Customizing Mouse
Customizing Mouse
This example shows how to customize mouse cursor appearance and change default mouse behavior in your application. It will help you to solve the following tasks:
  • Changing the default mouse cursor image
  • Toggling mouse cursor's handling modes
  • Customizing your application's icon and title
Defining Mouse Behavior#
  • Grab - the mouse is grabbed when clicked (the cursor disappears and camera movement is controlled by the mouse). This mode is set by default.
  • Soft - the mouse cursor disappears after being idle for a short time period.
  • User - the mouse is not handled by the system (allows input handling by some custom module).
  • In the Editor, by selecting the corresponding option in the Controls Settings.
  • Via code by adding the corresponding line to the logic (world or system logic, components, expressions, etc.).
ControlsApp::setMouseHandle(Input::MOUSE_HANDLE_SOFT);
//or
ControlsApp::setMouseHandle(Input::MOUSE_HANDLE_USER);
Customizing Mouse Cursor#
You can change the look of the mouse cursor in your application using any square RGBA8 image you want. This can be done by simply adding the following lines to your code (e.g. world's init() method):
ImagePtr mouse_cursor = Image::create("textures/cursor.png");
mouse_cursor->resize(mouse_cursor->getWidth(), mouse_cursor->getWidth());
if (mouse_cursor->isLoaded() && mouse_cursor->getFormat() == Image::FORMAT_RGBA8)
	App::setMouseCursorCustom(mouse_cursor);
	App::setMouseCursorSystem(1);
// clearing pointer
mouse_cursor.clear();
Sample cursor image
Example Code#
  • Sets a custom icon and title for the application window
  • Sets a custom mouse cursor
  • Switches between the three handling modes on pressing the ENTER key.
// AppWorldLogic.cpp
#include "UnigineApp.h"
#include "UnigineUserInterface.h"
#include "UnigineGui.h"
#include "UnigineGame.h"
// auxiliary variables
ControlsPtr controls;
GuiPtr gui;
String handling_mode[3] = { "GRAB", "SOFT", "USER" };
// widgets
WidgetLabelPtr label;
WidgetLabelPtr label2;
WidgetButtonPtr button;
int AppWorldLogic::init()
	gui = Gui::get();
	ImagePtr icon = Image::create("textures/cursor.png");
	if (icon->isLoaded() && icon->getFormat() == Image::FORMAT_RGBA8)
		App::setIcon(icon);
	icon.clear();
	App::setTitle("Custom Window Title");
	label = WidgetLabel::create(gui);
	label2 = WidgetLabel::create(gui);
	button = WidgetButton::create(gui, "BUTTON");
	label->setPosition(10, 20);
	label2->setPosition(10, 40);
	button->setPosition(10, 80);
	gui->addChild(label, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
	gui->addChild(label2, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
	gui->addChild(button, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
	// clearing pointer
int AppWorldLogic::update()
	if (controls->clearState(Controls::STATE_USE) == 1) {
		switch (ControlsApp::getMouseHandle())
		case Input::MOUSE_HANDLE_GRAB:
			if (App::isMouseGrab())
				App::setMouseGrab(false);
				Gui::get()->setMouseEnabled(true);
			Input::setMouseHandle(Input::MOUSE_HANDLE_SOFT);
			break;
		case Input::MOUSE_HANDLE_SOFT:
			Input::setMouseHandle(Input::MOUSE_HANDLE_USER);
			break;
		case Input::MOUSE_HANDLE_USER:
			Input::setMouseHandle(Input::MOUSE_HANDLE_GRAB);
			break;
	label->setText(String::format("\n MOUSE COORDS: %d, %d)", App::getMouseX(), App::getMouseY()));
	label2->setText(String::format("\n MOUSE HANDLE: %s", handling_mode[Input::getMouseHandle()].get()));
Last update: 2021-04-09
