Creating a Car with Suspension Joints
This example shows how to:
- Create a simple car with a frame and wheels attached to it using suspension joints.
- Enable car movement using joint motors.
- Use keyboard to control car movement.
The basic workflow of creating a simple car with keyboard control is as follows:
- Create car geometry: frame and wheels.
- Assign rigid bodies and collision shapes to the frame and all the wheels.
- Set up masses for the wheels and the frame.NoticeDo not use real masses (e.g. 2000 kg for the frame and 10 kg for the wheels), as joints may become unstable! It might be better to use 64 kg for the body and 25 kg for each wheel to provide realistic behavior.
- Connect the wheels to the frame using suspension joints. Set up joint parameters.
- Enable car movement using joint motors and assign movement control to corresponding keyboard keys.
The first thing we are going to address in this tutorial is the geometry of our car. We are going to create a rectangular car frame and four wheels. We are also going to add some physical parameters to the geometry. So, we need two functions:
- The first one to create a box with specified parameters representing the car frame:
/// function creating a named box having a specified size, color and transformation with a body and a shape
Object createBodyBox(string name, Vec3 size, float mass, Vec4 color, Mat4 transform)
// creating geometry and setting up its parameters (name, material and transformation)
ObjectMeshDynamic box = Unigine::createBox(size);
engine.editor.addNode(node_remove(box));
box.setWorldTransform(transform);
box.setMaterial("mesh_base", "*");
box.setMaterialParameter("albedo_color", color, 0);
box.setName(name);
BodyRigid body = class_remove(new BodyRigid(box));
ShapeBox shape = class_remove(new ShapeBox(size));
shape.setMass(mass);
body.addShape(shape, translate(0.0f, 0.0f, 0.0f));
body.setFreezable(0);
return box;
- The second one to create a cylinder with specified parameters representing a wheel:
/// function creating a named cylinder having a specified radius, height, color and transformation with a body and a shape
Object createBodyCylinder(string name, float radius, float height, float mass, Vec4 color, Mat4 transform)
ObjectMeshDynamic cylinder = Unigine::createCylinder(radius, height, 1, 32);
engine.editor.addNode(node_remove(cylinder));
cylinder.setWorldTransform(transform);
cylinder.setMaterial("mesh_base", "*");
cylinder.setMaterialParameter("albedo_color", color, 0);
cylinder.setName(name);
BodyRigid body = class_remove(new BodyRigid(cylinder));
ShapeCylinder shape = class_remove(new ShapeCylinder(radius, height));
return cylinder;
Now, using these functions we can create our car. We are going to use DynamicMesh objects for the frame and four wheels. For a proper mass balance let us set frame mass equal to 64 kg and the mass of each wheel - to 25 kg.
// defining DynamicMesh objects for the frame and four wheels
ObjectMeshDynamic car_frame;
ObjectMeshDynamic wheels[4];
// creating car frame
car_frame = createBodyBox("car_frame", Vec3(frame_length, frame_width, frame_height), 64.0f, Vec4(1.0f, 0.1f, 0.1f, 1.0f), transform);
// creating car wheels
// front left wheel
wheels[0] = createBodyCylinder("car_wheel_f_l", wheel_radius, wheel_width, 25.0f, Vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * translate(- frame_length/2 + wheel_radius, -(frame_width + wheel_width)/2 - delta, -frame_height/2) * rotateX(90.0f));
// front right wheel
wheels[1] = createBodyCylinder("car_wheel_f_r", wheel_radius, wheel_width, 25.0f, Vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * translate(- frame_length/2 + wheel_radius, (frame_width + wheel_width)/2 + delta, -frame_height/2) * rotateX(90.0f));
// rear left wheel
wheels[2] = createBodyCylinder("car_wheel_r_l", wheel_radius, wheel_width, 25.0f, Vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * translate(0.25f * frame_length, -(frame_width + wheel_width)/2 - delta, -frame_height/2) * rotateX(90.0f));
// rear left wheel
wheels[3] = createBodyCylinder("car_wheel_r_r", wheel_radius, wheel_width, 25.0f, Vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * translate(0.25f * frame_length, (frame_width + wheel_width)/2 + delta, -frame_height/2) * rotateX(90.0f));
Adding and Setting Up Joints#
Now that we have the frame and four wheels we can attach each wheel to the frame with a suspension joint.
