Forum
Docs (2.16)
Unsupported SDK
UNIGINE Future
(Unsupported SDK)
UNIGINE 2.18 (Latest)
(Unsupported SDK)
UNIGINE 2.17
(Unsupported SDK)
UNIGINE 2.16.1
(Unsupported SDK)
UNIGINE 2.16
(Unsupported SDK)
UNIGINE 2.15.1
(Unsupported SDK)
UNIGINE 2.15
(Unsupported SDK)
UNIGINE 2.14.1
(Unsupported SDK)
UNIGINE 2.14
(Unsupported SDK)
UNIGINE 2.13
(Unsupported SDK)
UNIGINE 2.12
(Unsupported SDK)
UNIGINE 2.11
(Unsupported SDK)
UNIGINE 2.10
(Unsupported SDK)
UNIGINE 2.9
(Unsupported SDK)
UNIGINE 2.8
(Unsupported SDK)
UNIGINE 2.7.3
(Unsupported SDK)
UNIGINE 2.7.2
(Unsupported SDK)
UNIGINE 2.7.1
(Unsupported SDK)
UNIGINE 2.7
(Unsupported SDK)
UNIGINE 2.6.1
(Unsupported SDK)
UNIGINE 2.6
(Unsupported SDK)
UNIGINE 2.5
(Unsupported SDK)
UNIGINE 2.4.1
(Unsupported SDK)
UNIGINE 2.4
(Unsupported SDK)
UNIGINE 2.3.1
(Unsupported SDK)
UNIGINE 2.3
(Unsupported SDK)
UNIGINE 2.2.1
(Unsupported SDK)
UNIGINE 2.2
(Unsupported SDK)
UNIGINE 2.1.1
(Unsupported SDK)
UNIGINE 2.0
(Unsupported SDK)
UNIGINE 1.0
(Unsupported SDK)
Show older versions >>|Hide older versions <<
Select Your Language
English
Русский
中文
Français
Deutsch
日本語
한국어
Español
Português
Italiano
Türkçe
Svenska
Suomi
Dansk
Nederlands
Norsk
हिन्दी
Tiếng Việt
Bahasa Indonesia
Polski
Limba Română
Magyar
Cрпски
Slovenčina
Slovenščina
Hrvatski
Český
Bosanski
Македонски
Български
Sign in
in API
Not found
Getting Started
What's Inside?
Downloading and Installing UNIGINE SDK
Project Workflow
Programming Quick Start
Introduction
Programming Quick References
1. Setting Up the Project
2. Creating the Controllable Character
3. Implementing Shooting
4. Generating Physical Objects
5. Implementing Color Zone
6. Playing Background Music
7. Managing Game Rules
8. Creating the End UI
9. Building the Project
Getting Started with VR
Classes and Components Overview
System Requirements
Migrating to UNIGINE
Migrating to UNIGINE From Unreal Engine
Physics
Migrating to UNIGINE From Unity
Physics
SDK Browser Interface
Editor Interface
Scene Viewport
Importing 3D Models
Instancing Nodes
Tracker Tool
Global Illumination
Performance Inspection with Microprofile
Procedural Texturing
Bit Masking
Audio Sources and Sound Effects
Cached Shadows
Water
Physics
C# Component System
Landscape Terrain
Volumetric Clouds
Node References: Must-Knows
Microprofile for Artists
Export 3D Models from Autodesk Maya
Export 3D Models from Blender
Export 3D Models from Cinema 4D
Export 3D Models from Autodesk 3ds Max
Edit Source Code with a Custom IDE
Change the Default World On Startup
Customize Boot Screen
Disable Splash Screen
Use Texture Profiler to Optimize Performance
Use Physical Water To Make Objects Float and Imitate Streams
Create a Final Build for a C# Project
Configure Levels of Detail (LODs)
Using Autogenerated LODs
Delete Unused Assets from the Final Build
Transfer Assets to Another Project
Swapping and Transforming Objects for More Variations
Using Cluster Brush Editor
Replacing Assets in the Project
Capturing Screenshots and Frame Sequences
Use Cleaner to Delete Unused Assets from a Project
Asset Browser
C# Programming
Print User Messages to Console with C#
Access Assets from C# Components
Access Nodes from C# Components
Create C# (.NET Core) Project
Debug C# Project in Visual Studio Code
Customize Loading Screens
Use World Triggers to Detect Nodes by Their Bounds
Use Physical Triggers to Catch Physical Objects
Use Node Triggers to Detect Changes in Node States
Use Intersections to Select Objects with the Mouse
Handle Contacts on Collision
C++ Programming
Create a C++ Project
Create a C++ Project (CMake)
Create a Final Build for a C++ Project
Enable Planar Reflections
Bake Global Illumination to Voxel Probes
Bake Reflections to Environment Probes
Use Cached Shadows
Create Scriptable Materials
Bake Global Illumination to Lightmaps
Reuse Lightmaps for Levels of Detail
Use Particle Systems to Create Fountain with Sparks
Tweak Baked Lighting Dynamically via the Lightmap Color
Combine Baked Lighting and Reflections via Additive Blending
Customize Environment Lighting
Make Thin Geometry Visible at Long Distances
Cut Out Unwanted Reflections in Occluded Areas of Irregular-Shaped Rooms
Create Vertex Color Based Animation for Vegetation
Set Up Adaptive Camera Exposure
Use Surface Custom Texture
Create and Use Flowmaps
Quick start with IG Template for a Flight Simulator
