app_wall_00
This article describes the data/samples/plugins/app_wall_00.cpp sample.
The app_wall_00 sample demonstrates how to render an interface across all of the available monitors with the AppWall plugin. In this sample, the engine.wall.getGui() function is used to get a GUI instance for each monitor.
It is required to launch the AppWall plugin before running the sample.
Interface rendering across 2 monitors (2×1 configuration) with AppWall.
The monitor with the 0×0 label is the primary by default. You can change it via the engine.wall.setPrimary() function.
Last update: 2017-10-20
