Sandworm (Experimental)
This article explains how you can rebuild the UNIGINE Engine components (samples, plugins, etc.) by using Visual Studio on the Windows platform.
Rebuilding UNIGINE Engine Components#
Customization Options#
Apart from developing your project with UnigineScript, you can also customize the UNIGINE application C++ code. What exactly is available for customization depends on the version of UNIGINE SDK:
  • With the limited binary/evaluation version you can only modify the following components:
    1. C++ plugins for the engine (in the evaluation version, some plugins cannot be rebuilt).
    2. The source code of UNIGINE-based sample applications.
    You can also modify the source code of high-level scripts: just like all other scripts, they do not require recompilation.
  • If you have the full source version, you can modify the entire UNIGINE codebase:
    1. The C++ source code of the engine itself.
    2. All UNIGINE standalone tools.
    3. C++ plugins for the engine.
    4. The source code of UNIGINE-based sample applications.
After customizing the code, recompilation of UNIGINE application or its libraries is required.
It is strongly not recommended to modify the engine source code directly, because you will need to merge your modifications each SDK update. Instead, it is better to use C++ API (including C++ plugin system) designed specifically for extending basic UNIGINE functionality.
Rebuild Engine Plugins#
To rebuild engine C++ plugins, perform one of the following: >To rebuild a plugin with Microsoft Visual Studio, do the following:
  • Open the solution of the necessary plugin to rebuild. All plugins are located in <UNIGINE_SDK>\source\plugins\.
  • Specify the solution configuration: Debug, Debug-Double, Release or Release-Double.
  • Choose Build -> Build Solution in the menu or press F7.
Rebuild Task-Specific Applications#
Some specific functionality is not supported by the main UNIGINE application. For that, you need to recompile separate applications (their binary executables).
Only one plugin from <UnigineSDK>\source\plugins\App\ can be loaded at the same time. To load another plugin, you should unload the previous one.
To rebuild athe task-specific application with Microsoft Visual Studio, do the following:
  1. Open the solution of the necessary plugin to rebuild. All plugins are located in <UNIGINE_SDK>\source\plugins\.
  2. Specify the solution configuration: Debug, Debug-Double, Release or Release-Double.
  3. Choose Build -> Build Solution in the menu or press F7.
Rebuild Sample Applications#
In UNIGINE SDK, there are included sample applications that can be modified and used as templates to create your own applications.
To rebuild UNIGINE samples, you should do the following:
  1. Open the Visual Studio project file of the sample. Samples are located in the<UnigineSDK>\source\samples\ directory.
Last update: 2020-11-24
