High-Level Vehicle Demo
High-Level Vehicle demo project showcases a new High-Level Car Physics System. To learn more on using the system to create your own wheeled vehicle simulation please refer to this article. High-Level Vehicle 演示项目展示了一个新的高级汽车物理系统。要了解有关使用该系统创建自己的轮式车辆模拟的更多信息,请参阅本文.
Features特征#
- Setting engine's power and resistance curves, as well as idle speed (RPM).设置发动机的功率和阻力曲线,以及怠速 (RPM)。
- Gearbox simulation (manual and automatic) enabling you to adjust throttle and speed values for shifting gears along with transition time, as well as to set the number of gears and configure gear ratios.变速箱模拟(手动和自动)使您能够调整换档时的油门和速度值以及转换时间,以及设置档位数量和配置传动比。
- Mathematical wheel model for more realistic steering, enabling simulation of forces affecting the rotating wheel, along with an ability to adjust suspension travel distance, spring, and damping values.用于更逼真转向的数学车轮模型,能够模拟影响旋转车轮的力,以及调整悬架行程距离、弹簧和阻尼值的能力。
- Easy setup of steering and driving axes along with capability to turn the differential lock on and off.转向和驱动轴的轻松设置以及打开和关闭差速锁的能力。
- Switching between different views (driver's view, external camera, etc.).在不同视图(驾驶员视图、外部摄像头等)之间切换。
- Simulation of various surface conditions (such as dry, wet, snow-covered, or icy road, mud, and so on).模拟各种表面条件(如干燥、潮湿、积雪或结冰的道路、泥泞等)。
- A set of debug windows displaying information on all vehicle parameters in real time.一组实时显示所有车辆参数信息的调试窗口。
访问演示项目源代码#
您可以学习和修改此演示的源代码来创建自己的项目。 要访问源代码,请执行以下操作:
- 在Demos部分中找到High-Level Vehicle Demo演示并点击Install(安装)(如果您尚未安装)。
- 安装成功后,demo会出现在Installed部分,您可以点击Copy as Project基于此创建项目 演示。
- 在打开的 Create New Project 窗口中,在相应字段中输入新项目的名称,然后单击Create New Project.
- 现在您可以点击Open Code IDE查看和修改默认IDE中的源代码,或者点击Open Editor打开项目 在 UnigineEditor中。
最新更新:
2022-12-14