Principles of Operation
Virtual World Structure
World Management
Properties
Hierarchy and Inheritance
Component System
C++ Component System
C# Component System
Rendering Sequence
Parallel-Split Shadow Mapping
Anti-Aliasing
Temporal Anti-Aliasing (TAA)
Supersampling
Interleaved Lights Rendering
Alpha Blending
Output Modes
Stereo Rendering
Separate Images Output with Separate Plugin
Quad Buffered Stereo Support
Oculus Rift Output with Oculus Plugin
VR Output with OpenVR Plugin
Varjo Output with Varjo Plugin
Multi-Monitor Rendering
Video Wall Output with Wall Plugin
3 Monitor Output with Surround Plugin
Panoramic Rendering
Projections with Projection Plugin
Physics
Physical Bodies
Cloth Body
Dummy Body
Fracture Body
Path Body
Ragdoll Body
Rigid Body
Rope Body
Water Body
Shapes
Collision Detection
Joints
Simulation of Physics
Bit Masking
Import System
Export System
File System
Asynchronous Data Streaming
SDK Browser 2
Projects
Licenses
Managing Company Accounts and Licenses
Assets
Airport Assets
Eastern European Countryside
Docs Sample Content
IG Aviation
Industrial Assets
Road Tool Constructor
Scans
Vegetation
VFX
Weather
Procedural Generation Assets
Demos
CIGI
C# Component Samples
Animation
Arcade Sample
Cameras
CharacterController
Components
Create Nodes
Navigation
Sounds
Tracker
Transformation
Water Global
Weapon Clipping
Widgets
World Intersection
C# Third Person Platformer
CPP Samples
Earthworks
Fox Hole
High-Level Vehicle
Mars
Oil Platform
Oil Refinery
Orbits
ROS Vehicle
Superposition
Syncker
Viewer
VR Sample
API Samples
C++ API
Logics
Physics
Render
Scripts
Systems
Widgets
WindowManager
C# API
Physics
Scripts
Systems
Widgets
3rd Party
QT
NVIDIA
Dear ImGui
Other
Sounds
Layout Customization
Context Menus
Asset Types
Assets and Runtime Files
Creating and Importing Assets
FBX Import Guide
CAD Import Guide
Texture Import Guide
Exporting 3D Models From Blender
Exporting 3D Models From Autodesk Maya
Exporting 3D Models From Autodesk 3ds Max
Exporting 3D Models From Maxon Cinema 4D
Organizing Assets
Copying Assets From Other Projects
Optimizing Assets
Texture Profiler
Cleaner
Connections Between Assets
Upgrading Assets
Project Files
Editor Settings and Hotkeys
World Settings
Render Settings
Screen
Visibility Distances
Lights
Transparent
Shadows
Tessellation
Global Illumination
SSAO
SSGI
Bent Normal
Subsurface Scattering
SSR
Dynamic Reflections
SSBevel
SSDirt
Landscape
Terrain
Water
Clouds
Vegetation
Environment
Occlusion Culling
Camera Effects
Color Correction
Buffers
Streaming
Custom Post Materials
Debug Materials
Custom Composite Materials
Wireframe Color
Global Physics Settings
Global Sound Settings
Controls Settings
Managing Worlds
Scene Navigation
Creating Nodes
Selecting and Positioning Nodes
Organizing Nodes
Exporting Nodes
Instancing Nodes
Transformation and Common Parameters
Visual Representation
Properties
Physics and Sound
Organizing Materials
Forced Shader Compilation
Organizing Properties
Environment
Shadows
Global Illumination
Bake Lighting Window
Lightmapping
Voxel-Based GI
Environment Probes
Light Meter
Reflections
Setting Up Cameras
Using Visual Helpers
System Menu
Interface Overwiew
Workflow
Creating Landscape
Adding a Mask
Adding Vegetation
Adding Roads
Placing Points
Pipelines, Fences, Powerlines
Adding Buildings
Generating the Terrain and Objects
Sources and Their Parameters
Elevation and Imagery
Mask
Buildings
Vegetation
Points
Roads
Generation Settings
Format
Export Area
Data Types
Projection
Curvature
Quality
Distributed Generation
Output Directories and Files
Questions and Answers
Making Cutscenes: Animations & Camera Control
Basic Operations in Tracker
Creating Type-Specific Tracks
Usage Example
Running Tracks in Application
Adding Variations for a More Realistic Environment
Generating Impostors with Impostors Creator
Editing Global Terrain
Editing Landscape Terrain
Mask Editor for Grass and Clutters
Cluster Editor
Texture Editor
Brush Tool
Pencil Tool
Eraser Tool
Smooth Tool
Smudge Tool
Contrast Tool
Brightness Tool
Saturation Tool
Replace Color Tool
Invert Tool
Flow Map Tool
Draw Mesh Data Tool
Ambient Occlusion Tool
Curvature Tool
Leaks Tool
Color Picker Tool
Setting Up Environment
Creating Your First Editor Plugin
Managing Assets in Editor Plugins
Editing Curves
Tools
Plugins for 3D Editors
Plugins for 3ds Max
