mesh_02
This article describes the data/samples/objects/mesh_02.cpp sample.
The mesh_02 sample demonstrates how to deform a static mesh as a dynamic mesh, namely:
  • Load the static mesh from a given file and copy it to the dynamic mesh by using the setMesh() function
  • Deform vertices of the dynamic mesh
  • Add the deformed dynamic mesh as the static mesh to the editor
49 dynamic ObjectMeshes
The static mesh used in this sample is stored in the samples/objects/meshes/mesh_02.mesh file.
Last update: 2020-07-31
