Rendering Sequence
Unigine has a combination of full deferred renderer with forward rendering techniques:
  • All opaque (non-transparent) geometry is rendered in the deferred pass
  • Transparent geometry is rendered in the forward pass.
Before the deferred rendering pass, the engine performs all the necessary calculations. It specifies what nodes should be rendered, the order of rendering, how many lights on the scene and so forth.
This article introduces the detailed Unigine rendering pipeline including all the auxiliary stages which can be skipped by user.
Rendering Pipeline Overview
A frame is a complex structure including a lot of different calculations and textures rendering.
Here is a rendering pipeline, all stages are performed during one frame composition. Some stages can be switched off if it is necessary: decals rendering stage, auxiliary pass, post-materials, etc.
During the rendering, the engine initializes necessary texture buffers and most of them not cleared completely (the engine cuts out the sky areas). Some passes just re-use these already created buffers. Such optimizations help to increase the rendering performance.
The schematic representation of the rendering pipeline helps you to understand the major stages of the rendering order.
During the frame rendering, we will observe the simple test scene with a variety of materials (transparent and opaque), environment probes, decals, planar reflections, different light sources.
Common Pass
A Common pass is the very first step of the rendering sequence. In this pass environment LUTs, Environment cubemap are rendered. These textures are rendered only once before all the geometry on the scene and will be used further for the final screen composition: for scattering rendering and non-dynamic reflections.
Environment cubemap is composed from 6 pieces (each 256x256 px).
Schematic representation of the 1x256 LUT textures.
LUT textures are represented as 1x256 px textures taken from the current state of the loaded LUT textures for scattering.
Calculations
In this step, nothing will be rendered at all. This stage prepares the scene before geometry rendering: the engine analyzes the visible part of the scene to know which objects should be drawn and which shouldn't. The engine does the following:
  • Checks the intersections of objects with frustum (frustum culling) and finds those which present in the frame.
  • Finds all the light sources on the scene.
  • Finds all the surfaces that should be rendered (taking into account occluder objects).
  • Sorts Environment Probes by size (from large to small).
  • Sorts Decal objects by their rendering order.
  • Sets the Occlusion Query flags to objects that shouldn't be rendered.
Occlusion Query works with a delay: it is a very performance-hit operation that requires much time. The optimization is the following: the engine checks the scene asynchronously and sets the "should not be rendered" flag during the Occlusion Query stage. That's why occlusion query runs at least 1 frame late. But the object will be hidden without "hard switching" when the FPS value is high.
Shadow Maps
After calculations, shadow maps are rendered. The way of rendering these maps depends on a type of the light source. Generated shadow maps will be used in the further rendering stages.
World Light
For the world lights, the engine creates cascaded shadow maps. World Light's shadow map is rendered into the orthographic projection.
The shadow map of the world light source is rendered into texture divided into four parts (since the 4 is the maximum quantity of shadow cascades).
Shadow map of the world light source.
Shadows near the camera have higher resolutions, while shadows that far away from the camera have fewer details.
Rectangular shadow cascades on the final scene.
You can specify the number of cascades in the Shadow tab of the World Light source in the Nodes window.
Omni Light
Omni light sources use perspective projection for shadow maps. It uses 6 cameras that generate shadow maps.
Keep in mind that using a lot of Omni lights can sufficiently decrease the performance.
Proj Light
Shadow maps for Proj light sources are rendered only once because only 1 camera is used.
It is better to use Proj lights instead of Omni for better performance.
Dynamic Reflections
On this stage, the engine renders necessary textures for dynamic (that changed each frame) reflections: cubemaps for environment probes and 2D textures for planar reflections. To render these textures, the engine goes through all rendering pipeline (but misses some passes described below).
Cubemaps are generated by using 6 cameras, planar reflections use only 1 camera. Both render the final image (one more rendering cycle) with some hooks:
  • Textures use shadow maps, that were already generated in the previous shadow maps rendering pass.
  • All post effects are ignored.
  • Final image for dynamic reflections is rendered missing TAA.
The final texture of the dynamic reflections.
Update parameter (that available in the settings window of the Environment Probe object) has an influence on the rendering. This parameter specifies how many sides of the cubemap will be rendered during 1 update cycle. The minimal value doesn't always mean the better performance: a model with a lot of polygons (e.g. ~1 million) may cause a lag ("spike") because other sides will take much less time for rendering.
