gui_07
This article describes the data/samples/objects/gui_07.cpp sample.
The gui_07 sample demonstrates how to create a GUI object with a custom skin, namely:
- Specify a path to a folder with an *.rc file and custom textures when creating a GUI object
- Load a user interface by using the constructor of the UserInterface class
In this sample, the window assigned to the GUI object is generated from the samples/objects/interfaces/gui_07.ui UI file.
You can interact with its elements with the mouse as usual: change position of the window, switch between tabs, etc.
- Article on the GUI Object
- Article on the Skin Layout to learn how to create a custom skin
- Functions of the ObjectGui class
- Functions of the UserInterface class
Была ли эта статья полезной?