Plugins for Maya
Performance Profiling Tools
Performance Profiler
Microprofile
USC Interpreter
Archiver
Resource
Upgrade Script
Runtimes Generator
Node
Node Reference
Dummy Node
Layer
Trigger
Dummy Object
Static Mesh
Skinned Mesh
Dynamic Mesh
Mesh Cluster
Mesh Clutter
Terrain
Landscape Terrain
Landscape Layer Map
Configuring Details
Importing Heightmaps
Import from World Creator 2
Import from Quadspinner GAEA
Import from World Machine
Import from Houdini
Import from Instant Terra
Global Terrain
Global Terrain Details
Text Object
Water
Global Water
Water Mesh
Sky
Cloud Layer
Grass
Grass Settings
Tutorial: Adding Grass
Billboards
Stars Generator for Billboards
GUI Objects
GUI Mesh
Particle System
Volumetric Objects
Volume Box
Volume Sphere
Volume Omni
Volume Projected
Fields
Field Spacer
Field Animation
Field Height
Field Shoreline
Field Weather
Physicals
Physical Wind
Physical Force
Physical Noise
Physical Water
Physical Trigger
Projected Decal
Orthographic Decal
Mesh Decal
Light Sources Parameters
Omni Light
Projected Light
World Light
Environment Probe
Voxel Probe
Planar Reflection Probe
Geodetic Pivot
World Trigger
World Clutter
Switcher
Occluders
Occluder
Occluder Mesh
Transforms
Transform Path
Transform Bone
World Expression
World Spline Graph
Sound Source
Sound Reverb
Navigation Areas
Navigation Sector
Navigation Mesh
Obstacles
Obstacle Box
Obstacle Sphere
Obstacle Capsule
Player Actor
Player Dummy
Player Persecutor
Player Spectator
Programming Overview
Engine Architecture
Execution Sequence
Application Logic System
Engine Initialization
Engine Main Loop
Engine Shutdown
Where to Put Your Code
Working with Smart Pointers
Thread Safety
Matrix Transformations
Camera Matrices
Event Handling Callbacks
Windows Development Environment
Linux Development Environment
Working with Landscape Terrain via Code
High-Level Car Physics System (C++)
Custom Import Plugin
Importing Models Directly to Memory
Basic Object Movements
A Car with Wheel Joints
Creating A Simple Mechanism Using Joints
Creating Routes
Dynamic Meshes
Playing Sounds on Collisions
Intersections
Mesh Class
Working with Console
Sharing Data
Using Manipulators to Transform Objects
Making Screenshots at Runtime
Handling Contacts on Collision
Making a First-Person Shooter (C#)
Creating C++ Application
Creating C++ Plugin
C++ Integration Samples
Integrating with Frameworks
C++ Usage Examples
Extending UnigineScript
Library's Namespace
Variable Export
Constant Export
Function Export
Class Export
Data Structure Export
Callbacks
Serialization
UnigineScript Containers
Creating C# Application
Debugging C# Components
Garbage Collector
C# API Reference
C# Integration Samples
Application with Direct3D11 via SharpDX Library
Application with OpenGL via OpenTK Library
C# Usage Examples
C# Component System
Plugin Class
Package Class
Widget Dialog
Callbacks
Variable Export
Adding Scripts to the Project
The Language
Structure of a Program
Data Types
Operators
Control Statements
Selection Statements
if-else
switch-case
Iteration Statements
for
while
do-while
forloop
foreach
foreachkey
Jump Statements
return
goto
break
continue
Other Statements
yield
wait
call()
thread()
Functions
Scope. Namespaces
Object Oriented Programming
Interface Class
Preprocessor Directives
Templates
Language Features
System Functions
String Global Functions
Script Debugging
UnigineScript Basic Utilities
Unigine::Widgets
Input System
Dialogs Script
cluster_00
cluster_01
dynamic_00
dynamic_01
dynamic_02
dynamic_03
dynamic_04
dynamic_05
gui_00
gui_01
gui_02
gui_05
gui_06
gui_07
mesh_01
mesh_02
app_oculus_00
app_surround_00
app_surround_01
app_wall_00
gpu_monitor_00
ssl_socket_00
ssl_socket_01
Shaders
scriptable_00
Cache Files
UUSL Keywords
UUSL GBuffer Structure
UUSL Parameters
UUSL Textures
UUSL Semantics
UUSL Tessellation
UUSL Color Spaces
UUSL Matrices
UUSL Noise
UUSL Pack Utils
UUSL Parallax
UUSL Compute Shaders
Creating a Custom Shader for Post-Processing
ARTTRACK Plugin
FbxImporter Plugin
CadImporter Plugin
Setting Up Projections with AppEasyBlend Plugin
GeodeticsPlugin
Kinect2 Plugin
LeapMotion Plugin
Ultraleap Plugin
Secure SSL Connection via SSLSocket Plugin
Syncker Plugin
Syncker-Specific Options
Configuring Screens and Projections
Teslasuit Plugin
VRPN Plugin
FMOD Plugin
Mesh File Formats
Materials Files
XML Base Material File Format