Deferred Pass for Opaque Objects
This one of the key passes of the rendering: all the opaque geometry is rendered during this pass one-by-one.
In the end of this pass, the engine has the texture (color texture) with all opaque geometry and scattering.
Native Depth Pre-Pass
In this pre-pass, the GPU performs a depth-test for surface culling. The pre-pass is performed only for alpha test and complex materials (like Terrain materials with a lot of layers).
The depth buffer stores native depth values z/w.
The depth data stored in a depth buffer texture format D32F
During this pass, the GPU can discard a pixel (the shading for this pixel won't be calculated).
Filling the GBuffer
During this step of rendering, the engine fills the Gbuffer (Geometry buffer) for shading.
Depth
Depth buffer contains scene objects in the current field of view (found between the near and far clipping planes). Objects are rendered as pure geometric models and stored into this buffer.
The engine also uses native depth.
Albedo
Albedo colors buffer stores pure albedo colors of all material textures:
The format of the texture is RGBA8 (RT0):
  • RGB channels store albedo color values
  • A channel stores the occlusion value. This channel is optional
Shading
Shading buffer stores the shading information of objects on the scene.
The format of the texture is RGBA8 (RT1):
  • R channel stores the metalness value
  • G channel stores the f0 (specular) value
  • B channel stores the translucent value
  • A channel stores the microfiber value
Translucency is used to simulate light shine through objects (leaves, for example).
Normal
Normal buffer stores normal vectors for each vertex of geometry which will be necessary to calculate the proper lighting.
The format of the texture is RGBA8 (RT2):
  • RGB channels store compressed normal values (in view space)
  • A channel stores the roughness value
Velocity
Velocity buffer stores information about the displacement of pixels per frame. When the image is still the buffer is filled with zero (black) values. These values are necessary to make the temporal anti-aliasing (TAA) and motion blur work correctly.
The format of the texture is RG16F (RT3):
  • RG channels store pixel displacement values (XY coordinates)
You can disable it if you don't need velocity-related effects: motion blur, TAA, etc.
Material Mask
Material mask texture. The first 8 bits are reserved for post effects, other bits can be used for materials.
The format of the texture is R32U (RT4):
  • R channel stores material mask value
Lightmap
Lightmap buffer is used to add baked light to the scene.
The format of the texture is RG11B10F (RT5):
  • RGB channels store lightmap values
During this step of the deferred pass for opaque objects, the engine renders decals. Decals have been already sorted on the Calculations stage and during this stage the engine performs rendering by using this order.
Decals are rendered by using alpha blending, but since normal and shading textures' A channels are occupied by microfiber and roughness values, the engine copies necessary values into new textures and performs alpha blending.
New Normal texture (uncompressed) that is used for alpha blending
New Roughness texture to store Roughness value in R channel, and Microfiber value in G channel.
If the value of render_decals console variable is set to 0, the engine will skip this rendering stage.
Shoreline Wetness
This rendering stage is responsible for shoreline wetness effect of the Global Water object. The behavior of this step is like in a previous Decals rendering step. So we can call this step Post-Decal Rendering.
The effect is performed by using Compute Shaders and Unordered Access Textures techniques.
Deferred Light Pass
In the deferred light pass the engine creates a buffer (Deferred Light Map) which is a 2D array of RG11B10F textures. The first layer of the array is for diffuse light, the second is for specular (which can be switched off for VR).
Light sources use already generated shadow maps.
All lights sources are rendered one-by-one in the single 2D array to be applied during the Deferred Composite.
For optimization issues, 1 world light source is always calculated during the Deferred Composite step.
If you have 2 or more world light sources, 1 world light source will always be rendered during the deferred composite, other will be rendered during this step.
Light sources diffuse layer
Light sources specular layer
The engine uses tile rendering technique for Omni lights without shadows. With this optimization, the omni light sources are grouped and rendered in batches, decreasing the number of DIP calls, therefore, increasing the performance.
Deferred Reflections
During this stage of rendering, the engine renders all the environment probes that had been already sorted on the calculations stage.
Environment probes are rendered into the 2D array of RGBA16F textures: the first layer contains reflections, the second layer contains ambient light.
The renderer doesn't clear the deferred reflection textures if at least one environment probe has infinite size.