To create a suspension joint for a wheel using a JointSuspension() constructor we must specify the following parameters:
- Rigid body of the car frame
- Rigid body of the wheel
- Anchor point coordinates (this point is determined by the position(translation) of the wheel relative to the frame)Notice
To extract wheel translation we can multiply wheel transformation matrix by a vec3 zero-vector.
- Coordinates of suspension axis (a vertical axis along which a wheel moves vertically and rotates when steering)
- Coordinates of wheel spindle axis (a horizontal around which a wheel rotates when moving forward or backward)
for(int i = 0; i < 4; i++)
suspension[i] = class_remove(new JointSuspension(car_frame.getBodyRigid(), // car frame body
wheels[i].getBodyRigid(), // car wheel body
wheels[i].getTransform() * Vec3_zero, // anchor coordinates
vec3(0.0f,0.0f,1.0f), // suspension axis
vec3(0.0f,1.0f,0.0f))); // wheel spindle axis
// setting restitution parameters
suspension[i].setLinearRestitution(0.1f);
suspension[i].setAngularRestitution(0.1f);
// setting linear damping and spring rigidity
suspension[i].setLinearDamping(2.0f);
suspension[i].setLinearSpring(40.0f);
// setting lower and upper suspension ride limits [-1.0; 0.0]
suspension[i].setLinearLimitFrom(-1.0f);
suspension[i].setLinearLimitTo(0.0f);
// setting number of iterations
suspension[i].setNumIterations(8);
Using Joint Motors#
So, we have a car, let us make it move now.
To move the car forward or backward we are going to use joint motors of the rear wheels (2 and 3):
- setting a positive velocity value will move our car forward.
- setting a negative velocity value will move our car backward.
suspension[2].setAngularVelocity(velocity);
suspension[3].setAngularVelocity(velocity);
suspension[2].setAngularTorque(torque);
suspension[3].setAngularTorque(torque);
To steer the car left or right we are going to change Axis10 coordinates of the front wheels (0 and 1) using setAxis10() method:
suspension[0].setAxis10(rotateZ(angle_0) * vec3(0.0f,1.0f,0.0f));
suspension[1].setAxis10(rotateZ(angle_1) * vec3(0.0f,1.0f,0.0f));
To stop the car we are going to set a high angular damping value for all wheels via setAngularDamping() method:
suspension[0].setAngularDamping(20000.0f);
suspension[1].setAngularDamping(20000.0f);
suspension[2].setAngularDamping(20000.0f);
suspension[3].setAngularDamping(20000.0f);
Adding Keyboard Controls#
To add keyboard control we are going to make a handler for the keys that we need. The handler must be put to the world script update() function to be called for each frame. We are going to update car physics (joint motors) in the flush() method.