ULON Base Material File Format
Groups
Options
States
Conditions
Shaders
Passes
Parameters
Expressions
Scripts
Binds
User Material File Format
Property File Format
Spline File Format
Abstract Materials
Mesh
Mesh Transparent
Mesh Unlit
Decal
Startup Command-Line Options
Console
Configuration Files
Protecting Your Data with a Password
Window Management
Loading and Splash Screens
UI Files
Widgets
Localization
RC Files
Skin Layout
Usage Example
Usage
Performance Analyzer
Container Functions
ArrayMap Classes
ArrayMap Class
ArrayMap::Iterator Class
ArrayVector Class
BiMap Class
HashMap Class
HashSet Class
Map Class
Pair Class
Set Class
Tree Classes
Tree Class
Tree::ConstIterator Class
Tree::Iterator Class
Vector Classes
Vector Class
Vector::ConstIterator Class
Vector::Iterator Class
VectorStack Class
Async Class
ScopedLock Class
ScopedReaderLock Class
ScopedReentrantLock Class
ScopedWriterLock Class
Atomic Class
BackoffSpinner Class
Mutex Class
ReentrantMutex Class
RWMutex Class
Blob Class
Callback-Related Classes
CallbackBase Class
CallbackBase1 Class
CallbackBase2 Class
CallbackBase3 Class
CallbackBase4 Class
CallbackBase5 Class
Signal Class
Checksum-Related Classes
Checksum Class
CRC32 Class
MD5 Class
SHA1 Class
SHA256 Class
Compress Class
ConsoleVariableFloat Class
ConsoleVariableInt Class
ConsoleVariableString Class
Curve2d Class
Expression Class
ExternClass Class
FunctionBase Class
Hash Class
Hasher Class
File Import Classes
Data Structures
Import Class
Importer Class
ImportProcessor Class
ImportScene Class
FBX Export Classes
Export Class
Exporter Class
Image Class
ImageConverter Class
Interpreter Class
Json Class
Log Class
Logic Classes
EditorLogic Class
SystemLogic Class
WorldLogic Class
Component System Classes
ComponentBase Class
ComponentSystem Class
ComponentVariable Class
Component Class
AssetLink Class
AssetLinkNode Class
OS Functions
Palette Class
Path Class
Plugin Class
Property Class
PropertyParameter Class
Ptr Class
Reflection Class
RegExp Class
Resource Class
Stream Class
String Class
StringArray Class
StringPtr Class
StringStack Class
Thread Class
Time Class
Timer Struct
TypeInfo Class
UlonArg Class
UlonValue Class
UlonNode Class
Unigine Namespace Items
Utils Class
Xml Class
Variable Class
Controls Class
ControlsApp Class
ControlsDummy Class
ControlsJoystick Class
ControlsGamepad Class
Input Class
InputEvent Class
InputEventKeyboard Class
InputEventMouseButton Class
InputEventMouseMotion Class
InputEventMouseWheel Class
InputEventSystem Class
InputEventText Class
InputEventTouch Class
InputEventJoyDevice Class
InputEventJoyButton Class
InputEventJoyAxisMotion Class
InputEventJoyPovMotion Class
InputEventPadDevice Class
InputEventPadButton Class
InputEventPadAxisMotion Class
InputGamePad Class
BootConfig Class
CustomSystemProxy Class
Config Class
Console Class
Editor Class
Engine Class
EnginePtr Class
engine.system Functions
EnginePlugins Class
Game Class
GameIntersection Class
LoadingScreen Class
Memory Class
Profiler Class
Properties Class
Sound Class
Sounds Class
SystemDialog Class
SystemInfo Class
UserConfig Class
Visualizer Class
World Class
Dir Class
File Class
FileSystem Class
FileSystemAssets Class
FileSystemMount Class
AsyncQueue Class
File System Functions
Package Class
PackageUng Class
UGUID Class
Gui Class
UserInterface Class
Displays Class
EngineWindow Class
WindowManager Class
WindowEvent Class
WindowEventDrop Class
WindowEventGeneric Class
Widget Class
WidgetButton Class
WidgetCanvas Class
WidgetCheckBox Class
WidgetComboBox Class
WidgetDialog Class
WidgetDialogColor Class
WidgetDialogFile Class
WidgetDialogImage Class
WidgetDialogMessage Class
WidgetEditLine Class
WidgetEditText Class
WidgetExternBase Class
WidgetExtern Class
WidgetGridBox Class
WidgetGroupBox Class
WidgetHBox Class
WidgetHPaned Class
WidgetIcon Class
WidgetLabel Class
WidgetListBox Class
WidgetManipulator Class
WidgetManipulatorScaler Class
WidgetMenuBar Class
WidgetMenuBox Class
WidgetScroll Class
WidgetScrollBox Class
WidgetSlider Class
WidgetSpacer Class
WidgetSpinBox Class
WidgetSpinBoxDouble Class
WidgetSprite Class
WidgetSpriteNode Class
WidgetSpriteShader Class
WidgetSpriteVideo Class
WidgetSpriteViewport Class
WidgetTabBox Class
WidgetTreeBox Class
WidgetVBox Class
WidgetVPaned Class
WidgetWindow Class
Math Functionality (C#)
Geometry Class (C#)