If there is no environment, the RG11B10F 2D array is used.
Reflection texture of Environment Probe
Ambient texture of Environment Probe
Reflection Pass
In the reflection pass, planar dynamic reflections (that had been already rendered) are applied. Dynamic reflections are rendered in the same texture that was used for Deferred Reflections.
Planar dynamic reflection is applied
Occlusion Query
During the Occlusion query step, the engine excludes objects (geometry, lights and decals) which have the Culled by occlusion query flag enabled from rendering sequence.
If the render_occlusion_queries console command value is set to 2, the flag won't be taken into account and all objects will be excluded from rendereing sequence.
Occlusion query is an operation with a lot of calculations (i.e. has a huge influence on performance) and it is executed asynchronously. The engine checks object bounds and sets the flag the to renderer if it is necessary. In the next frame, during the Calculation stage, the renderer excludes the object from rendering sequence.
The Occlusion Query doesn't work, when the camera is inside the object.
Auxiliary Pass
Auxiliary pass is a type of custom pass. Materials with Auxiliary pass enabled will be rendered in the auxiliary RGBA8 texture.
Auxiliary texture is often used for different post-effects. It has his own TAA stage.
The engine will skip this pass if there's no material with enabled Auxiliary pass option.
Auxiliary buffer texture
Refractions
On this stage of the pipeline, the refractions are rendered. They are rendered in the Refraction texture and will be applied in the transparent object stage.
Refraction RGBA8 texture. texture contains distortion values.
Refractions buffer texture
Linear Depth and Color Old Reprojection
To perform screen-space effects, the engine renders Linear Depth and Color Old (previous frame) Reprojection textures.
These textures will be used in Screen-Space Reflections and Screen-Space Global Illumination stages.
Linear depth texture is generated by using G-buffer depth. Mips of linear depth and Color old textures are also created.
SSR
Screen-space Reflections are rendered in its own textures. It will be applied to the deferred composite stage.
SSR buffer texture
There are two different types of SSR: with importance sampling and without:
Importance Sampling is On
If the importance sampling is enabled, the rendered doesn't use linear depth texture.
In this case, SSR color texture and SSR velocity texture are rendered. Velocity is used for avoiding artifacts whilst the camera or objects are moving.
SSR has its own TAA stage.
Importance Sampling is Off
In this case, three textures are rendered: SSR velocity, SSR color texture, and ray-length texture. After that, the renderer applies TAA for the SSR.
Three textures mentioned above are used to perform blurring to provide realistic reflection behavior.
SSAO
Screen-space Ambient Occlusion is rendered in its own R8 texture. It will be applied in the deferred composite stage.
SSAO can be rendered with or without noise. This option has influence on TAA:
  • If the noise is enabled and SSAO is rendered in full resolution, there is no TAA in this stage.
  • If the noise is enabled and SSAO is rendered in half resolution, this stage has its own TAA.
SSAO texture
SSGI
Screen-space Global Illumination is rendered in 1 RGBA16F texture (color-only).
RGB channels store the color, A channel shows where the SSGI effect should be.
SSGI stage also has own TAA.
Underwater Fog
In this step, the Underwater Fog texture is initialized and cleared.
The renderer does it here to perform the underwater world lighting correctly.
Deferred Composite
During this stage, the engine uses all the necessary textures from the previous stages and passes to create the final texture with opaque geometry. The engine combines buffers and calculates shading for the final texture of this pass.
In this stage, the renderer calculates the light of the 1 World light and applies it. Environment reflections, ambient, haze (scattering) are also rendered here.
The final image of deferred pass for opaque geometry (excluding the Emission pass and SSS)
The final deferred composite texture can be RGBA16F or RG11B10F, depending on the corresponding option enabled.
Emission
Emission pass goes after the deferred composite image created. It applies emission effect over the deferred composite image.
Emission applied
SSS
Subsurface Scattering changes the final deferred texture: it applies the exponential blur.
SSS applied
Transparent Objects Rendering
Almost all transparent objects are rendered in the forward rendering pass.
During the forward pass, the renderer fills the deferred buffers to let forward transparent object participate in post-effects.
Refraction
During this stage of rendering sequence, the refraction texture (which had been already rendered) is applied
Refraction applied
Water
Water rendering in Unigine is really complex thing: it has its own deferred buffer (called WBuffer) with light and environment probes passes.
