Unigine::TerrainGlobalLodHeight Class
Header:#include <UnigineObjects.h>
Inherits:TerrainGlobalLod
This class is inherited from the TerrainGlobalLod class and used to manage a single height LOD (level of detail) of the global terrain object. Height LODs are used for collision and intersection detection.
Members
Ptr<TerrainGlobalLodHeight> cast(const Ptr<TerrainGlobalLod> & terraingloballod)
Casts a TerrainGlobalLodHeight out of the TerrainGlobalLod instance.
Arguments
  • const Ptr<TerrainGlobalLod> & terraingloballod - Pointer to TerrainGlobalLod.
Return value
Pointer to TerrainGlobalLodHeight.
void setCollision(int collision)
Enables or disables collision detection for the height LOD.
Arguments
  • int collision - 1 to enable collision detection, 0 to disable it.
int isCollision()
Returns a value indicating if collision detection for the height LOD is enabled.
Return value
1 if collision detection for the height LOD is enabled; otherwise, 0.
void setCollisionMask(int mask)
Sets the collision mask for the height LOD. A collision of an object with the height LOD will be detected, if they both have matching masks.
Arguments
  • int mask - Collision mask, an integer value each bit of which is a mask.
int getCollisionMask()
Returns the current collision mask for the height LOD. A collision of an object with the height LOD will be detected, if they both have matching masks.
Return value
void setIntersection(int intersection)
Enables or disables intersection detection for the height LOD.
Arguments
  • int intersection - 1 to enable intersection detection, 0 to disable it.
int isIntersection()
Returns a value indicating if intersection detection for the height LOD is enabled.
Return value
1 if intersection detection for the height LOD is enabled; otherwise, 0.
void setIntersectionMask(int mask)
Sets the intersection mask for the height LOD. An intersection of an object with the height LOD will be detected, if they both have matching masks.
Arguments
  • int mask - Intersection mask, an integer value each bit of which is a mask.
int getIntersectionMask()
Returns the current intersection mask for the height LOD. An intersection of an object with the height LOD will be detected, if they both have matching masks.
Return value
Last update: 21.12.2017