Math Common Functions (C#)
Math 2D Functions (C#)
Bounds-Related Classes (C#)
BoundBox Struct (C#)
BoundFrustum Struct (C#)
BoundSphere Struct (C#)
WorldBoundBox Struct (C#)
WorldBoundFrustum Struct (C#)
WorldBoundSphere Struct (C#)
Random Struct (C#)
Bits8 Struct (C#)
Bits16 Struct (C#)
Bits32 Struct (C#)
Bits64 Struct (C#)
bvec4 Struct (C#)
dmat4 Struct (C#)
dvec2 Struct (C#)
dvec3 Struct (C#)
dvec4 Struct (C#)
ivec2 Struct (C#)
ivec3 Struct (C#)
ivec4 Struct (C#)
mat2 Struct (C#)
mat3 Struct (C#)
mat4 Struct (C#)
quat Struct (C#)
vec2 Struct (C#)
vec3 Struct (C#)
vec4 Struct (C#)
Math Functionality (C++)
Predefined Constants
Bounds-Related Classes (C++)
BoundBox Struct
BoundFrustum Struct
BoundSphere Struct
Geometry Class
Math 2D Functions
Math Exponential Functions
Math Matrix Functions
Bits Class
BitStream Class
bvec4 Class
Concave Class
ConcaveConvexCompare Class
Convex Class
dmat4 Class
dvec2 Class
dvec3 Class
dvec4 Class
half Class
hvec2 Class
hvec3 Class
hvec4 Class
ivec2 Class
ivec3 Class
ivec4 Class
mat2 Class
mat3 Class
mat4 Class
Noise Class
Polygon Class
quat Class
Random Class
SHBasis Class
svec4 Class
vec2 Class
vec3 Class
vec4 Class
Node Class
NodeDummy Class
NodeExtern Class
NodeExternBase Class
NodeLayer Class
NodeReference Class
NodeTrigger Class
Decals-Related Classes
Decal Class
DecalMesh Class
DecalOrtho Class
DecalProj Class
Field-Related Classes
Field Class
FieldAnimation Class
FieldHeight Class
FieldShoreline Class
FieldSpacer Class
FieldWeather Class
Geodetics-Related Classes
Ellipsoid Class
GeodeticPivot Class
GeodeticsTransformer Class
Lights-Related Classes
BakeLighting Class
Light Class
LightEnvironmentProbe Class
LightVoxelProbe Class
LightPlanarProbe Class
LightOmni Class
LightProj Class
LightWorld Class
LightLensFlare Class
Object Class
ObjectBillboards Class
ObjectCloudLayer Class
ObjectDummy Class
ObjectDynamic Class
ObjectExtern Class
ObjectExternBase Class
ObjectGrass Class
ObjectGui Class
ObjectGuiMesh Class
ObjectIntersection Class
ObjectLandscapeTerrain Class
TerrainDetail Class
TerrainDetailMask Class
Landscape Class
LandscapeLayerMap Class
LandscapeMapFileCreator Class
LandscapeFetch Class
LandscapeImages Class
LandscapeTextures Class
ObjectMeshStatic Class
ObjectMeshCluster Class
ObjectMeshClutter Class
ObjectMeshDynamic Class
ObjectMeshSkinned Class
ObjectMeshSplineCluster Class
ObjectParticles Class
ParticleModifier Class
ParticleModifierScalar Class
ParticleModifierVector Class
ObjectSky Class
ObjectTerrainGlobal Class
TerrainGlobalDetail Class
TerrainGlobalLod Class
TerrainGlobalLodHeight Class
TerrainGlobalLods Class
TileSet Class
TileSetFile Class
ObjectText Class
ObjectVolumeBox Class
ObjectVolumeOmni Class
ObjectVolumeProj Class
ObjectVolumeSphere Class
ObjectWaterMesh Class
ObjectWaterGlobal Class
Players-Related Classes
Player Class
PlayerActor Class
PlayerDummy Class
PlayerPersecutor Class
PlayerSpectator Class
Sound Nodes-Related Classes
AmbientSource Class
SoundReverb Class
SoundSource Class
World Nodes-Related Classes
WorldClutter Class
WorldExpression Class
WorldExternBase Class
WorldExtern Class
WorldIntersection Class
WorldIntersectionNormal Class
WorldOccluder Class
WorldOccluderMesh Class
WorldSplineGraph Class
SplineGraph Class
SplinePoint Class
SplineSegment Class
WorldSwitcher Class
WorldTransformBone Class
WorldTransformPath Class
WorldTrigger Class
Socket Class
Navigation Class
NavigationMesh Class
NavigationSector Class
Obstacle Class
ObstacleBox Class
ObstacleCapsule Class
ObstacleSphere Class
PathRoute Class
PathRouteIntersection Class
Contact Class
ShapeContact Class
Physics Class
PhysicsIntersection Class
Bodies-Related Classes
Body Class
BodyCloth Class
BodyDummy Class
BodyFracture Class
BodyParticles Class
BodyPath Class
BodyRagdoll Class
BodyRigid Class
BodyRope Class
BodyWater Class
Joints-Related Classes
Joint Class
JointBall Class
JointCylindrical Class
JointFixed Class
JointHinge Class
JointParticles Class
JointPath Class
JointPrismatic Class
JointSuspension Class
JointWheel Class
Physical Class
PhysicalForce Class
PhysicalTrigger Class
PhysicalNoise Class
PhysicalWater Class
PhysicalWind Class
Shapes-Related Classes
Shape Class
ShapeBox Class
ShapeCapsule Class
ShapeConvex Class
ShapeCylinder Class
ShapeSphere Class
GPUMonitor Plugin
GPUMonitor Class
GPUMonitorPlugin Class
