Getting Started
Migrating to UNIGINE 2.0
C++ API Migration
The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
C# API
This section contains information about the Unigine C# API.
The Unigine engine enables exporting the C# code to UnigineScript. You can export variables, UnigineScript containers, functions and set callbacks. However, you can't export your C# classes.
To work with C# API by using Mono on the Linux platform, the Mono should be installed this way.
The C++ API description. Most functions and classes in the C# API have the same names and behavior as in the C++ API.
