Version Control Systems (VCS) are used to manage changes to code and data, and enable teams to coordinate their development efforts. To make tracking of changes efficient and to reduce the amount of disk space required you should know which files should be tracked by the VCS and which of them can be ignored.
Ignore List
In any project there are files and folders that should not be subject to version control. These might include files created by the compiler, *.obj, *.tlog, or maybe an output folder used to store binary executables.
The following files and folders in you project's root can be ignored, as they are generated automatically on your disk:
  • .thumbnails
  • bin
  • launch_debug.bat
  • launch_editor.bat
  • launch_release.bat
Files and Folders to Add to Version Control
The following files and folders should be subject to version control:
  • assets folder
  • data folder.
  • source folder contents except for the elements mentioned above.
    This folder is created only for projects that use C++ or C# API.
  • *.project file
Last update: 2017-12-21