EasyBlend Class
OpenFlightImport Class
Kinect Class
Oculus Class
Projection Class
engine.surround Functions
Varjo Class
OpenVR Class
Wall Class
ARTTracker Class
DISConnector Plugin
DIS::Connector Class
HLAConnector Plugin
HLA::Connector Class
CIGI::Connector Class
CigiAerosolResponse Class
CigiAnimationNotify Class
CigiArticulatedControl Class
CigiAtmosphereControl Class
CigiCelestialControl Class
CigiComponentControl Class
CigiEarthModelDef Class
CigiEntityControl Class
CigiEnvironmentControl Class
CigiEnvironmentRequest Class
CigiEventNotify Class
CigiHatHotExtResponse Class
CigiHatHotRequest Class
CigiHatHotResponse Class
CigiHostPacket Class
CigiHostUserDefined Class
CigiIGControl Class
CigiIGMessage Class
CigiIGPacket Class
CigiIGUserDefined Class
CigiLosExtResponse Class
CigiLosResponse Class
CigiLosSegmentRequest Class
CigiLosVectorRequest Class
CigiMaritimeControl Class
CigiMaritimeResponse Class
CigiPositionRequest Class
CigiPositionResponse Class
CigiRateControl Class
CigiSegmentDef Class
CigiSegmentNotify Class
CigiSensorControl Class
CigiSensorExtResponse Class
CigiSensorResponse Class
CigiStartOfFrame Class
CigiSymbolCircleDef Class
CigiSymbolClone Class
CigiSymbolControl Class
CigiSymbolLineDef Class
CigiSymbolShortControl Class
CigiSymbolSurfaceDef Class
CigiSymbolTextDef Class
CigiTerrestrialControl Class
CigiTerrestrialResponse Class
CigiTrackerControl Class
CigiTrajectoryDef Class
CigiViewControl Class
CigiViewDef Class
CigiVolumeDef Class
CigiVolumeNotify Class
CigiWaveControl Class
CigiWeatherControl Class
CigiWeatherResponse Class
IG Manager Class
IGConfig Class
Component Class
ComponentBaseInterface
IGIntersection Structure
ArticulatedPart Class
CollisionSegment Class
CollisionVolume Class
Converter Class
Entity Class
LightController Class
Meteo Class
MeteoCameraEffects Class
MeteoPositionParam Structure
Region Class
SkyMap Class
SymbolsController Class
SymbolsPlane Class
Symbol Class
SymbolPolyline Class
SymbolCircle Class
SymbolText Class
ViewBase Class
ViewGroup Class
View Class
Water Class
WeatherLayer Class
WeatherLayerCloud Class
FMOD Plugin
Bank Class
Bus Class
Channel Class
ChannelGroup Class
DSP Class
DSPType Class
EventDescription Class
EventInstance Class
FMOD Class
FMODCore Class
FMODEnums Class
FMODStudio Class
Sound Class
VCA Class
LeapMotion Plugin
LeapMotion Class
LeapMotionArm Class
LeapMotionBone Class
LeapMotionFinger Class
LeapMotionHand Class
Ultraleap Plugin
Ultraleap Class
UltraleapDevice Class
UltraleapArm Class
UltraleapBone Class
UltraleapFinger Class
UltraleapHand Class
SSLSocket Plugin
SSLSocket Class
SSLSocketPlugin Class
Steam Plugin
Steam Class
SteamLeaderboard Class
Syncker Plugin
Manager Class
Syncker Class
Master Class
Slave Class
Projections Class
Teslasuit Plugin
TeslaSuitGeneral Class
Suit Class
SuitManager Class
VRPN Plugin
VrpnClient Class
VrpnAnalogDevice Class
VrpnButtonDevice Class
VrpnTrackerDevice Class
Camera Class
EngineExpression Class
Ffp Class
Material Class
Materials Class
Mesh Class
MeshDynamic Class
MeshStatic Class
Primitives Class
Render Class
RenderEnvironmentPreset Class
Renderer Class
RenderState Class
RenderTarget Class
Shader Class
CPUShader Class
StructuredBuffer Class
Texture Class
TextureRamp Class
Viewport Class
3D Models Requirements
Art Assets Conversion
Geometry Optimization
Working with Large Number of Objects
Setting Up LODs
Using Impostors
Switching Nodes On and Off
Occlusion Culling
Optimizing Grass
Textures Optimization
Lights Optimization
Dynamic Reflections Optimization
Water Optimization
Terrain Optimization
Physics Optimization
VR Best Practices
Material Editor
Material Samples
Alpha Blend Sample
Alpha Test Sample
Blackbody Sample
Blend By Height Sample
Boiling Sample
Cubemap Texture Sample
Custom Code Sample
Custom Subgraphs Sample
Displacement Sample
Dissolve Sample
Energy Shield Sample
Fade By Depth Sample
Fresnel Effect Sample
Glass Sample
Ice Sample
Interior Mapping Sample
Loop Sample
Melting Sample
Normal From Height Texture Sample
Normal From Height Value Sample
Object-Space Normal Map Sample
Tangent-Space Normal Map Sample
Panner Sample
Portals Sample
Procedural Damage Sample
Procedural Tiles Sample
Rain Sample
Simple PBR Material Sample
UV Tiling and Offset Sample
Vegetation Sample
Vertex Color Sample
Vertex Animation Sample
Reparent to Graph Material
