SSAO
This section contains settings related to screen-space ambient occlusion (SSAO).
Enabled |
The value indicating if the SSAO (Screen Space Ambient Occlusion) effect is enabled. Enabled by default.
Console access: render_ssao (API control) |
Preset |
The SSAO (Screen-Space Ambient Occlusion) preset used at the moment. To customize the SSAO effect options at run time you should activate the Custom preset: One of the following values:
Console access: render_ssao_preset (API control) |
Customizable Settings#
Screen-Space Ambient Occlusion Settings
Intensity |
The intensity of the SSAO (Screen Space Ambient Occlusion) for the scene. The intensity value affects brightness of shadows: by the minimum value of 0.0f, the ambient occlusion shadowing is the lightest. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_intensity (API control) |
Intensity Lighted Side |
The intensity of the SSAO (Screen Space Ambient Occlusion) for the scene object's lighted side. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_intensity_lighted_side (API control) |
Intensity Reflection |
The intensity of SSAO (Screen Space Ambient Occlusion) on reflections. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_intensity_reflection (API control) |
Cavity |
The value indicating if the cavity option for the SSAO (Screen Space Ambient Occlusion) effect is enabled. This option improves (sharpens) the look of junction contours at low resolutions, so it should be used for detail enhancement (small stones, bolts and so on).
Enabled by default.
When checking the parameter value via API, you'll get the corresponding setting stored in the active preset (default or custom one). Console access: render_ssao_cavity (API control) |
Cavity Intensity |
The intensity of sharpening of contours for the cavity option. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_cavity_intensity (API control) |
Cavity Radius |
The size of junction contours area for the cavity option for the SSAO (Screen Space Ambient Occlusion) effect. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_cavity_radius (API control) |
Color Clamping Intensity |
The intensity of TAA color clamping at zero pixel velocity for the SSAO (Screen Space Ambient Occlusion) effect. Lower values result in more accumulated frames combined, which reduces noise flickering, but increases ghosting effect (to reduce ghosting in this case you can use SSAO Color Clamping Velocity Threshold), while higher values reduce ghosting effect, but increase flickering. Range of values: [0.0f, 1.0f]. The default value is 1.0f. Console access: render_ssao_color_clamping_intensity (API control) |
Color Clamping Velocity |
The sensitivity of TAA color clamping for the SSAO (Screen Space Ambient Occlusion) effect to pixel velocity change. This parameter is used to reduce ghosting effect for lower Color Clamping Intensity values: it automatically increases clamping intensity for higher velocities, and disables clamping for low velocity values. Range of values: [0.0f, inf]. The default value is 0.0f. Console access: render_ssao_color_clamping_velocity_threshold (API control) |
Ray Tracing |
The value indicating if ray tracing is used for SSAO (Screen Space Ambient Occlusion) calculation. When enabled, SSAO provides more realistic shadows between the objects.
Disabled by default.
Ray-traced SSAO calculation available only when the SSRTGI technique is enabled. Console access: render_ssao_ray_tracing (API control) |
The following parameters are available when Ray Tracing option is disabled:
Quality |
The quality of SSAO (Screen Space Ambient Occlusion). Each quality uses the following number of samples:
Console access: render_ssao_quality (API control) |
Resolution |
The resolution of SSAO (Screen Space Ambient Occlusion). One of the following values:
Console access: render_ssao_resolution (API control) |
Noise |
The value indicating if noise for the SSAO (Screen Space Ambient Occlusion) effect is enabled. This option reduces banding effect.
Enabled by default.
It is recommended to use noise with TAA enabled. Console access: render_ssao_noise (API control) |
Radius |
The radius of SSAO (Screen Space Ambient Occlusion). The radius is the distance for each of the points in the world space, up to which they can shadow their neighboring points:
Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_radius (API control) |
SSAO Threshold |
The threshold value for the SSAO (Screen Space Ambient Occlusion) effect. It limits SSAO in areas where information cannot be obtained. The higher the value, the less pronounced the effect is. Range of values: [0.0f, 1.0f]. The default value is 0.5f. Console access: render_ssao_threshold (API control) |
Ray Tracing Options#
Ray-Traced Global Illumination Settings
These settings are available when the Ray Tracing option is enabled.
Ray Tracing Threshold |
The threshold value for the ray-traced SSAO (Screen Space Ambient Occlusion). Ray-traced SSAO calculation is available only when the SSRTGI technique is enabled. Range of values: [0.0f, inf]. The default value is 1.0f. Console access: render_ssao_ray_tracing_threshold (API control) |
Denoise Options#
Denoise |
The value indicating if noise reduction for the ray-traced SSAO (Screen Space Ambient Occlusion) is enabled. This option reduces noise by using blur effect.
Ray-traced SSAO calculation is available only when the SSRTGI technique is enabled. Console access: render_ssao_ray_tracing_denoise (API control) |
Radius |
The radius of the area to be affected by noise reduction for the SSAO (Screen Space Ambient Occlusion) effect. Range of values: [1, 3]. The default value is 1. Console access: render_ssao_denoise_radius (API control) |
Quality |
The noise reduction quality level for the SSAO (Screen-Space Ambient Occlusion) effect defining the number of samples used. Higher values provide better reduction, but for a performance cost (choosing Medium is enough in most cases). One of the following values:
Console access: render_ssao_denoise_quality (API control) |
Intensity |
The noise reduction intensity for the SSAO (Screen Space Ambient Occlusion) effect. Higher values provide a less noisy, but more blurred result. Range of values: [0.0f, 1.0f]. The default value is 0.2f. Console access: render_ssao_denoise_intensity (API control) |
Gaussian Sigma |
The sigma parameter of Gaussian blur used for noise reduction for the SSAO (Screen Space Ambient Occlusion) effect. This parameter controls the amount of blur applied. Range of values: [0.0f, 100.0f]. The default value is 10.0f. Console access: render_ssao_denoise_gaussian_sigma (API control) |
Threshold |
The threshold.threshold value for color difference of neighboring pixels used for noise reduction for the SSAO (Screen Space Ambient Occlusion) effect. The blur is applied when the color difference is less than the threshold value. Notice Setting too high values results in blurring the whole image. Range of values: [0.0f, 1.0f]. The default value is 0.1f. Console access: render_ssao_denoise_threshold (API control) |