FieldHeigth and FieldShoreline
First, FieldHeight and Field Shoreline textures are rendered.
Height
Field Height textures are rendered in a 2D array of R16F or R32F textures (depends on settings). All Field Height textures are packed into 2D array to pass the data to the shader.
You can specify the format of the texture in the array by using the render_field_precision console command
Shoreline
All Field Shoreline textures are also are packed into 2D array (of RGBA8) to pass the data to the shader.
WBuffer
The renderer initializes the WBuffer.
The Underwater Fog texture has been already initialized.
Diffuse
The diffuse color of the water is black, and diffuse texture is necessary for decals, that will be displayed over the water surface.
The format of the texture is RGBA8:
  • RGB channels store decal diffuse values
  • A channel stores foam values
Normal
The normal texture stores normal for lighting, and alpha channel stores mesh transparency values (it can be used for soft intersections with water geometry).
  • A channel stores water fade values
Water
The Water texture is used to create the procedural foam mask. The mask shows where the foam will be depicted.
The format of the texture is RG8:
  • R channel stores procedural foam mask
  • G channel stores caustics values
Constants
We use a Deferred Constant Transferring approach for water meshes. This channel stores the ID value of the water mesh which is used to load the corresponding textures and parameters for it.
The format of the texture is R32U:
  • R channel stores constant id value for the water mesh
Underwater Mask
Underwater mask is used only for Global water, since water mesh doesn't have an underwater mode.
The format of the texture is RGB8:
  • R channel stores underwater mask (where the underwater and where is not)
  • G channel stores height distance (a distance to the separating waterline)
  • B channel stores shafts samples value (where sun shafts will be situated)
Underwater Fog
The format of the texture is RGBA16:
  • RGB channel store bottom coloring values
  • A channel stores fog exponent values (transparency of the fog)
Copy Opacity Screen
During this step, the renderer copies the opacity screen that has been rendered before into new texture.
Clear Buffers Textures
In this stage, the renderer clears buffer texture to prepare for water rendering. It clears reflection texture (both specular and diffuse), Water buffer texture, and, if there is water mesh on the scene, Constants and Underwater Fog textures.
Select the Water Mode
After, the renderer checks the camera position to know, what part of the water should be rendered. There are 3 modes:
  • UNDERWATER. Only underwater will be rendered.
  • OVERWATER. Only the upper surface of the water will be rendered.
  • BOTH. Both underwater and overwater will be rendered including separating waterline.
Filling the WBuffer
In this step, the WBuffer textures are filled with the corresponding data.
In case of water mesh, WBuffer is rendered like GBuffer because it doesn't have an underwater mode.
Global water is rendered differently: most buffers are rendered as deferred buffers but caustics of the water, fog, and underwater mask are rendered as post effects.
Water Decals
In this stage, water decals are rendered. Decals are rendered (normal and diffuse) by using alpha-blending.
Water Lights and Environment Probes
After decals DLM (Deferred Light Map) and Environment Probes textures are rendered.
Underwater Shafts
Here underwater shafts are rendered by using underwater mask shaft samples values (stored in B channel). They are rendered only if the camera has UNDERWATER mode or BOTH.
Water Composite
After all of the water stages, the renderer writes two composite for water pass:
  • For underwater
  • For overwater
After water composite the waterline (a black separating line) is rendered.
Water DOF
After the composite texture is rendered, the depth of field effect for water is rendered. It performs blurring over the whole texture.
If the Global DOF is enabled, it is used the depth of the water (water will be rendered to depth texture where opaque object are already rendered) to perform the DoF blurring correctly.
Sorting Transparent Objects
Transparent objects are sorted from the farthest to the nearest and will be rendered one by another.
Transparent objects rendering has two modes: when multiple environment probes and without.
Multiple Environment Probes is On
First, the Depth Buffer is rendered and Environment Probes texture is cleaned.
Environment Probe Rendering
During this stage, environment probe ambient and reflection are rendered into Environment Probes texture.
Ambient Pass
By using Environment Probe texture, the rendered lerps sky ambient and reflection with Environment Probe texture.
In the Ambient pass 1 World Light is always rendered.
Light Passes
The renderer adds all the lights to the texture.
Multiple Environment Probes is Off
Ambient Pass
During the ambient pass the environment, lightmaps, emission for transparent objects are calculated.
