to - The endpoint of the range.
Return value
Random integer number.
void setScale(float scale)
Sets a value that is used to scale frame duration. It scales up or down the speed of rendering, physics and game logic. This function can be used to create effects of slow/accelerated motion.For example, if the scale equals 2, the rate of simulation of all effects (such as particles) speeds up to two times faster. This function scales both setIFps() and setFTime() functions. The default is 1.
Arguments
  • float scale - Scaling factor. The provided values is clamped within range [0;32].
float getScale()
Returns a value used to scale a frame duration.
Return value
Value to scale frame duration.
void setSeed(int seed)
Sets the seed for pseudo-random number generator.
Arguments
  • int seed - Number used to initialize a pseudo-random sequence of numbers. Non-negative value should be provided, as unsigned integer is used for it.
int getSeed()
Returns the seed for pseudo-random number generator.
Return value
void setTime(float time)
Sets a specified time value for the game. The time is counted off starting from the world loading and does not take game pauses into account.
Arguments
  • float time - Time value in seconds.
float getTime()
Returns the current time spent in the game. It is counted off starting from the world loading and does not take game pauses into account.
Return value
