Volume Sphere
Volume sphere has adjustable radii along three axes, so it can take a shape of an ellipsoid. Spheres are used to create:
  • Fog haze or mist that hides objects behind it. If spheres with fog intersect, denser fog is created.
  • Spheres of light around point light sources, for example, a bulb or a candle. These spheres are visible when the light illuminates dust and other particles floating in the air. A light material is always rendered as a regular sphere.
Volume sphere with a light material
Volume sphere with a light material around light sources
Volume sphere with a fog material
Sphere Options
Radius Scale of the sphere along X, Y and Z axes respectively.
If a volume light material is assigned to a sphere, it cannot be of an ellipsoid shape. A sphere is rendered based only on the X-axis Radius value. If its radii along Y or Z axes are smaller, then the object is cut along them.
Last update: 2017-12-21