Material Node
Final Node
To Int Node
Portal In Node
Portal Out Node
Expression Node
Function Node
Sub Graph Node
Loop Begin Node
Loop End Node
Rotate Space Node
Transform Space Node
Reflect Node
Refract Node
Time Node
Rotate UV Node
Compose Float2 Node
Compose Float3 Node
Compose Float4 Node
Compose Int2 Node
Compose Int3 Node
Compose Int4 Node
Color Saturation Node
Contrast Node
Flowmap Panner Node
Flowmap Panner Simple Node
Levels Node
Posterize Node
RGB To Luma Node
HUE To RGB Node
RGB To HCV Node
RGB To HSV Node
HSV To RGB Node
RGB To HCY Node
HCY To RGB Node
RGB To HCL Node
HCL To RGB Node
RGB To HSL Node
HSL To RGB Node
RGB To YUV Node
YUV To RGB Node
RGB To YCbCr Node
YCbCr To RGB Node
RGB To YCgCo Node
YCgCo To RGB Node
Overlay Node
Srgb Node
Srgb Inverse Node
Position to Screen UV Node
Depth To Position Node
Reorient Normal Blend Node
Reorient Vector Blend Node
Normal Reconstruct Z Node
Position to Normal Node
Specular to Metalness Node
Calc Mip Level Node
Calculate TBN Node
Normalization TBN Node
Normal To TBN Node
Parallax Simple Node
Face Forward Node
Vertex Interpolation Node
Pack 1212 To 888 Node
Pack 888 To 1212 Node
Pack 88 To 16 Node
Pack 16 To 88 Node
Pack 44 To 8 Node
Pack 8 To 44 Node
Pack 1616 To 8888 Node
Pack 8888 To 1616 Node
Refraction Raymarched Node
Reflection Simple Node
Reflection Raymarched Node
HDRI Raymarched Node
SSAO Raymarched Node
SSGI Raymarched Node
Triplanar Color Node
Triplanar Normal Node
Blend By Height Node
Blend By Height Simple Node
Tiling and Offset Node
Normal From Height Value Node
Depth Fade Node
Interior Mapping Cubemap Node
Blackbody Node
Fresnel Node
Fresnel PBR Node
Tree Animation Node
Grass Animation Node
Get Vector From Basis Node
Angle Between Vectors Node
Flipbook Node
Hair Shading Node
Curvature Node
Replace Color Node
Float Correction By Ramp Node
Color Correction By Ramp Node
Is Auxiliary Pass Node
Is GBuffer Pass Node
Is Shadow Pass Node
Is Baking GI Node
Is Lightmap Node
Is Front Face Node
View Direction Node
Camera Direction Node
Camera Offset Node
Camera Position Node
Camera Near Node
Camera Far Node
Camera INear Node
Camera IFar Node
Matrix Projection Node
Matrix IProjection Node
Matrix Camera Projection Node
Matrix Modelview Node
Matrix IModelview Node
Matrix Old Modelview Node
Matrix Old IModelview Node
Oblique Frustum Plane Node
Screen Resolution Node
Screen IResolution Node
Screen Coord Node
Screen UV Node
Vertex Tangent Node
Vertex Binormal Node
Vertex Normal Node
Vertex Color Node
Vertex Position Node
Vertex Depth Node
Vertex UV 0 Node
Vertex UV 1 Node
Vertex ID Node
Instance ID Node
Material Mask Node
Up Node
Down Node
Forward Node
Back Node
Right Node
Left Node
Vertex Front Face Node
Object Position Node
Object Scale Node
Sun Direction Node
Moon Direction Node
Float Node
Float2 Node
Float3 Node
Float4 Node
Color (Float3) Node
Color (Float4) Node
Int Node
Int2 Node
Int3 Node
Int4 Node
Bool Node
Frame Node
IFps Node
Game Scale Node
Settings Nodes
Logical
Equal Node
Greater Node
Less Node
Less Or Equal Node
Greater Or Equal Node
Logical And Node
Logical Or Node
Logical Negative Node
Bits And Node
Bits Or Node
Bits Xor Node
Bits Negative Node
Bits Shift Left Node
Bits Shift Right Node
Branch Node
Check Range Node
Has Bit Node
Decal-Related
Decal Material Mask Node
Decal Matrix Projection Node
Decal Matrix IProjection Node
Decal Plane Node
Decal Projected Normal Node
Decal Projected Position Node
Decal Radius Node
Decal Scene Normal Node
Decal Scene Position Node
Add Node
Subtract Node
Multiply Node
Frac Node
DDX Node
DDX Coarse Node
DDX Fine Node
DDY Node
DDY Coarse Node
DDY Fine Node
DDXY Node
Clamp Node
Saturate Node
Power Node
Ceiling Node
Floor Node
Absolute Node
Sign Node
Base-E Logarithm Node
Base-2 Logarithm Node
Base-10 Logarithm Node
Base-2 Exponential Node
Base-E Exponential Node
Increment Node
Decrement Node
Mod Node
FMod Node
Divide Node
Divide Int Node
Reciprocal Node
Maximum Node
Maximum Possible Float Node
Maximum Possible Half Node
Maximum Possible Int Node
Minimum Node
Minimum Possible Float Node
Minimum Possible Int Node
Rerange Node
Square Root Node
Reciprocal Square Root Node
Round Node
Multiply And Add Node
ModF Node
Step Node
Smooth Step Node
Length Node
Length Squared Node
Normalize Node
Cross Node
Dot Product Node
Lerp Node
Lerp3 Node
Lerp Contrast Preserving Node
