Managing Game Rules
Let's create the LevelManager component to manage game rules, level states and the User Interface. The manager creates a graphical user interface and shows the time left until the game is over. It also checks and shows the number of objects left to clear away from the Play Area.
Step 1. Set Up Timer and Game UI#
A node with the LevelManager component assigned should be present in the world for rules to take effect. It will manage the timer and update the widget user interface for the game.
  1. Create a new C# component and call it LevelManager.
  2. Open the LevelManager component in an IDE and copy the code below. Save your code in an IDE to ensure it's automatic compilation on switching back to UnigineEditor.
    LevelManager.cs
    using System;
    using System.Collections;
    using Unigine;
    [Component(PropertyGuid = "AUTOGENERATED_GUID")]  // <-- this line is generated automatically for a new component
    public class LevelManager : Component
    	// level timer
    	public float timer = 100.0f;
    	bool isCounting = true;
    	int physicalObjectsNum;
    	WidgetLabel widget_timer, widget_goal;
    	void Init()
    		InitGUI();
    		// count dynamic objects in the level
    		physicalObjectsNum = node.NumChildren;
    	void InitGUI()
    		// getting a GUI pointer
    		Gui gui = Gui.Get();
    		// creating a label widget and setting up its parameters
    		widget_timer = new WidgetLabel(gui, "Time Left:");
    		widget_timer.SetPosition(10, 10);
    		widget_timer.FontColor = vec4.RED;
    		widget_goal = new WidgetLabel(gui, "Objects Left: ");
    		widget_goal.SetPosition(10, 30);
    		widget_goal.FontColor = vec4.BLUE;
    		// add widgets to the GUI
    		gui.AddChild(widget_timer, Gui.ALIGN_OVERLAP);
    		gui.AddChild(widget_goal, Gui.ALIGN_OVERLAP);
    	void Update()
    		// decrease the timer
    		if (isCounting)
    			timer -= Game.IFps;
    			if (timer <= 0)
    				isCounting = false;
    		//win
    		if (physicalObjectsNum <= 0)
    			isCounting = false;
    		// show the current time and objects left to clear
    		if (isCounting)
    			widget_timer.Text = "Time Left: " + timer.ToString("0.0") + " s";
    			widget_goal.Text = "Objects Left: " + physicalObjectsNum.ToString();
    		//hide the widgets on end game
    		else
    			widget_timer.Enabled = false;
    			widget_goal.Enabled = false;
    	void Shutdown()
    		widget_timer.DeleteLater();
    		widget_goal.DeleteLater();
    	public void DecPhysicalObjectsNum()
    		physicalObjectsNum--;
  3. Create a new Dummy Node called "level_manager" and place it somewhere in the world.
  4. Add the LevelManager component to the level_manager node.
We created the system GUI via the API from the code. The alternative method is to use UI files.
Step 2. Detect Physical Objects#
Only the level_manager's children nodes shall be deleted by the Kill Zone's trigger. Let's add each physical object that we created earlier as a child to the level_manager node. For the rules to function properly you also need to add a new condition and a method call to the KillZone component that checks if the entered node has a parent with the LevelManager component attached.
  1. Open the KillZone component in your IDE, add a levelManager field and replace the content of Enter callback function according to the following code. Save your code in an IDE to ensure it's automatic compilation on switching back to UnigineEditor.
    KillZone.cs
    public class KillZone : Component
    	// the area into which an object should fall
    	WorldTrigger trigger;
    	LevelManager levelManager;
    //=========================== NEW - END ================================
    	void Init()
    		trigger = node as WorldTrigger;
    		if (trigger != null)
    			trigger.AddEnterCallback(Enter); // set the handler to be executed when an object enters the area
    	void Enter(Node target)
    		levelManager = target.GetComponentInParent<LevelManager>();
    		// check if the parent node has a LevelManager component attached
    		if (levelManager != null)
    			// delete the entered node and decrease the amount of physical objects
    			levelManager.DecPhysicalObjectsNum();
    			target.DeleteLater();
  2. Let's set the level_manager node as a parent to physical objects. Open the ObjectGenerator component in your IDE and replace the code with the following. Save the code in your IDE and switch back to UnigineEditor.
    ObjectGenerator.cs (C#)
    public class ObjectGenerator : Component
    	public Node levelManager;
    	private void Init()
    		if (levelManager)
    			// cube
    			Mesh meshBox = new Mesh();
    			meshBox.AddBoxSurface("box_surface", new vec3(1.0f));
    			ObjectMeshStatic box = new ObjectMeshStatic(meshBox);
    			box.Parent = levelManager;
    			box.TriggerInteractionEnabled = true;
    			box.SetIntersectionMask(0x00000080, meshBox.FindSurface("box_surface")); // check the BulletIntersection bit
    			box.WorldTransform = MathLib.Translate(new vec3(0.5f, 7.5f, 1.0f));
    			box.SetMaterialPath("materials/mesh_base_0", "*");
    			box.Name = "box";
    			BodyRigid bodyBox = new BodyRigid(box);
    			ShapeBox shapeBox = new ShapeBox(bodyBox, new vec3(1.0f));
    			new ShapeSphere(bodyBox, 0.5f);
    			bodyBox.ShapeBased = false;
    			bodyBox.Mass = 2.0f;
    			// sphere
    			Mesh meshSphere = new Mesh();
    			meshSphere.AddSphereSurface("sphere_surface", 0.5f, 9, 32);
    			ObjectMeshStatic sphere = new ObjectMeshStatic(meshSphere);
    			sphere.Parent = levelManager;
    			sphere.TriggerInteractionEnabled = true;
    			sphere.SetIntersectionMask(0x00000080, meshSphere.FindSurface("sphere_surface")); // check the BulletIntersection bit
    			sphere.WorldTransform = MathLib.Translate(new vec3(4.5f, 5.5f, 1.0f));
    			sphere.SetMaterialPath("materials/mesh_base_1", "*");
    			sphere.Name = "sphere";
    			BodyRigid bodySphere = new BodyRigid(sphere);
    			new ShapeSphere(bodySphere, 0.5f);
    			bodySphere.ShapeBased = false;
    			bodySphere.Mass = 2.0f;
    			// capsule
    			Mesh meshCapsule = new Mesh();
    			meshCapsule.AddCapsuleSurface("capsule_surface", 0.5f, 1.0f, 9, 32);
    			ObjectMeshStatic capsule = new ObjectMeshStatic(meshCapsule);
    			capsule.Parent = levelManager;
    			capsule.TriggerInteractionEnabled = true;
    			capsule.SetIntersectionMask(0x00000080, meshCapsule.FindSurface("capsule_surface")); // check the BulletIntersection bit
    			capsule.WorldTransform = MathLib.Translate(new vec3(4.5f, 0.5f, 3.0f));
    			capsule.SetMaterialPath("materials/mesh_base_2", "*");
    			capsule.Name = "capsule";
    			BodyRigid bodyCapsule = new BodyRigid(capsule);
    			new ShapeCapsule(bodyCapsule, 0.5f, 1.0f);
    			bodyCapsule.ShapeBased = false;
    			bodyCapsule.Mass = 2.0f;
  3. Select the object_generator node in the World Nodes window and drag the level_manager node to the corresponding field of the ObjectGenerator component.
  4. Save changes to the world, go to File->Save World or press Ctrl+S hotkey. Then run the game to see the game rules in action.
Last update: 2022-04-11