In the Ambient pass 1 World Light and 1 Reflection probe (where the object is located) are always rendered. If there are no reflection probes, the sky will be rendered.
Light Passes
During the light passes for transparent objects, the light is calculated. Render goes only through passes that were specified in the material states.
Ultimately, all the lights for transparent objects are added one after another.
After the transparent objects rendering.
Filling Deferred Buffers
Transparent objects also write information into deferred buffers to let them participate into post-effects.
Color Texture Copy
Current screen (color) texture is copied in this stage. The texture will be used for TAA and also for SSR and SSGI screen-space effects.
SRGB Correction and Static Exposure
In this pass, the engine performs SRBG correction and static exposure (if it is enabled). If the static exposure is off, the engine goes to the Adaptive Exposure stage.
After the SRGB correction
Adaptive Exposure
During this step, the engine renders luminance texture and applies it to the screen by using corresponding exposure: logarithmic or quadratic.
After the Adaptive Exposure
Temporal Anti-Aliasing (TAA)
This pass is used when TAA is enabled. Otherwise, the engine skips this pass and goes to the next one.
After the TAA
TAA uses previous frames to improve the current frame by using linear interpolation.
Render Post Materials
In this pass, the engine generates procedural textures for Render Post Materials. They are applied after the TAA.
Camera Effects
Almost all camera effects are rendered in their own textures to be used in the final screen composition stage to create the final image.
Motion Blur
Motion blur uses Velocity buffer for texture blurring. It hasn't its own buffer and changes the screen.
Depth of Field (DoF)
For the Depth of Field effect, the engine generates a DOF RG8 mask.
  • R channel stores the farthest blurring values (that behind the in-focus objects).
  • G channel stores the nearest blurring values (that in front of the in-focus objects).
DOF works with RG11B10F texture for fast work, therefore, if the screen texture has RGB16F it will be converted into RG11B10F in this step. Also, renderer performs some accuracy operations to improve the texture in the boundary areas of objects that in focus.
Chromatic aberrations are also rendered here.
Bright Texture
The renderer generates new texture which pixels are brighter than the threshold that had been set. This texture determines the areas that will be illuminated with other camera effects that mentioned below:
  • Sun Shafts
  • Bloom
  • Cross
  • Lens
Sun Shafts
Sun shafts are rendered into their texture and will be applied in the final screen composition stage.
Bloom
If the bloom is enabled, the engine generates up to 8 bloom textures: each texture has lower resolution (original size, original size /2, original size /4, so forth) with bloom effect. After that, all these bloom textures with the different resolution are composed for the final bloom texture.
Cross and Lens textures use the bloom texture (not final one) which has 1/4 screen resolution even if the bloom is not rendered.
Cross
Cross texture uses the original size /4 bloom texture to create the cross camera effect even if the bloom is disabled.
Lens
Lens texture also uses the original size /4 bloom texture to create the bloom effect even if the bloom is disabled. Dirt on the lens is also applied here.
Shadow Shafts
In this step, the engine renders the texture with shadow shafts. That texture will be used in the final screen composition stage.
Shadow shafts have their own mask (specifies where shadow shafts should be applied) and TAA for that mask.
Final Screen Composition
On this stage, the engine assembles a final texture by using all the textures that were rendering in the previous steps. Filmic tone mapping, dithering, and the LUT texture is applied here during the final screen composition.
Final screen composition.
Post Materials
After the final screen composition, all the post-effects applied.
If the procedural texture is necessary for a post-material, it will be calculated in this step and then the post-effect will be applied to the final composed screen.
Post Engine Materials
Border
In this engine post effect, the engine cuts out the edges of the screen, which are outside the main window.
FXAA
If the FXAA is enabled, the engine doesn't perform TAA pass and performs the anti-aliasing here by using FXAA algorithm.
Sharpen
If the Sharpen effect is enabled, the engine applied it here to the final screen.
Visualizer
On this stage the engine visualizer is rendered: mesh wireframes, bounding boxes, etc.
Fade Material
Fade material is used to create a smooth screen blacking. It usually used for the beginnings and endings of tracks for Tracker.
GUI is rendered last after all the stages and passes are rendered.
After GUI rendering.
Finally, the engine rendered a single frame!
Last update: 2017-10-20
