grass_03
This article describes the data/samples/objects/grass_03.cpp sample.
The grass_03 sample demonstrates how to place the grass on the terrain according to a mesh mask, namely:
  • Load the terrain
  • Add the grass to the editor and make it a child node of the terrain
    It is also required to enable intersection with parent objects to make the grass grow upon the terrain.
  • Set a transformation matrix and assign a material to make the grass visible in the scene
  • Specify the required options: maximum visible and fade distances, width and height, step for cells used to render grass, density factor, etc.
  • Set the mesh-based mask to specify the areas where the grass should grow
Grass placed upon the terrain according to the mesh-based mask
In this sample, the samples/objects/meshes/grass_01.mesh planar mesh is used as the mask.
