This example shows how to create a cloth pinned to two dummy bodies using the particles joints. The cloth falls down and rests on a sphere, which illustrates the cloth ability to change its form.
To implement this, we need to perform the following:
- Create a cloth and set its parameters.
- Create two Dummy Objects that can hold the cloth. They also should have a body so that we can connect a cloth to them using joints.
- Create a sphere that is not a physical body (so that it would not drop and roll away), but is a collider, so our cloth will not fall through.
We are going to create functions for each participant of the example and then use these functions in init() to create the required objects.
Code Sample#
The complete code sample is provided below.
Source code (UnigineScript)
#include <core/scripts/primitives.h>
ObjectMeshDynamic MyCloth;
ObjectMeshDynamic MySphere;
ObjectDummy dummy1;
ObjectDummy dummy2;
// function, creating a named sphere with a specified radius and color at a specified position
Object createSphere(string name, float radius, Vec4 color, Vec3 pos)
// creating a dynamic mesh object with a sphere surface
ObjectMeshDynamic sphere = Unigine::createSphere(radius);
sphere.setWorldTransform(translate(pos));
sphere.setMaterialParameterFloat4("albedo_color", color, 0);
sphere.setName(name);
return sphere;
// function, creating a named cloth body with specified parameters
Object createBodyCloth(string name, float width, float height, float step, float mass, float friction, float restitution, float rigidity, float lrestitution, float arestitution, int num_iterations, Vec4 color, Vec3 pos)
// creating a dynamic mesh object with a plane surface and passing it to Editor
ObjectMeshDynamic cloth = Unigine::createPlane(width,height,step);
//assigning a cloth body to the dynamic mesh object and setting cloth parameters
BodyCloth body = class_remove(new BodyCloth(cloth));
body.setMass(mass);
body.setFriction(friction);
body.setRestitution(restitution);
body.setLinearRestitution(lrestitution);
body.setAngularRestitution(arestitution);
body.setRigidity(rigidity);
body.setNumIterations(num_iterations);
cloth.setMaterialParameterFloat4("albedo_color", color, 0);
cloth.setWorldTransform(pos);
cloth.setName(name);
return cloth;
// function, creating a named dummy body of a specified size at a specified position
Object createBodyDummy(string name, Vec3 size, Vec3 pos)
// creating a dummy object and passing it to Editor
ObjectDummy dummy = new ObjectDummy();
dummy.setWorldTransform(translate(pos));
dummy.setName(name);
BodyDummy body = class_remove(new BodyDummy(dummy));
ShapeBox shape = class_remove(new ShapeBox(size));
body.addShape(shape, translate(0.0f, 0.0f, 0.0f));
return dummy;
int init() {
// setting up player
PlayerSpectator player = new PlayerSpectator();
player.setPosition(Vec3(30.0f,0.0f, 30.5f));
player.setDirection(Vec3(-1.0f, 0.0f, -0.4f));
// creating a cloth
MyCloth = createBodyCloth("MyCloth", 20.0f, 20.0f, 1.0f, 10.0f, 0.05f, 0.05f, 0.05f, 0.2f, 0.05f, 8, Vec4(1.0f, 0.1f, 0.1f, 1.0f), translate(Vec3(0.0f, 0.0f, 25.0f)));
// creating a sphere
MySphere = createSphere("MySphere", 3.0f, Vec4(1.0f, 0.1f, 0.1f, 1.0f), Vec3(-1.0f, 0.0f, 16.0f));
// creating 2 dummy bodies to which the cloth will be attached
dummy1 = createBodyDummy("fixpoint1", Vec3(1.0f, 1.0f, 1.0f), Vec3(-10.0f, -10.0f, 25.0f));
dummy2 = createBodyDummy("fixpoint2", Vec3(1.0f, 1.0f, 1.0f), Vec3(-10.0f, 10.0f, 25.0f));
class_remove(new JointParticles(dummy1.getBody(),MyCloth.getBody(),dummy1.getPosition(),Vec3(1.0f)));
class_remove(new JointParticles(dummy2.getBody(),MyCloth.getBody(),dummy2.getPosition(),Vec3(1.0f)));
