Fundamentials
Bounds-Related Classes
Core Library
Utility Classes
cigi_client_00
This article describes the data/samples/plugins/cigi_client_00.cpp sample.
The cigi_client_00 sample demonstrates how to:
  • Initialize connection via the CIGI protocol in the script
  • Respond to packets received from the CIGI host
Start the CIGI Host before running the sample.
It is required to change values of the following variables in the cigi_client_00.cpp file before running the sample:
  • host should contain an IP address of the CIGI Host (by default it is 192.168.0.20)
  • recv should contain a port, which is used by the CIGI Host for sending packets over the network (default value is 33333)
  • send should contain a port, which is used by the CIGI Host for getting a response from the master (default value is 44444)
The variables listed above are specified in the cigi_client_00.cpp as follows:
Source code(UnigineScript)
#include <samples/plugins/common/plugins.h>
#include <samples/common/info.h>
#ifdef HAS_CIGI_CLIENT
string host = "192.168.0.20";
int send = 33333;
int recv = 44444;
int size = 1472;
Info info;
string reflect_packet(CigiHostPacket packet) {
Data sent by the CIGI host to the image generator should appear as follows:
Last update: 03.07.2017
