Sandworm (Experimental)
This example shows how to create a cloth pinned to 2 dummy bodies resting on a sphere using a particles joint.
// AppWorldLogic.h
#include <UnigineObjects.h>
// AppWorldLogic.cpp
#include "UnigineGame.h"
#include "UnigineObjects.h"
ObjectMeshDynamicPtr createSphere(char *name, float radius, const vec4& color, const vec3& pos)
	// setting parameters
	OMD->setName(name);
	return OMD;
	// creating a dummy object
	dummy->setName(name);
	BodyDummy::create(dummy);
	return dummy;
ObjectMeshDynamicPtr createBodyCloth(char *name, float width, float height, float step, float mass, float friction, float restitution, float rigidity, float lrestitution, float arestitution, int num_iterations, const vec4& color, const Mat4& tm)
	//assigning a cloth body to the dynamic mesh object and setting rope parameters
	BodyClothPtr body = BodyCloth::create(OMD);
	body->setMass(mass);
	body->setFriction(friction);
	body->setRigidity(rigidity);
	OMD->setWorldTransform(tm);
	OMD->setName(name);
	return OMD;
int AppWorldLogic::init() {
	Game::setPlayer(player);
	// creating 2 dummy bodies to attach the cloth to
Last update: 2020-11-24