int update()
// forward and backward movement by setting joint motor's velocity and torque
if(engine.controls.getState(CONTROLS_STATE_FORWARD) || engine.controls.getState(CONTROLS_STATE_TURN_UP)) {
// TODO: increase velocity by delta
// set desired torque
} else if(engine.controls.getState(CONTROLS_STATE_BACKWARD) || engine.controls.getState(CONTROLS_STATE_TURN_DOWN)) {
// TODO: decrease velocity by delta
} else {
// TODO: decrease velocity gradually
// clamp velocity value
velocity = clamp(velocity,-90.0f,90.0f);
// steering left and right by changing Axis01 for front wheel joints
if(engine.controls.getState(CONTROLS_STATE_MOVE_LEFT) || engine.controls.getState(CONTROLS_STATE_TURN_LEFT)) {
// TODO: increase steering angle by some delta
} else if(engine.controls.getState(CONTROLS_STATE_MOVE_RIGHT) || engine.controls.getState(CONTROLS_STATE_TURN_RIGHT)) {
// TODO: decrease steering angle
} else {
// TODO: return steering angle to zero value gradually
// clamp steering angle value
angle = clamp(angle,-30.0f,30.0f);
// TODO: calculate steering angles for front joints (angle_0 and angle_1)
// set new Axis10 coordinates for front joints
if(engine.controls.getState(CONTROLS_STATE_USE)) {
// TODO: set a very high angular damping value for all joints
// set velocity to zero
} else {
// TODO: set angular damping value to zero for all joints
int flush ()
// set angular velocity for rear joints
// set torque for rear joints
Putting it All Together#
In this section let us sum up all described above and create a new class for our car. The final code for our tutorial will be as follows:
#include <core/scripts/primitives.h>
Car car = NULL;
/// function, creating a named box having a specified size, color and transformation with a body and a shape
box.setName(name);
return box;
/// function, creating a named cylinder having a specified radius, height, color and transformation with a body and a shape
return cylinder;
/// Car class definition
class Car
// car parameters
float frame_width;
float frame_height;
float frame_length;
float wheel_radius;
float wheel_width;
// car elements
JointSuspension suspension[4];
// initialization of movement parameters
float angle = 0.0f;
float velocity = 0.0f;
float torque = 0.0f;
/// Car constructor creating a car with specified frame and wheel parameters
Car(float blength, float bwidth, float bheight, float wradius, float wwidth, Mat4 transform)
frame_width = bwidth;
frame_height = bheight;
frame_length = blength;
wheel_radius = wradius;
wheel_width = wwidth;
float delta = 0.2f;
// initialization of wheels
// initialization of suspension joints
for(int i=0; i < 4; i++)
suspension[i] = class_remove(new JointSuspension(car_frame.getBodyRigid(), wheels[i].getBodyRigid(), wheels[i].getTransform() * Vec3_zero, vec3(0.0f, 0.0f, 1.0f), vec3(0.0f, 1.0f, 0.0f)));
/// method updating current car state with a keyboard control handler
int update()
float ifps = engine.game.getIFps();
velocity = max(velocity,0);
velocity += ifps * 50.0f;
torque = 5.0f;
velocity = min(velocity,0);
velocity -= ifps * 50.0f;
torque = 5.0f;
} else {
velocity *= exp(-ifps);
angle += ifps * 100.0f;
angle -= ifps * 100.0f;
} else {
if(abs(angle) < 0.25f) angle = 0.0f;
else angle -= sign(angle) * ifps * 45.0f;
// calculating steering angles for front joints (angle_0 and angle_1)
float base = 3.3f;
float width = 3.0f;
float angle_0 = angle;
float angle_1 = angle;
if(abs(angle) > EPSILON) {
float radius = base / tan(angle * DEG2RAD);
angle_0 = atan(base / (radius + width / 2.0f)) * RAD2DEG;
angle_1 = atan(base / (radius - width / 2.0f)) * RAD2DEG;
suspension[0].setAxis10(rotateZ(angle_0) * vec3(0.0f, 1.0f, 0.0f));
suspension[1].setAxis10(rotateZ(angle_1) * vec3(0.0f, 1.0f, 0.0f));
// enabling or disabling a brake
velocity = 0.0f;
} else {
suspension[0].setAngularDamping(0.0f);
suspension[1].setAngularDamping(0.0f);
suspension[2].setAngularDamping(0.0f);
suspension[3].setAngularDamping(0.0f);
/// method updating car physics
int flush()
int init() {
engine.physics.setGravity(vec3(0.0f,0.0f,-9.8f * 2.0f));
engine.physics.setFrozenLinearVelocity(0.1f);
engine.physics.setFrozenAngularVelocity(0.1f);
//creating a car with specified parameters
car = new Car(4.0f, 2.0f, 0.5f, 0.5f, 0.5f, translate(Vec3(0.0f, 0.0f, 1.0f)));
// setting up player and controls
PlayerPersecutor player = new PlayerPersecutor();
player.setFixed(1);
player.setTarget(car.car_frame);
player.setMinDistance(6.0f);
player.setMaxDistance(11.0f);
player.setPosition(Vec3(10.0f, 0.0f, 6.0f));
player.setControlled(0);
int update() {
// updating current car state
car.update();
int flush() {
// updating car physics
car.flush();
