Sandworm (Experimental)
Unigine.NodeReference Class
Inherits: Node
A node reference is a node that refers to an external .node file on the disk, which is obtained by exporting a node from the world.
The world can contain several instances of node references referring to the same .node file.
The .node file usually contains a pre-fabricated node (or a hierarchy of nodes) with all the materials and properties that are required for its rendering. All changes that are made for the node reference via UnigineEditor are saved into this file.
When editing the node reference via the code, implement saving changes into the .node file.
The node reference should be used instead of the node if there a lot of identical objects repeated in the world: it will enable to avoid manual editing each object if you need to make the same changes in all of these objects.
A bounding box of the reference node is equal to the bounding box of its root node stored by the reference (child nodes are disregarded).
Unlike regular nodes, reference nodes are loaded into the world faster because of the internal cache usage.
An NodeReference instance is an owner of the node (or nodes) stored by the reference, so it is responsible for loading and deleting them.
Node Reference Transformations#
NodeReference transformation differs from transformation of the node (or nodes) stored by the reference. However, matrix hierarchy is used for a NodeReference. So, when moving the NodeReference, its root node stored by the reference will also move relatively to this NodeReference. At that, the local transformation matrix of the root reference node won't be changed.
  • Article on Nodes that lists the main differences between the regular nodes and reference nodes
  • Article on Node Reference
Creating a Node Reference#
To create a NodeReference, you should specify a path to the existing .node file. For example, you can export a node into a .node file and then create a NodeReference by using it:
Source code (C#)
using Unigine;
namespace UnigineApp
        public override bool Init()
            // create a mesh
            Mesh mesh = new Mesh();
            mesh.addBoxSurface("box_0", new vec3(1.0f));
            // create a dynamic mesh by using the mesh
            ObjectMeshDynamic dynamic = new ObjectMeshDynamic(mesh);
            // export the dynamic mesh into a .node file
            World.SaveNode("unigine_project/nodes/node_reference_0.node", dynamic);
            // create a node reference
            NodeReference nodeRef = new NodeReference("unigine_project/nodes/node_reference_0.node");
			return true;
Also you can cast a Node instance to the NodeReference. However, such type casting is possible only if the Node type is NODE_REFERENCE. For example:
Source code (C#)
using Unigine;
        public void nodeCast(Node node)
            // check if the node is a NodeReference
            if (node.getType() == Node.NODE_REFERENCE)
                // cast the node to the NodeReference
                NodeReference nodeRef = node as NodeReference;
                // set a name for the NodeReference
                nodeRef.SetName("NodeReference_casted");
            // create a NodeReference from the file
            NodeReference nodeRef_0 = new NodeReference("unigine_project_10/nodes/node_reference_0.node");
            // set a name
            nodeRef_0.Name = "NodeReference_0";
            // save changes into the .world file
            Console.Run("world_save");
            // get the added NodeReference as a Node
            Node node = World.GetNodeByName("NodeReference_0");
            // cast the obtained Node to a NodeReference
            nodeCast(node);
			return true;
In the result, the NodeReference_0 node will be converted to the NodeReference_casted node.
Editing a Node Reference#
Editing a NodeReference includes:
  • Changing the path to the referenced .node file.
  • Editing the node stored by the reference.
To access the node to which the NodeReference refers, use the getReference() method as follows:
Source code (C#)
using Unigine;
            // create a NodeReference instance
            NodeReference nodeRef = new NodeReference("unigine_project_10/nodes/node_reference_0.node");
            // set a name
            nodeRef.Name = "NodeReference_0";
            // get a node stored by the reference and check if it is an ObjectMeshDynamic
            if (nodeRef.GetReference().GetType() == Node.OBJECT_MESH_DYNAMIC)
                // cast the referenced node to the ObjectMeshDynamic type
                ObjectMeshDynamic dynamic = nodeRef.GetReference() as ObjectMeshDynamic;
                // set a material
                dynamic.SetMaterial("mesh_base", 0);
                // save changes on the referenced node into the .node file
                World.SaveNode(nodeRef.NodeName, dynamic);
In the result, the source .node file, to which the NodeReference refers, will be updated and the NodeReference_0 node will refer to the updated node with the material assigned.
NodeReference Class
Properties
string NodeName#
The path to the referenced *.node file.
Source code (C#)
// create an NodeReference instance
NodeReference nodeRef = new NodeReference("unigine_project/nodes/reference_0.node");
// return the path to the reference node
Log.Message("The referenced node is: {0}\n",nodeRef.getNodeName());
set
Sets a reference to a new *.node file.
Source code (C#)
// change a reference node
nodeRef.setNodeName("unigine_project/nodes/reference_1.node");
set value - Path to a *.node file.
Node Reference#
The node stored by the reference. the method should be used when you need to change the referenced node. if getReference() has returned a NodeDummy instance, it means that several nodes of the same hierarchy level has been converted into the NodeReference.
Source code (C#)
NodeReference nodeRef = new NodeReference("unigine_project/nodes/single_nref.node");
Node node = nodeRef.getReference();
// if the node is a NodeDummy
if (node.getType() == Node.NODE_DUMMY){
	// print the type name of each child node of the root node stored by the reference
	for(int i = 0; i & node.getNumChildren(); i++) {
		Log.Message("{0}: {1}\n",i,node.getChild(i).getTypeName());
Members
static NodeReference ( string name ) #
Constructor. Creates a new object that references a node from a given file.
Arguments
  • string name - Path to a *.node file.
bool CanBeReference ( string name, Node node ) #
Returns a value indicating if the hierarchy of the given node does not contain a node reference with the given name.
Arguments
  • string name - Node reference name.
  • Node node - Node to check.
Return value
1 if the hierarchy of the given node does not contain a node reference with the given name; otherwise, 0.
Node DetachReference ( ) #
Returns the node stored by the reference and releases this node of ownership so it is no longer owned and referred to by the NodeReference. The node is managed by the World.
Source code (C#)
// create a new NodeReference instance
// perform something
// get the node stored by the reference and release NodeReference ownership of the node
Node node = nodeRef.detachReference();
// destroy the NodeReference pointer as the NodeReference doesn't refer to a node any more
nodeRef.destroyPtr();
Return value
Root node of the internal hierarchy.
static int type ( ) #
Returns the type of the node.
Return value
NodeReference type identifier.
Last update: 2020-11-24