Inverse Lerp Node
Golden Ratio Node
Pi Node
Pi2 Node
Pi05 Node
Reverse Bits Node
Is Finite Node
Is Infinity Node
Is Nan Node
All Node
Any Node
First Bit High Node
First Bit Low Node
Distance Node
Matrix2 Node
Compose Matrix2 By Row Node
Compose Matrix3 Node
Compose Matrix3 By Row Node
Compose Matrix4 Node
Compose Matrix4 By Row Node
Get Matrix Column Node
Get Matrix Row Node
Get Matrix Value Node
Set Matrix Column Node
Set Matrix Row Node
Set Matrix Value Node
Is Ortho Node
Basis X Node
Basis Y Node
Basis Z Node
Determinant Node
Orthonormalize Node
Scale Node
Translate Node
Transpose Node
Inverse Node
Inverse Transform Node
Decompose Euler Node
Rotate Euler Node
Rotate Axis Node
Rotate X Node
Rotate Y Node
Rotate Z Node
Decompose Transform Node
Compose Transform Node
Matrix Multiply 3x3 Node
Matrix Multiply 4x4 Node
Ortho Node
Frustum Node
Perspective Node
Cube Transform Node
Matrix Object To View Node
Matrix View To Object Node
Trigonometry
ArcCosine Node
ArcSine Node
ArcTangent Node
2-Argument ArcTangent Node
Cosine Node
Hyperbolic Cosine Node
Sine Node
Hyperbolic Sine Node
Tangent Node
Hyperbolic Tangent Node
Degrees To Radians Node
Radians To Degrees Node
Light Map Texture Node
Surface Custom Texture Node
Texture 2D Node
Texture 2D Array Node
Texture 2D Int Node
Texture 3D Node
Texture Cube Node
Sample Texture Node
Texture Resolution Node
Texture Buffer Curvature Node
Texture Buffer Auxiliary Node
Texture Buffer Lights Node
Texture Buffer Depth Node
Texture Buffer SSAO Node
Texture Buffer SSGI Node
Texture Buffer SSR Node
Texture Buffer DOF Mask Node
Texture Ramp R Node
Texture Ramp RG Node
Texture Ramp RGB Node
Texture Ramp RGBA Node
Procedural
Bayer Noise Node
Blue Noise Node
Blue Noise TAA Node
Blue Noise Temporal Node
Vogel Disk Node
Hammersley Node
Alpha Fade Noise TAA Node
Checker Noise Node
Fibonacci Sphere Node
Fibonacci Hemisphere Node
Built-in Base Materials
billboards_base
billboards_cloud_base
billboards_impostor_base
clouds_base
decal_base
decal_terrain_hole_base
grass_base
grass_impostor_base
gui_base
landscape_terrain_base
landscape_terrain_detail_base
mesh_base
Physically Based Materials
particles_base
render_composite
sky_base
terrain_global_base
volume_cloud_base
volume_fog_base
volume_light_base
volume_omni_base
volume_proj_base
volume_shaft_base
water_global_base
water_mesh_base
Postprocess Materials
post_sensor
Debug Materials
debug_materials
Custom Materials
Main Samples
Animated Character
Billboards
Car Visualization
Clouds
Cluster
Clutter
Cross Section
Custom Post Effects
Depth of Field
Environment
Impostors
Interior
Landscape
Lens Flares
LOD System
Occluders
Particles
Post Sensors
Simlights
SSBevel
SSDirt
Vegetation
Volumetrics
Water
Wildfire
World Spline Graph
Material Examples
Clear Coat
Cloth
Flowmap
Hair Shading
Materials Hierarchy
Multi-layered Material
Parallax
Ramp Texture
Tessellation
Transparent Materials
Triplanar Mapping
Unlit Materials
Global Illumination
Lights
Reflections
Adding Morph Targets
Vegetation: Authoring Tips
Creating Weather Effects
Upgrading to UNIGINE 2.16
API Migration
Console Migration
Content Migration
IG Template
IG Configuration
Environment Settings
Light Settings
Entity-Related Properties
Creating Custom Components
Processing User-Defined Packets
Debugging IG Application
IG Editor Plugin
IG Host
Troubleshooting
SDK Browser Issues
UnigineEditor Issues
.NET Issues
Application Crashes
Antivirus Recommendations
Third-Party Notices
Table of Contents
Warning! This version of documentation is OUTDATED, as it describes an older SDK version! Please
switch to the documentation for the latest SDK version
Warning! This version of documentation describes an old SDK version which is no longer supported! Please
upgrade to the latest SDK version
No
language
No
language
code for this page,
shown in
other
instead.
Double
Copy
Artists
Material
Graph
Creates a
float
value from the
mantissa and exponent
values.
Last update: 2022-10-10
Yes
No
0
out of
0
users found it helpful
You have already voted
Type :
Missing information
Incorrect information
Spelling or grammar error
Code samples do not work
Code samples are needed
Other
Details *:
Login
Email:
Password:
Forgot your password?
We use cookies to ensure that we give you the best experience on our website. Click
here
for more information.
Got it
